查看: 734|回复: 0
[1122]BOUNDARY命令问题请教
发表于 2005-11-22 08:28:01 | 显示全部楼层 |阅读模式
版主请删除这篇文章~发错版了抱歉~
为何此程序中 BOUNDARY 命令制作孤立物件的物件会没有出现
如果我想将此物件留下并且移转到一个固定的图层
不知道程序对吗?
另外这段程序还有一个问题
就是贴上的数据文字为何不能编辑呢
烦请各位帮忙解答
谢谢
(defun c:ac2 ()
   (setq pt (getpoint "\n选取点: "))
      (command "-BOUNDARY" pt "" )
      (setq en (entlast))
    (command "chprop" en "" "la" "bpoly" "")
      (if (/= en nil)
         (progn
            (command "area" "o" en)
            (setq aa (getvar "area"))
            (redraw en 3)
            (entdel en)
(IF (tblsearch "STYLE" "CHINA-H")
       (setvar "TEXTSTYLE" "CHINA-H")
       (COMMAND "-style" "CHINA-H" "simplex,china" "" "1" "" "" "" "")
(setq txt (strcat "\n 面积:" (rtos (/ aa 10000) 2 3) "㎡ ")
   (command "text" pt "" "" txt)
   (prin1)
GMT+8, 2026-11-3 06:22 , Processed in 0.432653 second(s), 32 queries , Gzip On.
