查看: 846|回复: 4
[求助]:用sendcommaon执行measure时的问题
发表于 2005-10-25 17:44:03 | 显示全部楼层 |阅读模式
用sendcommaon执行measure时,要求选择对象,怎样才能自动选择所有要定点分矩的对象呢?我想把它放在sset选择集中,或是其的办法都行,只要能自动选择就可以,分矩成功后,再遍历所成生的点。
这段代码主要是选择要分矩的对象:
Set sset = acadApp.ActiveDocument.SelectionSets.Add("test")
sset.Select acSelectionSetAll
/////这句:
doc1.SendCommand "measure" & vbCr & "select" & vbCr & "all" & vbCr & Object_Step & vbCr
sset.Erase
For Each obj In doc1.ModelSpace
xyz = obj.Coordinates
conn.Execute "insert into object_points (tablename,objectid,xmgl_id,chamfer_id,pointx,pointy) values ('circle'," & db("id") & "," & NowXmgl_id & "," & ids & "," & Round(xyz(0), 4) & "," & Round(xyz(1), 4) & ")"
Next
发表于 2005-10-25 19:50:39 | 显示全部楼层
方法独特!学习中...
发表于 2005-10-25 22:05:46 | 显示全部楼层
把"all" 改为"(handent """ & obj.handle & """)"
 楼主| 发表于 2005-10-26 10:55:49 | 显示全部楼层 |阅读模式
doc1.SendCommand "measure" & vbCr & "(handent " & "," & circleObj.handle & ")" & vbCr & Object_Step & vbCr
不管带不带select都出下面的错误
命令: measure
选择要定距等分的对象: (handent ,2D)
; 错误: 参数类型错误: stringp nil
选择要定距等分的对象: .2
*无效*
发表于 2005-10-26 13:35:54 | 显示全部楼层
doc1.SendCommand "measure" & vbCr & "(handent """ & circleObj.handle & """)"  & vbCr & Object_Step & vbCr
GMT+8, 2026-11-3 20:47 , Processed in 0.562487 second(s), 42 queries , Gzip On.
