查看: 1105|回复: 4
[求助] [求助]:1122]BOUNDARY命令问题请教
发表于 2005-11-22 11:10:18 | 显示全部楼层 |阅读模式
[1122]BOUNDARY命令问题请教
为何此程序中 BOUNDARY 命令制作孤立物件的物件会没有出现
如果我想将此物件留下并且移转到一个固定的图层
不知道程序对吗?
另外这段程序还有一个问题
就是贴上的数据文字为何不能编辑呢
烦请各位帮忙解答,谢谢!
(defun c:ac2 ()
   (setq pt (getpoint "\n选取点: "))
      (command "-BOUNDARY" pt "" )
      (setq en (entlast))
    (command "chprop" en "" "la" "bpoly" "")
      (if (/= en nil)
         (progn
            (command "area" "o" en)
            (setq aa (getvar "area"))
            (redraw en 3)
            (entdel en)
(IF (tblsearch "STYLE" "CHINA-H")
       (setvar "TEXTSTYLE" "CHINA-H")
       (COMMAND "-style" "CHINA-H" "simplex,china" "" "1" "" "" "" "")
(setq txt (strcat "\n 面积:" (rtos (/ aa 10000) 2 3) "㎡ ")
   (command "text" pt "" "" txt)
   (prin1)
发表于 2005-11-22 14:44:24 | 显示全部楼层
这样也许更好些:
  1. [FONT=courier new](defun c:ac2 ()
  2.   (IF (tblsearch "STYLE" "宋体")
  3.     (setvar "TEXTSTYLE" "宋体")
  4.     (command "_style" "宋体" "宋体" "0" "1" "0" "" "")
  5.   )
  6.   (setq pt (getpoint "\n选取点: "))
  7.   (command "-BOUNDARY" pt "")
  8.   (setq en (entlast))
  9.   (if (/= en nil)
  10.     (progn
  11.       (command "area" "o" en)
  12.       (command "layer" "m" "tmp" "c" "1" "" "")
  13.       (command "chprop" en "" "la" "tmp" "")
  14.       (setq txt
  15.              (strcat "面积:" (rtos (/ (getvar "area") 1000000) 2 3) "㎡")
  16.       )
  17.       (command "layer" "m" "面积标注" "c" "4" "" "")
  18.       (command "text" "j" "MC" pt "300" "0" txt)
  19.     )
  20.   )
  21.   (prin1)
  22. )[/FONT]
 楼主| 发表于 2005-11-22 20:35:10 | 显示全部楼层
謝謝xyp1964版主的回答
總算解答出來了
程序是否因為排列順序的錯誤而會造成問題呢?
发表于 2005-11-22 20:52:30 | 显示全部楼层
最初由 xyz518mm 发布
[B]謝謝xyp1964版主的回答
總算解答出來了
程序是否因為排列順序的錯誤而會造成問題呢? [/B]
问题:
1、(entdel en)如何再“移转到一个固定的图层”?
2、(rtos (/ aa 10000) 2 3)也换算错误。
3、(command "text" pt "" "" txt)未设字高和角度
发表于 2005-11-23 14:40:48 | 显示全部楼层
请问如果使用这各程序
继续发展成为将各各的面积资料做累加的动作
是否可行呢
GMT+8, 2026-10-17 04:09 , Processed in 0.481660 second(s), 40 queries , Gzip On.
