- UID
- 14
- 积分
- 8265
- 精华
- 贡献
- 威望
- 活跃度
- D豆
- 在线时间
- 小时
- 注册时间
- 2002-1-4
- 最后登录
- 1970-1-1
- ;;; TYPELIB.LSP ;
- ;;; Copyright 1987, 1988, 1990, 1992, 1994, 1996, 1997, 1998, 1999 ;
- ;;; by Autodesk, Inc. All Rights Reserved. ;
- ;;; You are hereby granted permission to use, copy and modify this ;
- ;;; software without charge, provided you do so exclusively for ;
- ;;; your own use or for use by others in your organization in the ;
- ;;; performance of their normal duties, and provided further that ;
- ;;; the above copyright notice appears in all copies and both that ;
- ;;; copyright notice and the limited warranty and restricted rights ;
- ;;; notice below appear in all supporting documentation. ;
- ;;; Incorporation of any part of this software into other software, ;
- ;;; except when such incorporation is exclusively for your own use ;
- ;;; or for use by others in your organization in the performance of ;
- ;;; their normal duties, is prohibited without the prior written ;
- ;;; consent of Autodesk, Inc. ;
- ;;; Copying, modification and distribution of this software or any ;
- ;;; part thereof in any form except as expressly provided herein is ;
- ;;; prohibited without the prior written consent of Autodesk, Inc. ;
- ;;; AUTODESK PROVIDES THIS SOFTWARE "AS IS" AND WITH ALL FAULTS. ;
- ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF ;
- ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, ;
- ;;; INC. DOES NOT WARRANT THAT THE OPERATION OF THE SOFTWARE ;
- ;;; WILL BE UNINTERRUPTED OR ERROR FREE. ;
- ;;; Restricted Rights for US Government Users. This software ;
- ;;; and Documentation are provided with RESTRICTED RIGHTS for US ;
- ;;; US Government users. Use, duplication, or disclosure by the ;
- ;;; Government is subject to restrictions as set forth in FAR ;
- ;;; 12.212 (Commercial Computer Software-Restricted Rights) and ;
- ;;; DFAR 227.7202 (Rights in Technical Data and Computer Software), ;
- ;;; as applicable. Manufacturer is Autodesk, Inc., 111 McInnis ;
- ;;; Parkway, San Rafael, California 94903. ;
- ;;; This file shows how to import type library files and how to use ;
- ;;; them. ;
- ;;; First of all we have to init the ActiveX interface. ;
- (vl-load-com)
- ;;; Import the Microsoft WinWord type library. You have to replace ;
- ;;; the path with the path to your WinWord type library file. ;
- ;;; Import the type library only if it is not already loaded. ;
- (if (equal nil mswc-wd100Words) ; check for a WinWord constant
- (vlax-import-type-library
- :tlb-filename "c:/program files/Microsoft Office/msword8.olb"
- :methods-prefix "mswm-"
- :properties-prefix "mswp-"
- :constants-prefix "mswc-"
- ) ;_ end of vlax-import-type-library
- ) ;_ end of if
- ;;; After importing the type library file you can use the Apropos ;
- ;;; Window to see the added VisualLisp functions. ;
- ;;; Go to the "View" menu, select "Apropos Windows..." and enter ;
- ;;; "mswm-" in the edit box to get a list of all WinWord methods. ;
- ;;; For ActiveX functions, we need to define a global variable which ;
- ;;; "points" to the Model Space portion of the active drawing. This ;
- ;;; variable, named *ModelSpace* will be created at load time. ;
- (setq *ModelSpace*
- (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object)))
- ) ;_ end of setq
- ;;; "points" to the AutoCAD application object. This variable, named ;
- ;;; *AcadApp* will be created at load time. ;
- (setq *AcadApp*
- (vlax-get-acad-object)
- ) ;_ end of setq
- ;;; This is the main function. It will iterate the model space and ;
- ;;; collect all Text entities. Then it gets the text strings and adds ;
- ;;; them to a newly created Microsoft WinWord document. ;
- (defun c:ExtractText ( / msw docs doc ent pgs pg range
- text varTextpos arrayTextpos textinfo)
- ; Get the Microsoft WinWord application object
- (setq msw (vlax-get-object "Word.Application.8"))
- (if (equal nil msw)
- (progn
- ; WinWord is not running. Start it.
- (setq msw (vlax-create-object "Word.Application.8"))
- (vla-put-visible msw 1)
- (if (/= nil msw)
- (progn
- ;; Get the WinWord's document collection object.
- ;; The Application object of WinWord is accessed by the
- ;; vla-get-xxx functions. For some ActiveX properties and methods
- ;; there is no generated VisualLisp function. In this case you have
- ;; to use the vlax-get-property / vlax-put-property and
- ;; vlax-invoke-method functions.
- ;; Example: For the CommandBars property of the WinWord application
- ;; object there is no VisualLisp function, but you can get this
- ;; object the following way:
- ;; (setq ComBars (vlax-get-property msw "CommandBars"))
- (setq docs (vla-get-documents msw))
- ; Add a new document
- (setq doc (mswm-add docs))
- ; Get the paragraphs of the document (to do some formatting)
- (setq pgs (mswp-get-paragraphs doc))
- ; Now iterate the AutoCAD model space and export
- ; every text entity to WinWord.
- (vlax-for ent *ModelSpace*
- (if (equal (vla-get-ObjectName ent) "AcDbText")
- (progn
- ; Get some information from the text entity
- (setq text (vla-get-TextString ent)
- textpos (vla-get-InsertionPoint ent)
- arrayTextpos (vlax-variant-value textpos)
- textinfo (strcat
- (rtos (vlax-safearray-get-element arrayTextpos 0) 2 2)
- (rtos (vlax-safearray-get-element arrayTextpos 1) 2 2)
- (rtos (vlax-safearray-get-element arrayTextpos 2) 2 2)
- ) ;_ end of setq
- ; Print some info (with formatting)
- ; 1) Get the last paragraph
- (setq pg (mswp-get-last pgs))
- ; 2) Get a range object
- (setq range (mswp-get-range pg))
- ; 3) Do some formatting
- (mswp-put-bold range 1)
- (mswp-put-underline range mswc-wdUnderlineSingle)
- ; 4) Show the info text
- (mswm-InsertAfter range (strcat "AcDbText at position " textinfo "\n"))
- ; Now show the text string (from the ACAD text entity)
- (mswp-put-bold range 0)
- (mswp-put-underline range mswc-wdUnderlineNone)
- (mswm-InsertAfter range (strcat text "\n\n"))
- ) ;_ end of progn
- ) ;_ end of if AcDbText
- ) ;_ end of vlax-for
- ) ;_ end of progn
- (princ "\nNo Microsoft WinWord found.\n")
- ) ;_ end of if (/= nil msw)
- (princ)
- ;;; Display a message to let the user know the command name
- (princ "\nType ExtractText to export all text entities to Microsoft WinWord.\n")
- (princ)
