查看: 1661|回复: 5
[求助]:修改鼠标右键菜单项
发表于 2005-11-7 16:20:34 | 显示全部楼层 |阅读模式
VBA编成实现添加或删除右键菜单选项
发表于 2005-11-7 18:36:19 | 显示全部楼层
Sub test()
    Dim currMenuGroup As AcadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    Dim scMenu As AcadPopupMenu
    Dim element As AcadPopupMenu
    For Each element In currMenuGroup.Menus
        If element.ShortcutMenu = True Then
            Set scMenu = element
        End If
    Next element
    '为快捷菜单添加菜单项  测量距离(" & Chr(Asc("&")) & "D)
    Dim scMenuItem As AcadPopupMenuItem
    Set scMenuItem = scMenu.AddMenuItem("", "测量距离(&D)", Macro & "_dist")
End Sub
 楼主| 发表于 2005-11-8 09:20:04 | 显示全部楼层
谢谢2楼的帮助!
发表于 2005-11-11 18:49:10 | 显示全部楼层
这个程序好,我喜欢
发表于 2005-12-5 00:24:48 | 显示全部楼层
怎样用
发表于 2006-8-1 20:46:27 | 显示全部楼层
[PHP]
;下面的例子在鼠标右键菜单中添加一项“画直线Line(&L)”命令,注意第8行line后面有一个空格:
(setq main-menugroup-name (strcase (vl-filename-base (getvar "menuname"))))
(setq menugroups (vla-get-menugroups (vlax-get-acad-object)) )
(vlax-for item menugroups
  (if (= main-menugroup-name (vla-get-name item))
    (vlax-for menu (vla-get-menus item)
      (if (= :vlax-true (vla-get-shortcutmenu menu))
        (progn
          (setq new-macro "$M=$(if,$(!=,$(getvar,cmdactive),0),$P0=*,line )")
          (vla-addmenuitem menu 0 "画直线Line(&L)" new-macro)
          (setq exist-shortcut t)
[/PHP]
GMT+8, 2026-11-22 10:37 , Processed in 0.353420 second(s), 20 queries , Gzip On, File On.
