查看: 1439|回复: 4
[求助]:一个很初级的问题,高手请进
发表于 2003-4-8 14:26:58 | 显示全部楼层 |阅读模式
这段代码是ACAD帮助文件中的(我略作了些修改),有个问题我不懂:变量pd是怎么赋值的?(单步运行中可知为半径+间距)我找不到赋值语句!
Const pi = 3.14159
Private sp(0 To 2) As Double
Private ep(0 To 2) As Double
Private hwidth As Double
Private trad As Double
Private tspac As Double
Private pangle As Double
Private plength As Double
Private totalwidth As Double
Private angp90 As Double
Private angm90 As Double
' 将角度从度转换为弧度
Function dtr(a As Double) As Double
    dtr = (a / 180) * pi
End Function
' 计算两点之间距离
Function distance(sp As Variant, ep As Variant) _
As Double
    Dim x As Double
    Dim y As Double
    Dim z As Double
    x = sp(0) - ep(0)
    y = sp(1) - ep(1)
    z = sp(2) - ep(2)
    distance = Sqr((Sqr((x ^ 2) + (y ^ 2)) ^ 2) + (z ^ 2))
End Function
' 获取花园小路的信息
Private Sub gpuser()
    Dim varRet As Variant
    varRet = ThisDrawing.Utility.GetPoint( _
     , "路的起点: ")
    sp(0) = varRet(0)
    sp(1) = varRet(1)
    sp(2) = varRet(2)
     , "路的端点: ")
    ep(0) = varRet(0)
    ep(1) = varRet(1)
    ep(2) = varRet(2)
    hwidth = ThisDrawing.Utility. _
     GetDistance(sp, "路的半宽: ")
    trad = ThisDrawing.Utility. _
     GetDistance(sp, "砖的半径: ")
    tspac = ThisDrawing.Utility. _
     GetDistance(sp, "砖之间的间距: ")
    pangle = ThisDrawing.Utility.AngleFromXAxis( _
     sp, ep)
    totalwidth = 2 * hwidth
    plength = distance(sp, ep)
    angp90 = pangle + dtr(90)
    angm90 = pangle - dtr(90)
End Sub
' 绘制路的轮廓
Private Sub drawout()
    Dim points(0 To 9) As Double
    Dim pline As AcadLWPolyline
    varRet = ThisDrawing.Utility.PolarPoint( _
        sp, angm90, hwidth)
    points(0) = varRet(0)
    points(1) = varRet(1)
    points(8) = varRet(0)
    points(9) = varRet(1)
        varRet, pangle, plength)
    points(2) = varRet(0)
    points(3) = varRet(1)
        varRet, angp90, totalwidth)
    points(4) = varRet(0)
    points(5) = varRet(1)
        varRet, pangle + dtr(180), plength)
    points(6) = varRet(0)
    points(7) = varRet(1)
    Set pline = ThisDrawing.ModelSpace. _
     AddLightWeightPolyline(points)
End Sub
' 按沿小路的给定距离放置一行砖
' 并且可能需要偏移
Private Sub drow(pd As Double, offset As Double)
    Dim pfirst(0 To 2) As Double
    Dim pctile(0 To 2) As Double
    Dim pltile(0 To 2) As Double
    Dim cir As AcadCircle
     sp, pangle, pd)
    pfirst(0) = varRet(0)
    pfirst(1) = varRet(1)
    pfirst(2) = varRet(2)
     pfirst, angp90, offset)
    pctile(0) = varRet(0)
    pctile(1) = varRet(1)
    pctile(2) = varRet(2)
    pltile(0) = pctile(0)
    pltile(1) = pctile(1)
    pltile(2) = pctile(2)
    Do While distance(pfirst, pltile) < (hwidth - trad)
        Set cir = ThisDrawing.ModelSpace.AddCircle( _
         pltile, trad)
         pltile, angp90, (tspac + trad + trad))
        pltile(0) = varRet(0)
        pltile(1) = varRet(1)
        pltile(2) = varRet(2)
    Loop
     pctile, angm90, tspac + trad + trad)
         pltile, trad)
         pltile, angm90, (tspac + trad + trad))
    Loop
End Sub
' 绘制每行砖
Private Sub drawtiles()
    Dim pdist As Double
    Dim offset As Double
    pdist = trad + tspac
    offset = 0
    Do While pdist <= (plength - trad)
        drow pdist, offset
        pdist = pdist + ((tspac + trad + trad) * Sin(dtr(60)))
        If offset = 0 Then
            offset = (tspac + trad + trad) * Cos(dtr(60))
        Else
            offset = 0
        End If
    Loop
End Sub
' 执行命令,调用各个函数
Sub gardenpath()
    Dim sblip As Variant
    Dim scmde As Variant
    gpuser
    sblip = ThisDrawing.GetVariable("blipmode")
    scmde = ThisDrawing.GetVariable("cmdecho")
    ThisDrawing.SetVariable "blipmode", 0
    ThisDrawing.SetVariable "cmdecho", 0
    drawout
    drawtiles
    ThisDrawing.SetVariable "blipmode", sblip
    ThisDrawing.SetVariable "cmdecho", scmde
    ZoomExtents
End Sub
已领礼包: 181个
发表于 2003-4-8 19:19:56 | 显示全部楼层
在下面的过程中pdist的赋值。
  1.   [FONT=courier new]
  2. ' 绘制每行砖
  3. Private Sub drawtiles()
  4. Dim pdist As Double
  5. Dim offset As Double
  6. pdist = trad + tspac
  7. offset = 0
  8. Do While pdist <= (plength - trad)
  9. drow pdist, offset
  10. pdist = pdist + ((tspac + trad + trad) * Sin(dtr(60)))
  11. If offset = 0 Then
  12. offset = (tspac + trad + trad) * Cos(dtr(60))
  13. Else
  14. offset = 0
  15. End If
  16. Loop
  17. End Sub
  18.   [/FONT]
首先,pdist = trad(砖的半径) + tspac(砖之间的间距)[/COLOR] 。接着,在Dp...Loop语句中,根据条件pdist <= (plength - trad)[/COLOR],如果成立时,不断的变更其值,再调用过程drow绘制砖。
 楼主| 发表于 2003-4-8 19:49:00 | 显示全部楼层
斑竹说的我知道,可我说的是pd,不是pdist啊!难道pd是pdist的缩写?请斑竹指点!
已领礼包: 181个
发表于 2003-4-8 20:05:30 | 显示全部楼层
不是缩写,这涉及到VB的用法。Private Sub drow(pd As Double, offset As Double) ,在这一句中,其实它是一个自定义过程的开始,pd代表传给过程的一个形参,本身没有实际意义。只有到了调用这个过程,指定它的值时才有真正的数据值。而drow pdist, offset这一句正是调用这个过程,将pdist作为实参传到drow过程。到了drow过程时,pd对应的就被赋予了pdist的值。
 楼主| 发表于 2003-4-8 20:15:15 | 显示全部楼层
懂了!太好了!谢谢!谢谢efan2000斑竹!!以后要好好好向efan2000斑竹学习!!!
GMT+8, 2026-11-2 17:04 , Processed in 0.767237 second(s), 40 queries , Gzip On.
