查看: 1371|回复: 2
[LISP程序]:消除点表重复项
发表于 2005-10-10 11:59:27 | 显示全部楼层 |阅读模式
  1. ;;;|消除点表重复项
  2. (defun rem-ptlst (a / ex y)
  3.   (setq        ex (vl-remove-if
  4.              '(lambda (y)
  5.                 (and (equal (car y) (caar a) 1e-4)
  6.                      (equal (cadr y) (cadar a) 1e-4)
  7.                 )
  8.               )
  9.              a
  10.            )
  11.   )
  12.   (if (car a)
  13.     (cons (car a) (rem-ptlst ex))
  14.   )
  15. )
已领礼包: 593个
发表于 2005-10-10 22:53:48 | 显示全部楼层
  1. (defun xdl-pts-removedups (pts / pl)
  2.   (while pts
  3.     (setq p   (car pts)
  4.           pts (cdr pts)
  5.           pts (vl-remove-if '(lambda (x) (equal x p 1e-10)) pts)
  6.           pl (cons p pl)
  7.     )
  8.   )
  9.   (reverse pl)
  10. )
已领礼包: 593个
发表于 2005-10-12 00:28:37 | 显示全部楼层
补充一点,Lisp中无序的点表是没有什么价值的,会大大降低程序运行效率。
GMT+8, 2026-11-3 10:46 , Processed in 0.415838 second(s), 34 queries , Gzip On.
