查看: 1209|回复: 1
[分享]:拷贝、移动所选实体到另一个空间的程序
发表于 2005-8-9 20:30:31 | 显示全部楼层 |阅读模式
[php]
(defun sp2sp_error (msg)
  (if (not (member msg '("Function cancelled" "console break")))
    (princ (strcat "\nError " msg))
  (command ".undo" "end")
  (var_restore)
  (princ)
(defun var_set (var_list)
  (foreach pair        var_list
    (setq
      sysvars (cons (cons (strcase (car pair)) (getvar (car pair)))
                    sysvars
    (if        (cdr pair)
      (setvar (car pair) (cadr pair))
(defun var_restore ()
  (foreach pair sysvars (setvar (car pair) (cdr pair)))
  (setq *error* old_error)
  (princ)
(defun dtr (d) (/ (* d pi) 180.0))
(defun rtd (r) (/ (* r 180.0) pi))
(defun sp2sp (val / ed en msctr nm old_error psctr rt ss ssv sysvars sz
              trig vd)
  (princ "\nSpace to Space")
  (if (= (getvar "tilemode") 1)
    (alert "\nCommand not allowed.\nTILEMODE must be set to 0.")
    (if (= (length (vports)) 1)
      (alert "\nThere are no active Model space viewports.")
      (progn
        (command ".undo" "group")
        (var_set '(("cmdecho" 0) ("expert" 2) ("osmode" 0)))
        (setq old_error        *error*
              *error*        sp2sp_error
              trig        nil
        (graphscr)
        (if (or (= val 1) (= val 2))
          (command "mspace")
          (command "pspace")
        (if (or (= val 1) (= val 3))
          (princ "Select objects to copy: \n ")
          (princ "Select objects to move: \n ")
        (setq
          ss (ssget '((-4 . "<NOT") (0 . "VIEWPORT") (-4 . "NOT>")))
        (if (or (= val 3) (= val 4))
          (progn (command "mspace")
                 (if (= val 3)
                   (getpoint "\n \n \nPick viewport to copy to: ")
                   (getpoint "\n \n \nPick viewport to move to: ")
        (setq msctr (getvar "viewctr"))
        (command "pspace")
        (setq SSV (ssget "x" (list (cons 0 "VIEWPORT"))))
        (if (/= SS nil)
          (progn
            (while (= trig nil)
              (setq EN (ssname SSV 0))
              (setq ED (entget EN '("ACAD")))
              (setq NM (cadr (assoc '-3 ED)))
                (progn (setq RT (rtos (rtd (cdr (nth 6 NM))) 2 6))
                       (setq
                         SZ (rtos (/ (cdr (assoc '41 ED)) (cdr (nth 7 NM)))
                                  2
                                  6
                (progn
                  (setq RT (rtos (- 360 (rtd (cdr (nth 6 NM)))) 2 6))
                  (setq
                    SZ (rtos (/ (cdr (nth 7 NM)) (cdr (assoc '41 ED)))
                             2
                             6
              (if (= (cdr (assoc '68 ED)) 2)
                (setq trig 1)
              (ssdel EN SSV)
            (setq VD (cdr (nth 5 NM)))
            (setq psctr (cdr (assoc '10 ED)))
            (if        (and (= (car VD) 0.0)
                     (= (cadr VD) 0.0)
                     (= (caddr VD) 1.0)
              (progn
                  (command "mspace")
                (cond ((= val 1)
                       (command "block" "sp2sp" msctr ss "" "oops")
                      ((= val 2) (command "block" "sp2sp" msctr ss ""))
                      ((= val 3)
                       (command "block" "sp2sp" psctr ss "" "oops")
                      ((= val 4) (command "block" "sp2sp" psctr ss ""))
                  (command "pspace")
                  (command "mspace")
                  (command "insert" "*sp2sp" psctr SZ RT)
                  (command "insert" "*sp2sp" msctr SZ RT)
                (alert
                  "Selected entities must be in \na viewport that is set to\nthe world coordinate system!"
                (alert
                  "Selected viewport must set to\nthe world coordinate system!"
        (var_restore)
  (princ)
(defun c:c2p () (sp2sp 1))
(defun c:m2p () (sp2sp 2))
(defun c:c2m () (sp2sp 3))
(defun c:m2m () (sp2sp 4))
[/php]
命令 c2p  拷贝所选实体到图纸空间
命令 m2p  移动所选实体到图纸空间
命令 c2m 拷贝所选实体到模型空间
命令 m2m 移动所选实体到模型空间
虽然用autocad的复制或带基点复制以及粘贴也可以实现,但这个程序使用起来更方便。
举个简单例子:
图框是在图纸空间的, 图框中有一个viewport。 现在你想把这个图框移动(或复制)到模型空间, 只要输入m2m(或c2m)选取该图框, 然后按提示点选那个viewport就行了。
反之也一样(不过tilemode必须为0)
发表于 2013-10-20 11:33:11 | 显示全部楼层
不错这个功能不错!
GMT+8, 2026-11-6 16:48 , Processed in 0.801048 second(s), 34 queries , Gzip On.
