查看: 1095|回复: 6
[求助] [求助]:大家帮忙给看看~有什么问题
发表于 2005-11-20 13:43:10 | 显示全部楼层 |阅读模式
(defun c:ch-c()
          (setvar "cmdecho" 0)                                ;取消命令响应
        (setq en_name (car (entsel)))
        (command "chprop" (en_name) "c" 3 "")
        (prin1)
已领礼包: 9347个
发表于 2005-11-20 13:55:12 | 显示全部楼层
(command "chprop" en_name "" "c" 3 "")
 楼主| 发表于 2005-11-20 14:12:00 | 显示全部楼层
        (setq en1 (entsel "\n 请选择直线:"))          ;选取直线
        (setq sum 0)
        (setq num 0)
(while en1
        (setq en1_nam (car en1))
        (command "chprop" en1_name "" "c" 3 "")
        (setq en1_data (entget en1_nam))          ;获取联合属性列表
        (setq pt1 (cdr (assoc 10 en1_data)))   ;获取群码为10的直线起点坐标
        (setq pt2 (cdr (assoc 11 en1_data)))  ;获取群码为11的直线终点坐标
        (setq dist (distance pt1 pt2))
那这个程序为什么运行不了呢
已领礼包: 9347个
发表于 2005-11-20 14:30:26 | 显示全部楼层
(command "chprop" en1_nam "" "c" 3 "")
;(setq en1 (entsel "\n 请选择直线:")) ;选取直线
(setq sum 0)   ; ???
(setq num 0)   ;???
(while (setq en1 (entsel "\n 请选择直线:")) ;选取直线
 楼主| 发表于 2005-11-20 14:50:32 | 显示全部楼层
谢谢,我太粗心了~!:)
再麻烦你依次,看看这个程序
(defun c:TK()
(initget "A0 A1 A2 A3 A4")
(setq size (getkword "\n input paper size:A0 A1 A2 A3 A4<A3>"))
(if (= size nil) (setq size "A3"))
(setq size (strcase size))
(cond
((= size "A0") (SETQ p2 '(1189,841)))
((= size "A1") (SETQ p2  '(841,594)))
((= size "A2") (SETQ p2  '(594,420)))
((= size "A3") (SETQ p2  '(420,297)))
(t             (SETQ p2  '(420,297)))
(setq p1 '(0,0))
(command "rectang" p1 p2)
(command "zoom" "e")
(prin1)
发表于 2005-11-20 18:09:11 | 显示全部楼层
你把两个点之间的逗号去掉就可以了,如下
....((= size "A1") (SETQ p2 '(841,594)))
....((= size "A1") (SETQ p2 '(841 594)))
依此类推.
 楼主| 发表于 2005-11-20 18:33:39 | 显示全部楼层
谢谢了:)
GMT+8, 2026-11-6 17:53 , Processed in 0.465272 second(s), 44 queries , Gzip On.
