查看: 2271|回复: 16
[求助] [求助]:请教那位大侠在此标注的LISP文件上加上选择文字的大小和小数点的位数!谢谢!
发表于 2005-9-4 11:10:47 | 显示全部楼层 |阅读模式
请教那位大侠在此标注的LISP文件上加上选择文字的大小和精度(小数点的位数)!谢谢!
此LISP标注时要加上TXT图层!
[php]
(defun c:tjj()
  (setvar "cmdecho" 0)
  (setvar "osmode" 1)
  (command "osnapcoord" 2)
  (command "ucs" "w")
  (command "layer" "s" "txt" "")
  (setq p4 (getpoint "\n 请输入图框左下角:"))
  (setq p5 (getpoint "\n 请输入图框右上角:"))
  (setq p1 (getpoint "\n 请输入要统计的左下角:"))
  (setq x1 (car p1) y1 (cadr p1))
  (setq p0 (getpoint "\n 请输入要统计的右上角:"))
  (setq p3 (getpoint "\n 请输入统计文字位置:"))
  (setq x4 (car p4) x5 (car p5))
  (setq w (- x5 x4))
  (setq h (* (/ w 280) 2))
  (setq p8 (getpoint "\n 请输入座标放置位置:"))
  (setq p9 (polar p8 0 (* 4 h)))
  (setq p10 (polar p8 0 (* 14 h)))
  (setq p11 (polar p8 0 (* 22 h)))
  (setq p12 (polar p8 (* 1.5 pi) h))
  (setq p13 (polar p11 (* 1.5 pi) h))
  (command "line" p12 p13 "" "")
  (setvar "osmode" 0)
  (command "text" "ml" p9 h 0 "X")
  (command "text" "ml" p10 h 0 "Y")
  (setq txt "ABCDEFGHIJKLMNOPQ")
  (setq ss (ssget "w" p1 p0 '((-4 . "<or") (0 . "arc") (0 . "circle") (-4 . "or>"))))
  (setq i 1)
  (setq pt p3)
  (while ss
     (setq en (ssname ss 0))
     (setq end (entget en))
     (setq rad (+ (cdr (assoc 40 end)) 0.000))
     (setq pci (cdr (assoc 0 end)))
     (setq d (rtos (* 2 rad)))
     (setq ssa (ssget "w" p1 p0 (list (cons 40 rad) (cons 0 pci))))
     (setq nn (sslength ssa))
     (setq stxt (substr txt i 1))
     (setq m 0)
     (setq x 0)
       (repeat nn
          (setq een (ssname ssa m))
          (setq eend (entget een))
          (setq cen (cdr (assoc 10 eend)))
          (setq xxx (- (+ 0.000 (car cen)) x1))
          (setq yyy (- (+ 0.000 (cadr cen)) y1))
          (setq xxxt (rtos xxx))
          (setq yyyt (rtos yyy))
          (setq ssb (ssget "x" (list (cons 10 cen))))
          (setq nnn (sslength ssb))
            (if (= nnn 2)
               (progn
                 (setq f (ssname ssb 0))
                 (setq g (ssname ssb 1))
                 (setq fn (entget f))
                 (setq gn (entget g))
                 (setq radf (+ (cdr (assoc 40 fn)) 0.000))
                 (setq radg (+ (cdr (assoc 40 gn)) 0.000))
                 (setq radma (max radf radg))
                 (setq radmi (min radf radg))
                 (setq p2 (polar cen (* 1.75 pi) (+ 4 radma)))
                 (if (= rad radf) (setq ss (ssdel g ss)) (setq ss (ssdel f ss)))
                 (if (= rad radf) (setq hn fn) (setq hn gn))
                 (setq ty (cdr (assoc 0 hn)))
                 (setq dma (rtos (* 2 radma)))
                 (setq dmi (rtos (* 2 radmi)))
                 (if (= ty "CIRCLE") (setq sssstxt (strcat " %%c" dma "<CB>")) (setq sssstxt (strcat " M" dma)))
                 (setq ssstxt (strcat "-%%C" dmi "<THR>" sssstxt))
               (setq p2 (polar cen (* 1.75 pi) (+ 3 rad))
                     ssstxt (strcat "-%%C" (rtos (* 2 rad) 2 3) "<THR>"))
          (setq x (+ 1 x))
          (setq xt (itoa x))
          (setq xtxt (strcat stxt xt))
          (setq xxxxt (strcat xtxt ":"))
          (command "text" "ml" p2 h 0 xtxt)
          (setq p8 (polar p8 (* 1.5 pi) (* 2 h)))
          (setq p9 (polar p9 (* 1.5 pi) (* 2 h)))
          (setq p10 (polar p10 (* 1.5 pi) (* 2 h)))
          (setq p11 (polar p11 (* 1.5 pi) (* 2 h)))
          (command "line" (polar p8 (* 1.5 pi) h) (polar p11 (* 1.5 pi) h) "" "")
          (command "text" "ml" p8 h 0 xxxxt)
          (command "text" "ml" p9 h 0 xxxt)
          (command "text" "ml" p10 h 0 yyyt)
          (setq ss (ssdel een ss))
          (setq m (+ 1 m))
     (setq sstxt (strcat stxt " : " (itoa nn) ssstxt))
     (command "text" "ml" pt h 0 sstxt)
     (setq i (+ i 1))
     (setq pt (polar pt (* 1.5 pi) (* 1.5 h)))
  (setvar "osmode" 7)
(prinl)
)[/php]
发表于 2005-9-4 11:26:13 | 显示全部楼层
错误:
1. (setq ss (ssget "w" p1 p0 '((-4 . " (setq i 1)
2. line命令应以""结束
(command "line" (polar p8 (* 1.5 pi) h) (polar p11 (* 1.5 pi) h) "" "");多了两个引号应为:
(command "line" (polar p8 (* 1.5 pi) h) (polar p11 (* 1.5 pi) h) "")
目前程序是否能用?
 楼主| 发表于 2005-9-4 11:30:28 | 显示全部楼层
最初由 xyp1964 发布
[B]错误:(setq ss (ssget "w" p1 p0 '((-4 . " (setq i 1) [/B]
目前可以用!就是不可以改变字体大小和精度!
请教!怎样改? 谢谢!!!
发表于 2005-9-4 17:37:22 | 显示全部楼层
就如xyp版主说的,这个ssget有些问题
由于你这个lisp文件看起来是很专用的程序
所以你可能得大概描述一下,它是干什么用的,比如拿来统计什么,标注,圆,还是文字
输出的大概是什么。
至于要求的文字和精度,指的是什么哪一步。
只有说清楚了,才比较好解决:)
发表于 2005-9-4 18:21:53 | 显示全部楼层
过滤器带“OR”用PHP代码吧
 楼主| 发表于 2005-9-4 21:50:26 | 显示全部楼层
此LISP是用来统计相同圆的数量和列出圆的坐标位置!
但是现在列出来的小数点的位数不可以选择!
                            如下
系号   ---------     X坐标    --------        Y坐标
A1          ---------   52.78952     --------      31.57891
  A2          ---------    3.01238      --------     65.12389
  B1          ---------  3.01549         --------     9.01358
  C1          ---------   39.01589      --------     9.01235
请拿位高手在此LISP文件上加上选择标注后小数点的位数!和数字的大小!谢谢!
发表于 2005-9-4 22:06:27 | 显示全部楼层
[php](load "xyp_lib")
;|加载通用函数(可在签名栏直接下载)
如果已经下载xyp_lib并放到搜索路径下可以不再下载!
利用以下任何一种方式即可加载和运行通用函数内的所有子程序:
1.在acad.lsp中增加(load"xyp_lib")
2.在每个程序内增加(load"xyp_lib")
3.在command下,输入(load"xyp_lib")
4.在菜单.mnl中增加(load"xyp_lib")
5.将xyp_lib.vlx文件直接拽到cad屏幕
★通用函数下载地址:[/COLOR]
http://www.xdcad.net/forum/attachment.php?s=&postid=1606661
http://www.mjtd.com/bbs/dispbbs. ... ID=37554&page=1|;
(defun c:tjj ()
  (cmdla0)
  (mkla "txt" 1)
  (setq        h   (UREAL 7 "" "\n文字高度" h)
        xsd (UINT 1 "" "\n小数点的位数" xsd)
        p5  (getcorner p4 "\n 请输入图框右上角:")
        x1  (car p1)
        y1  (cadr p1)
        p0  (getcorner p1 "\n 请输入要统计的右上角:")
        x4  (car p4)
        x5  (car p5)
        w   (- x5 x4)
        p8  (getpoint p3 "\n 请输入座标放置位置:")
  (command "line" p12 p13 "")
  (setvar "osmode" 0)
  (setq        txt "ABCDEFGHIJKLMNOPQRSTUVWXYP"
        ss  (ssget "w" p1 p0 '((0 . "arc,circle")))
        i   1
        pt  p3
  (while ss
          end  (entget en)
          d    (rtos (* 2 rad) 2 xsd)
          nn   (sslength ssa)
          m    0
          x    0
    (repeat nn
            eend (entget een)
            xxxt (rtos xxx 2 xsd)
            yyyt (rtos yyy 2 xsd)
            nnn         (sslength ssb)
      (if (= nnn 2)
        (progn
                g     (ssname ssb 1)
                fn    (entget f)
                gn    (entget g)
          (if (= rad radf)
          (if (= rad radf)
            (setq hn fn)
            (setq hn gn)
                dma (rtos (* 2 radma) 2 xsd)
                dmi (rtos (* 2 radmi) 2 xsd)
          (if (= ty "CIRCLE")
            (setq sssstxt (strcat " %%c" dma ""))
          (setq ssstxt (strcat "-%%C" dmi "" sssstxt))
              ssstxt (strcat "-%%C" (rtos (* 2 rad) 2 xsd) "")
      (setq x          (+ 1 x)
            xt          (itoa x)
      (command "line"
            m  (+ 1 m)
    (setq i  (+ i 1)
  (cmdla1)
(pxyp"tjj")
[/php]
 楼主| 发表于 2005-9-4 23:23:20 | 显示全部楼层
好像不可以用了!还是我加的不对?请xyp版主再帮忙看看!谢谢!!
发表于 2005-9-4 23:47:26 | 显示全部楼层
编译程序:
发表于 2005-9-5 18:20:30 | 显示全部楼层
大概如下,不过没有修改那个直径后面的位数,只改了坐标
第二,对于那些17.5的,暂时没有写成17.50,有待修改,很奇怪
(setq a 17.5)
(setq a (rtos a 2 2))按帮助应该是17.50的,不知道为什么在我机器上都是17.5的
[PHP](defun c:tjj()
  (setvar "osmode" 1)
  (command "ucs" "w")
  (setq txth (getreal "\n字高" ))
  (setq num (getint "\n小数位数"))
  (setq w (- x5 x4))
  (setq h txth)
  (setvar "osmode" 0)
  (setq i 1)
  (setq pt p3)
  (while (ssname ss 0)
     (setq m 0)
     (setq x 0)
       (repeat nn
          ;(setq xxxt (rtos xxx))
          (setq xxxt (rtos (sswr xxx num) 2 num))
          ;(setq yyyt (rtos yyy))
          (setq yyyt (rtos (sswr yyy num) 2 num))
            (if (= nnn 2)
               (progn
          (setq x (+ 1 x))
          (setq xt (itoa x))
          (command "line" (polar p8 (* 1.5 pi) h) (polar p11 (* 1.5 pi) h) "" )
          (setq m (+ 1 m))
     (setq i (+ i 1))
  (setvar "osmode" 7)
(princ)
(defun sswr (real num / real1)
(setq a (* real (expt 10 num)))
(setq real2 (- (quzheng (* real (expt 10 (1+ num)))) (* (quzheng (* real (expt 10 num))) 10)))
(if (> real2 4) (setq addnum 1) (setq addnum 0))
(setq real1 (/ (+ (atof (rtos (quzheng (* real (expt 10 num))))) addnum) (expt 10 num)))
real1
(defun quzheng(real1 / temp)
(setq temp (atoi (rtos real1)))
temp
)[/PHP]
发表于 2005-9-5 18:33:47 | 显示全部楼层
最初由 snoopychen 发布
[B]大概如下,不过没有修改那个直径后面的位数,只改了坐标
(setq a 17.5)
(setq a (rtos a 2 2))按帮助应该是17.50的,不知道为什么在我机器上都是17.5... [/B]
(setvar"DIMZIN"0)
 楼主| 发表于 2005-9-5 19:11:08 | 显示全部楼层
谢谢snoopychen 和xyp1964的帮助!
现在可以用了!但是注解里的不可以跟的一起改!
特别是有纯孔的,里面是5位!
请多多指教!谢谢!
发表于 2005-9-5 20:16:19 | 显示全部楼层
frank啊,其实原来的程序写的挺好的,不过你既然是这样要求,那就按照你的改一下吧
现在是写在圆心了,不如原来的好
第二,小数点对于半径和坐标都可以设置
原点位置可以自己指定
[PHP]
(defun c:tjj()
  (setvar "dimzin" 0)
  (setvar "osmode" 1)
  (command "ucs" "w")
  (setq num (getint "\n坐标小数位数"))
  (setq num1 (getint "\n圆半径小数位数"))
  ;(setq p4 (getpoint "\n 请输入图框左下角:"))
  ;(setq p5 (getpoint "\n 请输入图框右上角:"))
  (setq p000 (getpoint "\n座标原点位置"))
  (setq x1 (car p000) y1 (cadr p000))
  ;(setq w (- x5 x4))
  ;(setq h (* (/ w 280) 2))
  (setq h txth)
  (setvar "osmode" 0)
  (setq i 1)
  (setq pt p3)
     (setq m 0)
     (setq x 0)
       (repeat nn
            (if (= nnn 2)
               (progn
                 ;(setq p2 cen)
                 (setq dma (rtos (sswr (* 2 radma) num1) 2  num1) )
                 (setq dmi (rtos (sswr (* 2 radmi) num1) 2  num1) )
;                 (setq dmi (rtos (* 2 radmi)))
               ;(setq p2 cen)
                     ssstxt (strcat "-%%C" (rtos (sswr (* 2 rad) num1) 2 num1) "<THR>"))
          (setq x (+ 1 x))
          (setq xt (itoa x))
          (command "text" "ml" cen h 0 xtxt)
          (setq m (+ 1 m))
     (setq i (+ i 1))
  (setvar "osmode" 7)
(princ)
real1
temp
[/PHP]
 楼主| 发表于 2005-9-6 19:02:10 | 显示全部楼层
纯孔就是像螺丝头的让位孔!
snoopychen 这个LISP是用在机械设计里的!
注解
A:-2个3.000的通孔
B:-1个5.00000的通孔,8.00000的纯孔,深度是6.0000
C:-1个15.000的通孔
不过里面的文字是用代码的!
我是想注解里面的也可以选择小数点的位数!
还有代码不在圆的中间是在右下方?
请指教!谢谢!
发表于 2005-9-6 23:04:47 | 显示全部楼层
大概改完,见13楼,你的原点定法不对,重复定义会冲掉的
GMT+8, 2026-11-6 12:16 , Processed in 0.876792 second(s), 60 queries , Gzip On.
