查看: 1033|回复: 5
[LISP程序]:初学LISP
发表于 2005-10-15 09:45:17 | 显示全部楼层 |阅读模式
自己编了个小程序试试看,请不要见笑~~
;==============图形转块==========
(defun C:tvb ()
  (setq A (substr (rtos (getvar "DATE") 2 8) 10 9))
  (setq B (substr (rtos (getvar "CDATE") 2 8) 10 9))
  (setq p1 (getpoint "\n请设定插入点"))
  (command ".block" (strcat "cb" A B "x") P1 (ssget) "")
  (command ".insert" (strcat "cb" A B "x") P1 "" "" "")
  (princ)
 楼主| 发表于 2005-10-15 09:56:24 | 显示全部楼层 |阅读模式
初学LISP,试编着玩~~~
;-----------------复制旋转---------------------------------------------------------
(defun c:cr(/ ss)
(setq ss (ssget))
(if ss
(progn
(command "_.COPY" ss "" "0,0" "0,0" )
(command "_.ROTATE" ss "" pause pause)
(princ)
发表于 2005-10-15 14:33:22 | 显示全部楼层
我也初学 但我看不懂楼上的
看来函数还是得去看熟
发表于 2005-10-15 15:15:17 | 显示全部楼层
我也是初学者,大家有时间多多交流啊!!!!!!
发表于 2005-10-18 20:39:02 | 显示全部楼层
不懂lisp的语法意思啊!
发表于 2005-10-19 09:03:09 | 显示全部楼层
我也初学,请楼主多多发这样的帖子,要是有那位高手来指点一下就好了.
GMT+8, 2026-11-6 15:48 , Processed in 0.423925 second(s), 44 queries , Gzip On.
