查看: 1361|回复: 5
[LISP程序]:求教;如何画铁路线
发表于 2005-10-13 23:04:50 | 显示全部楼层 |阅读模式
求各位大侠帮忙!
我LISP画铁路程序如下:
;把spline变成铁路线示图
;ljc 2004.3
(DEFUN O1O( name cd / cm tc os q zd qd ang qdz zdy w1 w2 w3 w4 p1p2 p3 p4 ) ;name--spline的图元名 cd铁路线的宽度
          (setq cm(getvar "cmdecho") tc(getvar "clayer") os(getvar "osmode"))
          (command "osnap" "off")
          (setq cd(/ cd 2))
          (setq q(entget name))
          (setq Zd (cdr(assoc 10 q)))
          (setq qd (cdr(LAST q)))
          (SETQ ANG (ANGLE QD ZD))
          (SETQ  qdz (polar qd (+ ANG ( / PI 2)) cd))
          (setq  qdy (polar qd (- ANG ( / PI 2)) cd))
          (command "offset"  cd name qdz  "")
          (setq w1(entlast))
          (setq p1 (cdr(assoc 10 (entget w1))))
          (setq p2 (cdr(last (entget w1))))
          (command "offset"  cd name qdy  "")
          (setq w2(entlast))
          (setq p4 (cdr(assoc 10 (entget w2))))
          (setq p3 (cdr(last (entget w2))))
          (command "line" p1 p4 "")    (setq w3(entlast))
          (command "line" p2 p3 "")    (setq w4(entlast))
          (command "-bhatch" "p" "solid" "s" w1 w2 w3 w4 "" "")
          (command "erase" w1 w2 w3 w4 name "")
          (setvar "cmdecho" cm)
          (setvar "osmode" os)
          (setvar "clayer"  tc)
(defun c:tl( / line n0 j linex q qd zd cdd ang qdz dqy)
   (print "请选择铁路线:") (print)
   (setq line (ssget '((0 . "SPLINE"))))
   (setq ds(getint "请输黑白段长度:"))
   (setq cd(getreal "请输入绘制铁路线的宽度:"))
   (command "ucs" "" "")
   (command "erase" (ssget "x" '((0 . "point"))) "")
   (setq n0 (sslength line))
   (setq j 0  n2 0)
  (repeat n0
   (setq linex (ssname line j))
   (setq cdd(/ cd 2))
   (setq q(entget linex))
   (SETQ  qdz (polar qd (+ ANG ( / PI 2)) (* 10 cd)))
   (setq  qdy (polar qd (- ANG ( / PI 2)) (* 10 cd)))
   (command "offset"  cdd linex qdz linex qdy "")
   (command "measure" linex ds "")
   (command)
   (setq point (ssget "x" '((0 . "point"))))
   (setq n (sslength point))
   (setq i 0 ii 0)
   (repeat n
   (setq p1 (cdr(assoc 10 (entget(ssname point i)))))
   (command "erase" (ssname point i) "")
   (command "zoom" "w" (polar p1 (* pi 0.75) ds )  (polar p1 (* pi -0.25) ds ) )
   (command "break"  (list (car p1) (cadr p1)  (caddr p1))  "@" )
   (if (= 2 ii) (setq ii 0))
   (if (= 0 ii) (o1o (entlast) cd) (command "erase" (entlast) ""))
   (setq ii (1+ ii))
   (setq i (+ i 1))
   (setq j (+ j 1))
   (if (= 2 ii) (o1o linex cd) (command "erase" linex ""))
   (command "zoom" "e" "")
(print "敲入tL运行程序---LJC") (PRINT)
加载后不能画铁路线,请指导或提供新程序.谢谢!
发表于 2005-10-13 23:24:39 | 显示全部楼层
其实最简单的方法是加载一种特殊的“铁路线”线型,直接使用这种线型画线就可以了,剪切修改起来也很方便
发表于 2005-10-13 23:47:57 | 显示全部楼层
Re: [LISP程序]:求教;如何画铁路线
最初由 陈西 发布
[B]求各位大侠帮忙!
我LISP画铁路程序如下:
;把spline变成铁路线示图
;ljc 2004.3
        ... [/B]
试试:
  1. [FONT=courier new](defun c:tl (/ line n0 j linex q qd zd cdd ang qdz dqy)
  2.   (setq        cm (getvar "cmdecho")
  3.         tc (getvar "clayer")
  4.         os (getvar "osmode")
  5.   )
  6.   (command "osnap" "off")
  7.   (print "\n请选择铁路线 : ")
  8.   (setq        line (ssget '((0 . "SPLINE")))
  9.         ds   (getint "\n请输黑白段长度 : ")
  10.         cd   (getreal "\n请输入绘制铁路线的宽度 : ")
  11.   )
  12.   (command "ucs" "" "")
  13.   (command "erase" (ssget "x" '((0 . "point"))) "")
  14.   (setq        n0 (sslength line)
  15.         j  0
  16.         n2 0
  17.   )
  18.   (repeat n0
  19.     (setq linex        (ssname line j)
  20.           cdd        (/ cd 2)
  21.           q        (entget linex)
  22.           Zd        (cdr (assoc 10 q))
  23.           qd        (cdr (LAST q))
  24.           ANG        (ANGLE QD ZD)
  25.           qdz        (polar qd (+ ANG (/ PI 2)) (* 10 cd))
  26.           qdy        (polar qd (- ANG (/ PI 2)) (* 10 cd))
  27.     )
  28.     (command "offset" cdd linex qdz linex qdy "")
  29.     (command "measure" linex ds "")
  30.     (command)
  31.     (setq point        (ssget "x" '((0 . "point")))
  32.           n        (sslength point)
  33.           i        0
  34.           ii        0
  35.     )
  36.     (repeat n
  37.       (setq p1 (cdr (assoc 10 (entget (ssname point i)))))
  38.       (command "erase" (ssname point i) "")
  39.       (command "zoom"
  40.                "w"
  41.                (polar p1 (* pi 0.75) ds)
  42.                (polar p1 (* pi -0.25) ds)
  43.       )
  44.       (command "break" (list (car p1) (cadr p1) (caddr p1)) "@")
  45.       (if (= 2 ii)
  46.         (setq ii 0)
  47.       )
  48.       (if (= 0 ii)
  49.         (o1o (entlast) cd)
  50.         (command "erase" (entlast) "")
  51.       )
  52.       (setq ii (1+ ii)
  53.             i  (+ i 1)
  54.       )
  55.     )
  56.     (setq j (+ j 1))
  57.     (if        (= 2 ii)
  58.       (o1o linex cd)
  59.       (command "erase" linex "")
  60.     )
  61.   )
  62.   (command "zoom" "e" "")
  63.   (setvar "cmdecho" cm)
  64.   (setvar "osmode" os)
  65.   (setvar "clayer" tc)
  66. )
  67. (print "敲入tL运行程序---LJC")
  68. (PRINT)
  69. (DEFUN O1O (name cd / cm tc os q zd qd ang qdz zdy w1 w2 w3 w4 p1p2 p3
  70.             p4)
  71.   (setq        cm (getvar "cmdecho")
  72.         tc (getvar "clayer")
  73.         os (getvar "osmode")
  74.   )
  75.   (command "osnap" "off")
  76.   (setq        cd  (/ cd 2)
  77.         q   (entget name)
  78.         Zd  (cdr (assoc 10 q))
  79.         qd  (cdr (LAST q))
  80.         ANG (ANGLE QD ZD)
  81.         qdz (polar qd (+ ANG (/ PI 2)) cd)
  82.         qdy (polar qd (- ANG (/ PI 2)) cd)
  83.   )
  84.   (command "offset" cd name qdz "")
  85.   (setq        w1 (entlast)
  86.         p1 (cdr (assoc 10 (entget w1)))
  87.         p2 (cdr (last (entget w1)))
  88.   )
  89.   (command "offset" cd name qdy "")
  90.   (setq        w2 (entlast)
  91.         p4 (cdr (assoc 10 (entget w2)))
  92.         p3 (cdr (last (entget w2)))
  93.   )
  94.   (command "line" p1 p4 "")
  95.   (setq w3 (entlast))
  96.   (command "line" p2 p3 "")
  97.   (setq w4 (entlast))
  98.   (command "-bhatch" "p" "solid" "s" w1 w2 w3 w4 "" "")
  99.   (command "erase" w1 w2 w3 w4 name "")
  100.   (setvar "cmdecho" cm)
  101.   (setvar "osmode" os)
  102.   (setvar "clayer" tc)
  103. )[/FONT]
发表于 2005-10-14 00:34:11 | 显示全部楼层
关于画铁路线,我认为两种方法最可取
1.用线形
2.3条曲线组成,中间一条为有宽度虚线
两种方法都不用将spline改成多义线
发表于 2005-10-14 06:34:14 | 显示全部楼层
如果用三条线,属性如何给
 楼主| 发表于 2005-10-15 08:33:45 | 显示全部楼层
请问能否适用2006,我加载运行告诉我函数错误,不知如何解决?谢谢!
GMT+8, 2026-11-6 15:50 , Processed in 0.418955 second(s), 41 queries , Gzip On.
