查看: 1569|回复: 2
[LISP函数]:添加设置当前层
发表于 2005-9-8 09:54:21 | 显示全部楼层 |阅读模式
  1. ;;添加设置当前层
  2. (defun xd-addlayer (layname color / lay)
  3.   (if (not (setq elay (tblobjname "layer" layname))) ;no
  4.     (progn
  5.       (setq lay (vla-add (vla-get-layers (thisdrawing)) layname))
  6.       (if color
  7.         (vla-put-color lay color)
  8.       )
  9.     )
  10.     (if        (= (type color) 'INT)
  11.       (progn
  12.         (setq lst    (entget elay)
  13.               oldlst (assoc 62 lst)
  14.               col    (abs (cdr oldlst))
  15.         )
  16.         (if (/= col color)
  17.           (setq        lst (subst (cons 62 color)
  18.                            oldlst
  19.                            lst
  20.                     )
  21.           )
  22.           (entmod lst)
  23.         )
  24.       )
  25.     )
  26.   )
  27.   (setvar "clayer" layername)
  28. )
发表于 2005-9-13 02:39:30 | 显示全部楼层
[php]
;| 设置当前层颜色(无层自动建层)-----by 狂刀.
  功能: 创建/修改含颜色属性的层,并设为当前层.
 参数: lan = 层名.
     col = 颜色.
  实例: (xd-mklac "1" "3")
        (xd-mklac2 "1" "0")
        (xd-mklac2 "1" "2")
        (xd-mklac2 "1-1" "4")
(defun xd-mklac (lan col )
  (command ".layer" "n" lan "s" lan "c" col "" "")
[/php][php]
;;功能等同 xd-mklac
(defun xd-mklac2 ( lan col )
  (vla-put-color (vla-add (vla-get-layers
                            (vla-get-activedocument (vlax-get-acad-object))
                          lan)
    col)
  (setvar "CLAYER" lan)
[/php]
发表于 2005-9-13 09:58:17 | 显示全部楼层
我从来不设置层。
  1. 新生成实体后:
  2. ([URL=http://www.xdcad.net/forum/showthread.php?s=&threadid=452097][U][COLOR=red]xd-modent[/COLOR] [/U][/URL] (entlast)  8 "newlayer")  ;层会自动生成.
  3. ([URL=http://www.xdcad.net/forum/showthread.php?s=&threadid=452097][U][COLOR=red]xd-modent[/COLOR] [/U][/URL] (cdr(assoc -1(tblobjname "layer""newlayer"))) 62 "newcolor") ;如果有必要改颜色.
复制代码
GMT+8, 2026-11-22 10:30 , Processed in 0.364116 second(s), 12 queries , Gzip On, File On.
