查看: 3804|回复: 7
[飞鸟集] [分享]:如何用lisp列出层的详细信息?
已领礼包: 8125个
发表于 2007-5-17 20:26:47 | 显示全部楼层 |阅读模式
这是根据 《The Visual Lisp Devepolers Bible-2003 Edition》的代码段改写的关于层的详细列表的lisp程序。以供大家参考。
最终的结果以网页形式列出。
[pcode=lisp,true]
(prompt "Please run with Command: \"Dumplayers\"\n")
(defun C:DumpLayers ( / *APP doc dwg layers name col ltp lwt pst onoff
                        frz lock plotTb dat path olist outfile output)
  (vl-load-com)
  (setq *APP   (vlax-get-acad-object)
        doc    (vla-get-activedocument *APP)
        dwg    (vla-get-name doc)
        path   (vla-get-path doc)
        layers (vla-get-layers doc)
        laylst (tbl_NL "LAYER")                            ; have been sorted
  ;;(vlax-for each layers                                  ; have been modified
  (foreach each laylst
    (setq name  (vla-get-name each)
          ;;col   (itoa (dsx-get-color each))              ; see Chapter 25!
          col   (get-color each)                           ; have been modified
          ltp   (vla-get-linetype each)
          lwt   (itoa (vla-get-lineweight each))
          lwt   (if (= lwt "-3") "Defualt" lwt)            ; have been modified
          pst   (vla-get-plotstylename each)
          onoff (if (= :vlax-true (vla-get-layeron each))
                  "ON"
                  "OFF"
          frz   (if (= :vlax-true (vla-get-freeze each))
                  "FROZEN"
                  "THAWED"
          lock  (if (= :vlax-true (vla-get-lock each))     ; have been modified
                  "LOCKED"
                  "UNLOCKED"
          pltTb (if (= :vlax-true (vla-get-plottable each)); have been modified
                  "PRINTABLE"
                  "UNPRINTABLE"
          dat   (list name col ltp lwt onoff frz lock pst pltTb)
          olist (cons dat olist)
  ); vlax-for
  (setq olist (reverse olist))
  (setq olist
    (cons
      (list  "Name" "Color" "Linetype" "Lineweight" "ON" "Freeze" "Lock" "PrintstyleName" "Printalbe")
      olist
  (vlax-release-object layers)
  (vlax-release-object doc)
  (vlax-release-object *APP)
  (cond
    ( olist
      (setq outfile (strcat (vl-filename-base dwg) ".htm"))
      (setq outfile (strcat path "\\" outfile))
      (cond
        ( (setq output (open outfile "w"))
          (write-line "<html>" output)
          (write-line "<head><title>" output)
          (write-line (strcat "Layer Dump: " dwg) output)
          (write-line "</title></head><body>" output)
          (write-line (strcat "<b>Drawing: " path "\\" dwg "</b><br>") output)
          (write-line "<table border=1>" output)
          (foreach layset olist
            (write-line "<tr>" output)
            (foreach prop layset
              (write-line (strcat "<td>" prop "</td>") output) )
              (write-line "</tr>" output)
            ); foreach layer set
          (write-line "</table></body></html>" output)
          (close output)
          (setq output nil)
          (princ "\nReport finished! Opening in browser...")
          (vl-cmdf "_.browser" outfile)
        ( T (princ "\nUnable to open output file.") )
    ( T (princ "\nUnable to get layer table information.") )
  (princ)
;;;get layer color
(defun dsx-get-color (obj / try)                ;???
  (cond
    ( (and
        (vlax-property-available-p obj 'color)
        (not
          (vl-catch-all-error-p
            (setq try
              (vl-catch-all-apply 'vla-get-color (list obj ))
      try
;;;my get layer color
(defun get-color (obj / CADver colobj method R G B color)
  (setq CADver (getvar "ACADVER"))
  (if (> (atoi (substr CADver 1 2)) 15)         ;if version higher than R15
    (progn
      (setq colobj (vla-get-truecolor obj))     ;get layer truecolor
      (setq method (vla-get-colorMethod colobj));get colorMethod
      (if (= method 194)
        (setq R (itoa (vla-get-red colobj))
              G (itoa (vla-get-green colobj))
              B (itoa (vla-get-blue colobj))
              color (strcat  R "," G "," B)     ;get truecolor RGB
        (itoa (vla-get-color obj))              ;get layer index color
;;; get the name list of layer
(defun tblname (tblsym / name namlst)
  (setq namlst nil)
  (setq namlst (cons (cdr (assoc 2 (tblnext tblsym T))) namlst))
  (while (setq name (cdr (assoc 2 (tblnext tblsym))))
    (setq namlst (cons name namlst))
  (setq namlst (acad_strlsort namlst))
  (mapcar '(lambda (x) (vla-item layers x)) namlst)
;;;tabLe name List
(DEFUN tbL_nL (tn / td L)
  (whiLe (setq td (tbLnext tn (not td)))
    (setq L (cons (cdr (assoc 2 td)) L))
  (mapcar '(lambda (x) (vla-item layers x))(acad_strlsort L))
)[/pcode]
支持中文名。
评分
参与人数 1D豆 +5 收起 理由
xdcad9819 + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
本帖被以下淘专辑推荐:
发表于 2007-5-18 09:32:04 | 显示全部楼层
中文层名不支持
发表于 2007-5-19 07:51:45 | 显示全部楼层
我这边支持啊啊。
发表于 2013-7-10 16:57:31 | 显示全部楼层
好程序,高飞鸟版主真强大
纯VLISP版查看图层信息
已领礼包: 2965个
财富等级: 家财万贯
发表于 2013-7-10 23:41:07 | 显示全部楼层
函数列表控制在哪?
已领礼包: 2965个
财富等级: 家财万贯
发表于 2013-7-10 23:42:24 | 显示全部楼层
刚才发错了,怎样删除?
发表于 2013-7-15 20:17:45 | 显示全部楼层
报个名来学习的。
发表于 2013-8-17 13:38:08 | 显示全部楼层
非常不错!
GMT+8, 2026-11-1 09:42 , Processed in 0.500105 second(s), 49 queries , Gzip On.
