查看: 1209|回复: 3
[LISP程序]:那位高手帮我修改下面那个LISP程序
发表于 2005-8-21 01:49:09 | 显示全部楼层 |阅读模式
那位高手帮我修改下,下面那个LISP程序。
他只能打断线。不能打断圆跟孤。。。打断是在这条线或孤的等分点处打断。。打断的数量跟长度自定义。。
(defun c:bb(/ ent_ca len cx ename elist entna im)
(setq temperr *error*)
(setq *error* abtrap)
(setq old1 (getvar "blipmode"))
(setq old (getvar "pickfirst"))
(setq cmd (getvar "cmdecho"))
(setvar "cmdecho" 0)
(command "undo" "m")
(setvar "blipmode" 0)
(setvar "pickfirst" 0)
(prompt "\n选择线加桥.")
(setq ent_ca (ssget))
(if (= ent_ca nil) (exit))
(if (= bridge nil) (setq bridge 6.0))
(initget (+ 2 4) "Y N")
(setq exitid (getkword "\n按等距离排列:<N> "))
(if (or (= exitid nil) (= exitid "N"))
    (setq im nil)
(if (= exitid "Y")
    (setq im "T")
(if (= im "T") (progn ;等距排列
                  (princ "\n定义桥位个数:<3> ")
                  (setq s (getstring))
                  (if (/= s "") (setq num (atoi s)) (setq num 3))
                (progn
                  (setq exitid (getkword "\n桥位距离统一:<N> "))
                  (if (or (= exitid nil) (= exitid "N"))(setq csd nil))
                  (if (= exitid "Y") (setq csd "T"))
(princ "\n定义桥位宽度:<")
(princ bridge)
(princ "> ")
(if (/= s "") (setq bridge (atof s)))
(setq len (sslength ent_ca))
(setq cx 0)
(repeat len
    (setq ename (ssname ent_ca cx))
    (setq elist (entget ename))
    (setq entna (cdr (assoc 0 elist)))
    ;(if (/= entna "LINE") (progn
    ;                       (princ "\nOnly process LINE entity.")
    (if ( = entna "LINE") (progn
                            (setq st (cdr (assoc 10 elist)))
                                   (setq ed (cdr (assoc 11 elist)))
                            (setq dis (distance st ed))
                            (entdel ename)
                            (if (= im nil)(progn
                                              (if (and (<= dis 5) (>= dis 0)) (entdel ename))
                                              (if (and (>  dis 5) (< dis 19.9)) (asb))
                                              (if (and (>= dis 19.9) (<= dis 180)) (adb1))
                                              (if (and (>  dis 180)(< dis 300)) (adb2))
                                              (if (>= dis 300) (adb3))
                              (progn
                                (abim)
    (setq cx (+ cx 1))
(setvar "blipmode" old1)
(setvar "pickfirst" old)
(setvar "cmdecho" cmd)
(setq csd nil dis nil num nil)
(setq *error* temperr)
(princ)
(defun asb(/ ang di1 di2 pt1 pt2)
(setq ang (angle st ed))
(if (/= csd nil)(progn
                   (setq di1 (/ (- dis bridge) 2))
                   (setq di2 (+ (/ (- dis bridge) 2) bridge))
                 (progn
                   (setq di1 (/ (- dis 1.5) 2))
                   (setq di2 (+ (/ (- dis 1.5) 2) 1.5))
(setq pt1 (polar st ang di1))
(setq pt2 (polar st ang di2))
(entmake (list (cons 0 "LINE") (cons 10 st) (cons 11 pt1)))
(entmake (list (cons 0 "LINE") (cons 10 pt2) (cons 11 ed)))
(defun adb1(/ ang di1 di2 pt1 pt2)
(defun adb2(/ ang di1 di2 pt1 pt2 pt3 pt4)
(setq di1 (- dis (+ 60 bridge)))
(setq di2 (- dis 60))
(setq pt1 (polar st ang 60))
(setq pt2 (polar st ang (+ 60 bridge)))
(setq pt3 (polar st ang di1))
(setq pt4 (polar st ang di2))
(entmake (list (cons 0 "LINE") (cons 10 pt2) (cons 11 pt3)))
(entmake (list (cons 0 "LINE") (cons 10 pt4) (cons 11 ed)))
(defun adb3(/ ang di1 di2 di3 di4 pt1 pt2 pt3 pt4 pt5 pt6)
(setq di1 (- (/ dis 2) (/ bridge 2)))
(setq di2 (+ (/ dis 2) (/ bridge 2)))
(setq di3 (- dis (+ 60 bridge)))
(setq di4 (- dis 60))
(setq pt5 (polar st ang di3))
(setq pt6 (polar st ang di4))
(entmake (list (cons 0 "LINE") (cons 10 pt4) (cons 11 pt5)))
(entmake (list (cons 0 "LINE") (cons 10 pt6) (cons 11 ed)))
(defun abim(/ ang singlelen cx pt pt1)
(setq singlelen (/ (- dis (* num bridge)) (+ num 1)))
(setq cx 0)
(repeat (+ num 1)
  (setq pt (polar st ang (* cx (+ singlelen bridge))))
  (if (= cx num) (setq pt1 ed) (setq pt1 (polar pt ang singlelen)))
  (entmake (list (cons 0 "LINE") (cons 10 pt) (cons 11 pt1)))
  (setq cx (+ cx 1))
(defun abtrap (errmsg)
(command "undo" "b")
(princ)
(princ)
已领礼包: 12483个
发表于 2005-8-21 20:46:09 | 显示全部楼层
楼主是做模切板的。
 楼主| 发表于 2005-8-21 23:17:15 | 显示全部楼层
你是从事那行的。。。。。也干过这行啊
已领礼包: 12483个
发表于 2005-8-23 14:28:37 | 显示全部楼层
GMT+8, 2026-11-3 08:05 , Processed in 0.474750 second(s), 39 queries , Gzip On.
