查看: 1312|回复: 2
[求助]如何得到AcDbBlockReference图块对象的图块名称?
发表于 2005-8-16 18:27:28 | 显示全部楼层 |阅读模式
找了好多函数,好像没有直接得到的啊。
或者怎么转换成AcDbBlockTableRecord对象,然后调用GetName(),但是如何根据AcDbBlockReference对象得到AcDbBlockTableRecord对象呢?
发表于 2005-8-17 14:12:45 | 显示全部楼层
遇到此类问题见意看看ARX帮助文件
AcDbObjectId
blockTableRecord() const;
This function returns the object ID of the AcDbBlockTableRecord referenced by the block reference.
The referenced block table record contains the entities that the block reference will display.
The block table record object ID is used to get the entity name that is used with the group code -2 in AutoLISP and ADSRX entity information listings of the block reference.
遇到此类问题见意看看ARX帮助文件
AcDbObjectId
GMT+8, 2026-11-6 02:45 , Processed in 0.400932 second(s), 36 queries , Gzip On.
