查看: 1608|回复: 2
[LISP函数-点集]:获取点集中距离最远的两点集合
发表于 2005-9-1 18:36:42 | 显示全部楼层 |阅读模式
  1. ;;获取点集中距离最远的两点集合
  2. ;; 返回值 ((point11 point12) (point21 point22) ... )
  3. (defun xd-GetFarthestPoints (ptl / ll p1 p2 d)
  4.   (setq        ll
  5.          (vl-sort
  6.            (mapcar
  7.              '(lambda (x)
  8.                 (car
  9.                   (vl-sort
  10.                     (mapcar '(lambda (p) (list (distance p x) x p)) ptl)
  11.                     '(lambda (e1 e2)
  12.                        (> (car e1) (car e2))
  13.                      )
  14.                   )
  15.                 )
  16.               )
  17.              ptl
  18.            )
  19.            '(lambda (a b) (> (car a) (car b)))
  20.          )
  21.   )
  22.   (setq        p1 (list (cdar ll))
  23.         d  (caar ll)
  24.         ll (cdr ll)
  25.   )
  26.   (while (equal (car (setq p2 (car ll))) d 1e-5)
  27.     (if        (and (not (vl-position (cdr p2) p1))
  28.              (not (vl-position (list (caddr p2) (cadr p2)) p1))
  29.         )
  30.       (setq p1 (append p1 (list (cdr p2))))
  31.     )
  32.     (setq ll (cdr ll))
  33.   )
  34.   (if (= (length p1) 1)
  35.     (car p1)
  36.     p1
  37.   )
  38. )
发表于 2005-9-1 22:43:48 | 显示全部楼层
  1. (defun Get$estPoints(pts / lst pt x y $temp)
  2. (defun $temp(pt pts / x)
  3.    (mapcar '(lambda(x)(list(distance pt x) pt x)) pts)
  4. )
  5. (while (setq pt(car pts)
  6.               pts(cdr pts))
  7.         (setq lst(cons ($temp pt pts)lst))
  8.   )
  9. (mapcar 'cdr
  10.    (vl-sort (apply 'append lst) '(lambda(x y)(>(car x)(car y))))
  11. )
  12. )
返回按距离排好序(大于)的俩俩点表.
发表于 2006-10-30 12:42:50 | 显示全部楼层
  1. (defun mlenpts (ptlst / pt d maxd mind maxl minl)
  2.   (setq minl (list (car ptlst)(cadr ptlst)) maxd 0 mind (apply 'distance minl))
  3.   (while (setq pt (car ptlst) ptlst (cdr ptlst))
  4.     (foreach n ptlst
  5.       (setq d (distance n pt))
  6.       (cond ((< maxd d)(setq maxd d maxl (list n pt)))
  7.             ((> mind d)(setq mind d minl (list n pt)))
  8.       )
  9.     )
  10.   )(list maxl minl)
  11. )
GMT+8, 2026-11-22 10:34 , Processed in 0.350023 second(s), 14 queries , Gzip On, File On.
