查看: 1178|回复: 0
[求助]:大家帮小弟看看这个程序有什么问题?
发表于 2005-8-10 11:26:46 | 显示全部楼层 |阅读模式
功能就是遍历整个块表,找到颜色索引为100的实体,然后用改实体跟整个块表中其他的实体进行布尔差运算,然后把最终的实体添加到块表中。程序如下:
AcDbBlockTable *pThisBlockTable;
        acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pThisBlockTable,
                AcDb::kForWrite);
        AcDbBlockTableRecord *pOtherBtr;
        pThisBlockTable->getAt(ACDB_MODEL_SPACE,pOtherBtr,AcDb::kForWrite);
        pThisBlockTable->close();
        AcDbBlockTableRecordIterator *pOIter,*Iter;
        AcDbEntity *mpipe;
        AcDb3dSolid *ZSolid;
        AcDbObjectId ZSolidId,mpipeId;
        pOtherBtr->newIterator(pOIter);
        for(pOIter->start();!pOIter->done();pOIter->step())
                AcDbEntity *ent;
                pOIter->getEntity(ent,AcDb::kForWrite);
                if(ent->colorIndex()==100)
                        mpipeId=ent->objectId();
                ent->close();
        delete pOIter;
        pOtherBtr->close();
        acdbOpenObject(mpipe,mpipeId,AcDb::kForWrite);
        ZSolid=(AcDb3dSolid *)mpipe;
        mpipe->close();
        pOtherBtr->newIterator(Iter);
        for(Iter->start();!Iter->done();Iter->step())
                AcDbEntity *mainp;
                Iter->getEntity(mainp,AcDb::kForWrite);
                if(mainp->colorIndex()!=100)
                        ZSolid->booleanOper(AcDb::kBoolSubtract,(AcDb3dSolid *)mainp);
                mainp->close();
        pOtherBtr->appendAcDbEntity(ZSolidId,ZSolid);
        ZSolid->close();
        delete Iter;
        pOtherBtr->close();
但是我每次运行到第二个遍历就会出现下面的问题:内部错误:!U:\global\src\coreacad\CORESRC\scandr.cpp@773:eWaoOpenForWrite,然后CAD就自动关闭了,这是哪里出错了?应该怎么改?
GMT+8, 2026-11-22 08:09 , Processed in 0.364862 second(s), 11 queries , Gzip On, File On.
