查看: 875|回复: 0
[求助] [求助]:如何插入数字序号时候选择旋转
发表于 2005-10-12 10:15:56 | 显示全部楼层 |阅读模式
eachy斑竹请进,这是一个双行数字序号的程序
能不能加个功能,就是能不能插入的时候可以选择是否旋转
(vl-load-com)
(setq *ACADDOC* (vla-get-activedocument (vlax-get-acad-object)))
(defun SL-NUM2CHAR        (INT / STR RES CHAR MBR)
  (while (/= (/ INT 26) 0)
        (setq RES (rem INT 26)
                  INT (/ INT 26))
        (if        (= RES 0)
          (setq        RES        26
                        INT        (1- INT)))
        (setq CHAR (cons RES CHAR)))
  (if (/= INT 0)
        (setq CHAR (reverse (cons INT CHAR))))
  (setq STR NIL)
  (foreach MBR CHAR (setq STR (cons (+ MBR 64) STR)))
  (setq STR (vl-list->string STR)))
(defun SL-CHAR2NUM        (STR / I INT)
  (setq        I        0
                STR        (reverse (vl-string->list (strcase STR)))
                INT        0)
  (while (nth I STR)
        (setq INT (+ INT (* (- (nth I STR) 64) (expt 26 I)))
                  I          (1+ I)))
  (abs INT))
(defun TNJ-DCL-ON2        (/ ON)
  (setq *TNJ-ON2 (get_tile "DCL_ON2")
   ON (- 1 (atoi *TNJ-ON2)))
  (mode_tile "DCL_PF2" ON)
  (mode_tile "DCL_SN2" ON)
  (mode_tile "DCL_AN2" ON)
  (mode_tile "DCL_SF2" ON)
  (mode_tile "DCL_LM2" ON)
  (mode_tile "DCL_ON3" ON)
  (TNJ-DCL-ON3)
  (if (= ON 1)
        (progn (mode_tile "DCL_PF3" 1)
                   (mode_tile "DCL_SN3" 1)
                   (mode_tile "DCL_AN3" 1)
                   (mode_tile "DCL_SF3" 1)
                   (mode_tile "DCL_LM3" 1)))
  (TNJ-DCL-UP))
(defun TNJ-DCL-ON3        (/ ON)
  (setq *TNJ-ON3 (get_tile "DCL_ON3")
                ON (- 1 (atoi *TNJ-ON3)))
  (mode_tile "DCL_PF3" ON)
  (mode_tile "DCL_SN3" ON)
  (mode_tile "DCL_AN3" ON)
  (mode_tile "DCL_SF3" ON)
  (mode_tile "DCL_LM3" ON)
  (TNJ-DCL-UP))
(defun TNJ-DCL-UP  (/ TEXT1 TEXT2)
  (TNJ-GETDATA)
  (if (= *TNJ-LM1 "1")
        (setq TEXT1 (SL-NUM2CHAR *TNJ-NUM1))
        (setq TEXT1 (itoa *TNJ-NUM1)))
  (setq TEXT1 (strcat *TNJ-PRE1 TEXT1 *TNJ-SUF1))
  (if (= *TNJ-ON2 "1")
        (if        (= *TNJ-LM2 "1")
          (setq TEXT2 (strcat *TNJ-PRE2 (SL-NUM2CHAR *TNJ-NUM2) *TNJ-SUF2))
          (setq TEXT2 (strcat *TNJ-PRE2 (itoa *TNJ-NUM2) *TNJ-SUF2))))
  (if (= *TNJ-ON2 *TNJ-ON3 "1")
        (if        (= *TNJ-LM3 "1")
          (setq TEXT2 (strcat TEXT2 *TNJ-PRE3 (SL-NUM2CHAR *TNJ-NUM3) *TNJ-SUF3))
          (setq TEXT2 (strcat TEXT2 *TNJ-PRE3 (itoa *TNJ-NUM3) *TNJ-SUF3))))
  (setq text1 (strcat "格式预览 第一行: " TEXT1))
  (IF (= (type TEXT2) 'STR)(SETQ TEXT1 (STRCAT TEXT1  "  第二行: "  TEXT2)))
  (set_tile "DCL_PREVIEW"  TEXT1))
(defun TNJ-DATANUM        ()
  (if (/= (type *TNJ-NUM1) 'INT)
        (setq *TNJ-NUM1 1))
  (if (/= (type *TNJ-NUM1+) 'INT)
        (setq *TNJ-NUM1+ 1))
  (if (/= (type *TNJ-NUM2) 'INT)
        (setq *TNJ-NUM2 1))
  (if (/= (type *TNJ-NUM2+) 'INT)
        (setq *TNJ-NUM2+ 1))
  (if (/= (type *TNJ-NUM3) 'INT)
        (setq *TNJ-NUM3 1))
  (if (/= (type *TNJ-NUM3+) 'INT)
        (setq *TNJ-NUM3+ 1))
  (if (/= (type *TNJ-PRE1) 'STR)
        (setq *TNJ-PRE1 ""))
  (if (/= (type *TNJ-PRE2) 'STR)
        (setq *TNJ-PRE2 ""))
  (if (/= (type *TNJ-PRE3) 'STR)
        (setq *TNJ-PRE3 ""))
  (if (/= (type *TNJ-SUF1) 'STR)
        (setq *TNJ-SUF1 ""))
  (if (/= (type *TNJ-SUF2) 'STR)
        (setq *TNJ-SUF2 ""))
  (if (/= (type *TNJ-SUF3) 'STR)
        (setq *TNJ-SUF3 ""))
  (if (/= (type *TNJ-TH) 'REAL)
        (setq *TNJ-TH 5)))
(defun C:TNJ  ()
  (setvar "CMDECHO" 0)
  (prompt "自动文字编号\n")
  (command ".UNDO" "BE")
  (setq        *TNJ-DCL-ID
                 (load_dialog "TextNumJ.DCL")
                *MARK-LIST NIL)
  (TNJ-DATANUM)
  (TNJ-DIALOG)
  (princ))
(defun TNJ-DIALOG  (/ DCL_ACT)
  (new_dialog "TNJDCL" *TNJ-DCL-ID)
        (progn (set_tile "DCL_LM1" "1") (set_tile "DCL_SN1" (SL-NUM2CHAR *TNJ-NUM1)))
        (progn (set_tile "DCL_LM1" "0") (set_tile "DCL_SN1" (itoa *TNJ-NUM1))))
  (set_tile "DCL_AN1" (itoa *TNJ-NUM1+))
        (progn (set_tile "DCL_ON2" "1")
                          (mode_tile "DCL_PF2" 0)
                   (mode_tile "DCL_SN2" 0)
                   (mode_tile "DCL_AN2" 0)
                   (mode_tile "DCL_SF2" 0)
                   (mode_tile "DCL_LM2" 0)(mode_tile "DCL_ON3" 0))
        (progn (set_tile "DCL_ON2" "0")
          (mode_tile "DCL_PF2" 1)
                   (mode_tile "DCL_SN2" 1)
                   (mode_tile "DCL_AN2" 1)
                   (mode_tile "DCL_SF2" 1)
                   (mode_tile "DCL_LM2" 1)(mode_tile "DCL_ON3" 1)))
        (progn (set_tile "DCL_LM2" "1") (set_tile "DCL_SN2" (SL-NUM2CHAR *TNJ-NUM2)))
        (progn (set_tile "DCL_LM2" "0") (set_tile "DCL_SN2" (itoa *TNJ-NUM2))))
        (progn (set_tile "DCL_ON3" "1")(mode_tile "DCL_PF3" 0)
                   (mode_tile "DCL_SN3" 0)
                   (mode_tile "DCL_AN3" 0)
                   (mode_tile "DCL_SF3" 0)
                   (mode_tile "DCL_LM3" 0))
        (progn (set_tile "DCL_ON3" "0")(mode_tile "DCL_PF3" 1)
        (progn (set_tile "DCL_LM3" "1") (set_tile "DCL_SN3" (SL-NUM2CHAR *TNJ-NUM3)))
        (progn (set_tile "DCL_LM3" "0") (set_tile "DCL_SN3" (itoa *TNJ-NUM3))))
  (set_tile "DCL_AN2" (itoa *TNJ-NUM2+))
  (set_tile "DCL_AN3" (itoa *TNJ-NUM3+))
  (set_tile "DCL_PF1" *TNJ-PRE1)
  (set_tile "DCL_PF2" *TNJ-PRE2)(set_tile "DCL_PF3" *TNJ-PRE3)
  (set_tile "DCL_SF1" *TNJ-SUF1)
  (set_tile "DCL_SF2" *TNJ-SUF2)
  (set_tile "DCL_SF3" *TNJ-SUF3)
  (set_tile "DCL_TH" (rtos *TNJ-TH 2 2))
  (TNJ-DCL-UP)
  (action_tile "accept" "(TNJ-GETDATA)(done_dialog 1)")
  (setq DCL_ACT (start_dialog))
  (cond ((= DCL_ACT 1) (TNJ-DATANUM) (TNJ-MARK))))
(defun TNJ-GETDATA        ()
  (setq        *TNJ-PRE1   (get_tile "DCL_PF1")
                *TNJ-NUM1  (get_tile "DCL_SN1")
                *TNJ-NUM1+ (atoi (get_tile "DCL_AN1"))
                *TNJ-SUF1  (get_tile "DCL_SF1")
                *TNJ-LM1   (get_tile "DCL_LM1")
                *TNJ-TH           (atof (get_tile "DCL_TH")))
        (setq *TNJ-PRE2         (get_tile "DCL_PF2")
                  *TNJ-NUM2         (get_tile "DCL_SN2")
                  *TNJ-NUM2+ (atoi (get_tile "DCL_AN2"))
                  *TNJ-SUF2         (get_tile "DCL_SF2")
                  *TNJ-LM2         (get_tile "DCL_LM2")))
        (setq *TNJ-PRE3         (get_tile "DCL_PF3")
                  *TNJ-NUM3         (get_tile "DCL_SN3")
                  *TNJ-NUM3+ (atoi (get_tile "DCL_AN3"))
                  *TNJ-SUF3         (get_tile "DCL_SF3")
                  *TNJ-LM3         (get_tile "DCL_LM3")))
  (if (= (atoi *TNJ-NUM1) 0)
        (setq *TNJ-NUM1 (SL-CHAR2NUM *TNJ-NUM1))
        (setq *TNJ-NUM1 (atoi *TNJ-NUM1)))
        (if        (= (atoi *TNJ-NUM2) 0)
          (setq *TNJ-NUM2 (SL-CHAR2NUM *TNJ-NUM2))
          (setq *TNJ-NUM2 (atoi *TNJ-NUM2))))
        (if        (= (atoi *TNJ-NUM3) 0)
          (setq *TNJ-NUM3 (SL-CHAR2NUM *TNJ-NUM3))
          (setq *TNJ-NUM3 (atoi *TNJ-NUM3)))))
(defun TNJ-MARK         (/ SPACE PT1 TEXT1 NEWTEXT1 PT2 TEXT2 NEWTEXT2)
  (if (= "Model" (getvar "CTAB"))
        (setq SPACE (vla-get-modelspace *ACADDOC*))
        (setq SPACE (vla-get-paperspace *ACADDOC*)))
  (while (setq PT1 (getpoint "指定编号位置: "))
        (setq PT2 (trans (polar PT1 (* pi 1.5) (* 1.25 *TNJ-TH)) 1 0))
        (setq PT1 (trans PT1 1 0))
        (setq NEWTEXT1          (vla-addtext SPACE TEXT1 (vlax-3d-point PT1) 1)
                  *MARK-LIST1 (append *MARK-LIST1 (list NEWTEXT1)))
        (vla-put-height NEWTEXT1 *TNJ-TH)
          (progn (setq NEWTEXT2           (vla-addtext SPACE TEXT2 (vlax-3d-point PT2) 1)
                                   *MARK-LIST2 (append *MARK-LIST2 (list NEWTEXT2)))
                         (vla-put-height NEWTEXT2 *TNJ-TH)))
        (setq *TNJ-NUM1 (+ *TNJ-NUM1 *TNJ-NUM1+))
          (setq *TNJ-NUM2 (+ *TNJ-NUM2 *TNJ-NUM2+)))
          (setq *TNJ-NUM3 (+ *TNJ-NUM3 *TNJ-NUM3+))))
  (TNJ-OP))
(defun TNJ-OP  (/ KEY END)
  (initget "c s u q")
  (setq KEY (getkword "\n输入选项 [继续(C)/设置(S)/取消末项(U)/退出(Q)]<退出>:"))
  (cond        ((= KEY "c") (TNJ-MARK))
                ((= KEY "s") (TNJ-DIALOG))
                ((= KEY "u")
                 (if (setq END (last *MARK-LIST1))
                   (progn (vla-delete END)
                                  (setq        *MARK-LIST1        (vl-remove END *MARK-LIST1)
                                                *TNJ-NUM1        (- *TNJ-NUM1 *TNJ-NUM1+))
                                        (setq *TNJ-NUM2 (- *TNJ-NUM2 *TNJ-NUM2+)))
                                        (setq *TNJ-NUM3 (- *TNJ-NUM3 *TNJ-NUM3+))))
                   (alert "已经没有我写的了!别让我擦了!!"))
                 (if (and (= *TNJ-ON2 *TNJ-ON3 "1")(setq END (last *MARK-LIST2)))
                   (progn (vla-delete END) (setq *MARK-LIST2 (vl-remove END *MARK-LIST2))))
                 (TNJ-OP))
                (t (unload_dialog *TNJ-DCL-ID) (command ".UNDO" "E"))))
(PRINC "双行文字编号---TNJ")(PRINC)
DCL
TNJDCL :dialog{label = "文字编号  ";
        :row{
            :boxed_column{label="第一行编号";
                    spacer_1;
                    :edit_box {key="DCL_PF1";label="前缀";action="(TNJ-DCL-UP)";}
                           :edit_box {key="DCL_SN1";label="初值";action="(TNJ-DCL-UP)";}
                           :edit_box {key="DCL_AN1";label="增量";action="(TNJ-DCL-UP)";}
                           :edit_box {key="DCL_SF1";label="后缀";action="(TNJ-DCL-UP)";}
                        :toggle{key="DCL_LM1";label="字母编号";action="(TNJ-DCL-UP)";}
                :boxed_column{label="第二行编号";
                        :toggle{key="DCL_ON2";label="启用";action="(TNJ-DCL-ON2)";}
                        :edit_box {key="DCL_PF2";label="前缀";is_enabled=false;action="(TNJ-DCL-UP)";}
                           :edit_box {key="DCL_SN2";label="初值";is_enabled=false;action="(TNJ-DCL-UP)";}
                           :edit_box {key="DCL_AN2";label="增量";is_enabled=false;action="(TNJ-DCL-UP)";}
                           :edit_box {key="DCL_SF2";label="后缀";is_enabled=false;action="(TNJ-DCL-UP)";}
                        :toggle{key="DCL_LM2";label="字母编号";is_enabled=false;action="(TNJ-DCL-UP)";}
                :boxed_column{label="第二行编号 2";
                        :toggle{key="DCL_ON3";label="启用";is_enabled=false;action="(TNJ-DCL-ON3)";}
                        :edit_box {key="DCL_PF3";label="前缀";is_enabled=false;action="(TNJ-DCL-UP)";}
                           :edit_box {key="DCL_SN3";label="初值";is_enabled=false;action="(TNJ-DCL-UP)";}
                           :edit_box {key="DCL_AN3";label="增量";is_enabled=false;action="(TNJ-DCL-UP)";}
                           :edit_box {key="DCL_SF3";label="后缀";is_enabled=false;action="(TNJ-DCL-UP)";}
                        :toggle{key="DCL_LM3";label="字母编号";is_enabled=false;action="(TNJ-DCL-UP)";}
        :row{:edit_box {key="DCL_TH";label="字高";}
                 :text {key="DCL_PREVIEW";label="格式预览   ";width=48;}}
                spacer_0;ok_cancel;
GMT+8, 2026-11-6 15:48 , Processed in 0.400131 second(s), 32 queries , Gzip On.
