查看: 1821|回复: 0
[ARX程序]:请看看我的代码!!
发表于 2002-4-27 11:38:46 | 显示全部楼层 |阅读模式
我想把AUTOCAD做成类VC窗口的窗口,但加载CAD退出!!请帮忙!看看我的代码!!
// 材料成型CAD项目管理.cpp : Initialization functions
#include "StdAfx.h"
#include "StdArx.h"
#include "resource.h"
#include <afxdllx.h>
#include "DockBar.h"
#include <migrtion.h>
#include <dbapserv.h>
#include <Afxext.h>
#include "ManProjectVw1.h"
#include "ManProjectVw2.h"
#include "ManProjectVw3.h"
#include "CJTabCtrlBar.h"
void CreateSampToolBar();
void DeleteSampToolBar();
void CreateLeftView();
//SampToolWnd*    gpWnd = NULL;
CDockViewBar*   gpBar;
CCJTabCtrlBar* m_wndWorkspace;
CImageList        m_ImageList;
CImageList  m_TabImages;
HINSTANCE _hdllInstance =NULL ;
// This command registers an ARX command.
void AddCommand(const char* cmdGroup, const char* cmdInt, const char* cmdLoc,
                                const int cmdFlags, const AcRxFunctionPtr cmdProc, const int idLocal = -1);
// NOTE: DO NOT edit the following lines.
//{{AFX_ARX_MSG
void InitApplication();
void UnloadApplication();
//}}AFX_ARX_MSG
//{{AFX_ARX_ADDIN_FUNCS
//}}AFX_ARX_ADDIN_FUNCS
// Define the sole extension module object.
AC_IMPLEMENT_EXTENSION_MODULE(CADDLL);
// Now you can use the CAcModuleRecourceOverride class in
// your application to switch to the correct resource instance.
// Please see the ObjectARX Documentation for more details
// DLL Entry Point
extern "C"
BOOL WINAPI DllMain(HINSTANCE hInstance, DWORD dwReason, LPVOID /*lpReserved*/)
        if (dwReason == DLL_PROCESS_ATTACH)
        _hdllInstance = hInstance;
                // Extension DLL one time initialization
                CADDLL.AttachInstance(hInstance);
                InitAcUiDLL();
                CreateLeftView();
        } else if (dwReason == DLL_PROCESS_DETACH) {
                // Terminate the library before destructors are called
                CADDLL.DetachInstance();
        return TRUE;    // ok
// ObjectARX EntryPoint
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* pkt)
        switch (msg) {
        case AcRx::kInitAppMsg:
                // Comment out the following line if your
                // application should be locked into memory
                acrxDynamicLinker->unlockApplication(pkt);
                acrxDynamicLinker->registerAppMDIAware(pkt);
                InitApplication();
                break;
        case AcRx::kUnloadAppMsg:
                break;
        return AcRx::kRetOK;
// Init this application. Register your
// commands, reactors...
        //{{AFX_ARX_INIT
        AddCommand("CADMFCTEST", "MANPROJECT", "MANPROJECT", ACRX_CMD_TRANSPARENT | ACRX_CMD_USEPICKSET, cadMfcTestManProject);
        //}}AFX_ARX_INIT
        // TODO: add your initialization functions
// Unload this application. Unregister all objects
// registered in InitApplication.
        //{{AFX_ARX_EXIT
        acedRegCmds->removeGroup("CADMFCTEST");
        //}}AFX_ARX_EXIT
        // TODO: clean up your application
// This functions registers an ARX command.
// It can be used to read the localized command name
// from a string table stored in the resources.
                                const int cmdFlags, const AcRxFunctionPtr cmdProc, const int idLocal)
        char cmdLocRes[65];
        // If idLocal is not -1, it's treated as an ID for
        // a string stored in the resources.
        if (idLocal != -1) {
                // Load strings from the string table and register the command.
                ::LoadString(_hdllInstance, idLocal, cmdLocRes, 64);
                acedRegCmds->addCommand(cmdGroup, cmdInt, cmdLocRes, cmdFlags, cmdProc);
        } else
                // idLocal is -1, so the 'hard coded'
                // localized function name is used.
                acedRegCmds->addCommand(cmdGroup, cmdInt, cmdLoc, cmdFlags, cmdProc);
        InitCommonControls();
        CMDIFrameWnd* pFrame=acedGetAcadFrame();
    AfxSetResourceHandle(_hdllInstance);
   // Create the image list to be used with the control bars.
        m_ImageList.Create(IDB_BITMAP2, 13, 1, RGB(0,255,0));
        // CG: The following block was inserted by the 'Dialog Bar' component
        m_wndWorkspace->SetBtnImageList (&m_ImageList);
        m_wndWorkspace->SetMenuID(IDR_POPUP);
        // Initialize dialog bar m_wndWorkspace
        if (!m_wndWorkspace->Create(pFrame, ID_LEFTVIEW,
        _T("Workspace"), CSize(220,200)))
                        TRACE0("Failed to create dialog bar m_wndWorkspace\n");
                // Add the views to the tab control.
                m_wndWorkspace->AddView(_T("Class"), RUNTIME_CLASS(CManProjectVw1));
                m_wndWorkspace->AddView(_T("Resource"), RUNTIME_CLASS(CManProjectVw2));
                m_wndWorkspace->AddView(_T("Files"),    RUNTIME_CLASS(CManProjectVw3));
                // Define the image list to use with the tab control
                m_TabImages.Create (IDB_BITMAP4, 16, 1, RGB(0,255,0));
                m_wndWorkspace->SetTabImageList(&m_TabImages);
            // allow bar to be resized when floating
            m_wndWorkspace->SetBarStyle(m_wndWorkspace->GetBarStyle() |
                    CBRS_TOOLTIPS | CBRS_FLYBY | CBRS_SIZE_DYNAMIC);
                m_wndWorkspace->EnableDocking(CBRS_ALIGN_ANY);
        //        EnableDocking(CBRS_ALIGN_ANY);
//                DockControlBar(&m_wndWorkspace, AFX_IDW_DOCKBAR_LEFT);
        gpBar = new CDockViewBar;
   // gpBar->SetBtnImageList (&m_ImageList);
//        gpBar->SetMenuID(IDR_POPUP);
        // Initialize dialog bar m_wndOutput
        if (!gpBar->Create(pFrame,_T("Output")))
                        TRACE0("Failed to create dialog bar m_wndOutput\n");
       gpBar->SetBarStyle(gpBar->GetBarStyle() |
             gpBar->EnableDocking(CBRS_ALIGN_ANY);
        pFrame->EnableDocking(CBRS_ALIGN_ANY);
        pFrame ->DockControlBar(gpBar, AFX_IDW_DOCKBAR_TOP);
            pFrame->ShowControlBar(gpBar, TRUE, TRUE);
        pFrame ->RecalcLayout();
// clean up
        if(m_wndWorkspace)
                delete m_wndWorkspace;
                m_wndWorkspace= NULL;
    if(gpBar)
                delete gpBar;
                gpBar = NULL;
        if(acedGetAcadFrame()->m_hWnd && acdbCurDwg())
                acedGetAcadFrame()->RecalcLayout();
GMT+8, 2026-11-22 11:01 , Processed in 0.262234 second(s), 10 queries , Gzip On, File On.
