查看: 1284|回复: 8
[讨论]:是群亚建筑软件的错吗?
发表于 2002-4-27 21:19:19 | 显示全部楼层 |阅读模式
我安装了群亚建筑软件后,刚开始运行很好,并且感觉很好用,但是前天我一用群亚建筑的菜单就死机!无奈我只能将CAD2002重装了一次,再次安装了群亚建筑软件,现在是好的!不知群亚建筑软件是否有BUG才导致我上次的死机!?
发表于 2002-4-27 22:49:39 | 显示全部楼层
我也同样的问题,要不是死机要不是菜单不见,不怎么稳定。
发表于 2002-4-28 01:09:26 | 显示全部楼层
会不会是R2002有不同的版本?
请问问其他人。
发表于 2002-4-28 02:08:33 | 显示全部楼层
我的就没有这个问题呀!
发表于 2002-4-28 02:56:19 | 显示全部楼层
不会死机啊。
不会死机啊。倒是自定义快节键时屏幕菜单会突然变大,不知你们会不会。
发表于 2002-4-28 10:57:34 | 显示全部楼层
不知你的CAD2002是运行在98还是2000下,CAD2002本来是只能在2000下运行的,后来被破解可以在98下运行,我在2000下2002一直没死过机。
但屏幕菜单经常在切换程序时突然变大,也许是Bug,前几天发贴问过,一直没回复。
发表于 2002-4-28 11:38:50 | 显示全部楼层
屏幕菜单的宽度好像可以在注册表中改的。
发表于 2002-4-28 20:07:54 | 显示全部楼层
屏幕菜单可以直接用鼠标控制(2002),不会麻烦,但终究是bug。
发表于 2002-4-28 21:45:37 | 显示全部楼层
我是说screen menu的设置的默认值的注册表中。
Type options on the command line.
In the Options dialog box, select the Profiles tab and then select the user profile you are currently using.
Select Export and then enter a file name and location for the file. Choose OK to export the file.
Using text editing software, open the file you exported in step 3.
Search for the following text: ScreenMenu. You should find three lines beginning with the text "ScreenMenu", similar to the following:
"ScreenMenu"=dword:00000001
"ScreenMenu.Style"=dword:00000000
"ScreenMenu.Position"="437 128 531 545"review background"=dword:00FFFFFF
Note: In your file, the values displayed after the equal sign may be different or some of these lines may be missing.
Delete all of the lines that include the ScreenMenu text and save your changes.
In AutoCAD, select Import on the Profiles tab and select the file you edited in step 6.
In the Import Profile dialog box, specify a different profile name than the one you are currently using.
Choose Apply & Close to import the new profile.
Select the new profile and then select Set Current to make the new profile current.
In the Options dialog box select the Display tab.
Select the Display Screen Menu check box and then choose Apply.
The screen menu will be docked to the right side of the application.
GMT+8, 2026-11-2 22:03 , Processed in 0.552046 second(s), 48 queries , Gzip On.
