查看: 1186|回复: 5
[求助] [求助]:lsp标注坐标程序的小数位求助
发表于 2005-11-7 14:53:39 | 显示全部楼层 |阅读模式
我在这边下了个小的lisp语句,是直接标注点的xy坐标的,不过标出来的是2位的,如何改成3位小数?
(defun c:pptext()
(setq olderr *error* *error* myerr)
(setq pm (getvar "OSMODE"))
(setq h (getvar "TEXTSIZE"))
(setq p0 (polar '(1 1) 0 1))
(while (/= nil p0)
  (setvar "OSMODE" 33)
  (setq p0 (getpoint "\nInter_point:"))
  (setvar "OSMODE" 1024)
  (if (/= nil p0) (progn
    (setq pp (getpoint "\nText_position:"))
    (if (< (car pp) (car p0)) (progn
      (setq pp1 pp)
      (setq pp (polar pp pi (* (+ (strlen (rtos (car p0) 2 2)) 2) h 0.8))))
     (setq pp1 (polar pp 0 (* (+ (strlen (rtos (car p0) 2 2)) 2) h 0.8))))
    (setq p1 (polar pp (* pi 0.2) (* h 0.7)))
    (setq p2 (polar (polar pp (- (* pi 0.2)) (* h 0.7)) (* pi 1.5) h))
    (command "text" p1 h 0 "X")
    (command "text" p2 h 0 "Y")
    (setq p1 (polar p1 0 (* h 0.9)))
    (setq p2 (polar p2 0 (* h 0.9)))
    (command "text" p1 h 0 (rtos (nth 1 p0) 2 2))
    (command "text" p2 h 0 (rtos (car p0) 2 2))
     (command "line" p0 pp1 pp "")
     (command "line" p0 pp pp1 "")))))
(setvar "OSMODE" pm)
(prin1))
已领礼包: 9347个
发表于 2005-11-7 15:05:14 | 显示全部楼层
先设定这个 DimDec
(setvar “DimDec” 3)
发表于 2005-11-7 16:35:58 | 显示全部楼层
把你程序中的这两两句
改成
(command "text" p1 h 0 (rtos (nth 1 p0) 2 3))
(command "text" p2 h 0 (rtos (car p0) 2 3))
就可以了。
发表于 2005-11-7 17:04:26 | 显示全部楼层
  1. [FONT=courier new]
  2. (defun c:pptext        ()
  3.   (setq        olderr        *error*
  4.         *error*        myerr
  5.   )
  6.   (setq        pm (getvar "OSMODE")
  7.         h  (getvar "TEXTSIZE")
  8.         p0 (polar '(1 1) 0 1)
  9.   )
  10.   (while (setq p0 (getpoint "\nInter_point : "))
  11.     (setvar "OSMODE" 1024)
  12.     (setq pp (getpoint p0 "\nText_position : "))
  13.     (if        (< (car pp) (car p0))
  14.       (progn
  15.         (setq pp1 pp
  16.               pp  (polar pp pi (* (+ (strlen (rtos (car p0) 2 2)) 2) h 0.8))
  17.         )
  18.       )
  19.       (setq pp1 (polar pp 0 (* (+ (strlen (rtos (car p0) 2 2)) 2) h 0.8)))
  20.     )
  21.     (setq p1 (polar pp (* pi 0.2) (* h 0.7))
  22.           p2 (polar (polar pp (- (* pi 0.2)) (* h 0.7)) (* pi 1.5) h)
  23.     )
  24.     (command "text" p1 h 0 (strcat "X=" (rtos (nth 1 p0) 2 3)))
  25.     (command "text" p2 h 0 (strcat "Y=" (rtos (car p0) 2 3)))
  26.     (if        (< (car pp) (car p0))
  27.       (command "line" p0 pp1 pp "")
  28.       (command "line" p0 pp pp1 "")
  29.     )
  30.   )
  31.   (setvar "OSMODE" pm)
  32.   (princ)
  33. )[/FONT]
 楼主| 发表于 2005-11-7 20:57:07 | 显示全部楼层
谢谢楼上的各位:)
发表于 2005-11-7 22:10:19 | 显示全部楼层
将上两句改成
(command "text" p1 h 0 (rtos (nth 1 p0) 32))
(command "text" p2 h 0 (rtos (car p0) 3 2))
试试看
GMT+8, 2026-11-6 16:47 , Processed in 0.416318 second(s), 42 queries , Gzip On.
