查看: 1829|回复: 2
[VLISP函数]:获得包含点表的凸包点表
发表于 2005-9-28 09:39:30 | 显示全部楼层 |阅读模式
  1. ;;from [email]wkai@xdcad.net[/email]
  2. ;;20050928
  3. ;;Graham扫描法
  4. ;;参数lst:坐标点表
  5. ;;返回值:凸包点表(逆时针)
  6. (defun XD_convex_hull (lst / re tblst AN BG RESULT)
  7.   ;;按与pt的角度对点表排序
  8.   (defun XD_convex_hull_sort_an(pt an ls / re)
  9.   (setq re (mapcar '(lambda(x) (list (rem (+ (* 2 pi)(- (angle pt x) an))(* 2 pi))(distance pt x) x)) ls))
  10.     (setq re ([URL=http://www.xdcad.net/forum/showthread.php?s=&threadid=465887][U][COLOR=red]XDL-SORT[/COLOR][/U][/URL] re '((0 <)(1 >))))
  11.   (last(car re));;取与pt的角度与an差最小的距离最远的点
  12.   )
  13.   ;;
  14.   (setq lst ([URL=http://www.xdcad.net/forum/showthread.php?s=&threadid=451886][U][COLOR=red]xd-remove-dups[/COLOR][/U][/URL] lst))
  15.   (setq lst ([URL=http://www.xdcad.net/forum/showthread.php?s=&threadid=465887][U][COLOR=red]XDL-SORT[/COLOR][/U][/URL] lst '((0 <)(1 <))));;按XY增排序
  16.   (setq        bg (car lst)
  17.         an (/ pi -2)
  18.   )
  19.   (setq tblst (list bg))
  20.   (while
  21.     (and (> (length lst) 2)
  22.          (not (and (> (length tblst) 1) (= (car tblst) (last tblst)))
  23.          )
  24.     )
  25.      (setq result (XD_convex_hull_sort_an (car tblst) an (vl-remove (car tblst) lst)))
  26.      (setq an (angle (car tblst) result))
  27.      (setq tblst (cons result tblst))
  28.   )
  29.   tblst
  30. )
 楼主| 发表于 2005-9-28 09:45:12 | 显示全部楼层
测试:
  1. (defun c:tt(/ lst re tblst ss n)
  2.   ;;
  3.   (defun ss_for (item ss fun / cn)
  4.   (repeat (setq cn (sslength ss))
  5.     (set item (ssname ss (setq cn (1- cn))))
  6.     (eval fun)
  7.     )
  8.   )
  9.   ;;
  10.   (command "undo" "be")
  11.   (setq ss (ssget '((0 . "LINE"))))
  12.   (ss_for 'n ss
  13.           '(setq lst (append lst
  14.                              (list (cdr (assoc 10 (entget n)))
  15.                                    (cdr (assoc 11 (entget n)))
  16.                              )
  17.                      ))
  18.   )
  19.   (setq tblst (XD_convex_hull lst))
  20.   (command "._pline" )
  21.   (foreach n tblst
  22.     (command "non" n)
  23.     )
  24.   (command)
  25.   (command "undo" "e")
  26.   (print tblst)
  27.   (princ)
  28.   )
发表于 2017-12-29 11:22:38 | 显示全部楼层
XD-REMOVE-DUPS 在哪呢
GMT+8, 2026-11-22 10:43 , Processed in 0.556381 second(s), 14 queries , Gzip On, File On.
