查看: 1434|回复: 1
[LISP函数]:Get ProcessorID
发表于 2005-11-23 00:38:25 | 显示全部楼层 |阅读模式
  1. ;;Test OK with XP
  2. ;;Use WMI to Get ProcessorID
  3. ;;Author :  eachy [eachy@xdcad.net]
  4. ;;Web    :  [url]http://www.xdcad.net[/url]
  5. ;;2005.11.22
  6. (defun xdl-ProcessorID (/ IDs WMIobj serv lox sn)
  7.   (vl-load-com)
  8.   (setq IDs '())
  9.   (if (SETQ WMIobj (VLAX-CREATE-OBJECT "wbemScripting.SwbemLocator"))
  10.     (progn
  11.       (SETQ serv (VLAX-INVOKE
  12.                    WMIobj     'ConnectServer            "."
  13.                    "\\root\\cimv2"         ""            ""
  14.                    ""              ""         128            nil
  15.                   )
  16.       )
  17.       (setq lox        (vlax-invoke
  18.                   serv
  19.                   'ExecQuery
  20.                   "Select * from Win32_Processor"
  21.                 )
  22.       )
  23.       (vlax-for        item lox
  24.         (if (not
  25.               (member (setq sn (vlax-get item 'ProcessorId)) IDs)
  26.             )
  27.           (setq IDs (cons sn IDs))
  28.         )
  29.       )
  30.       (mapcar 'vlax-release-object (list lox serv WMIobj))
  31.     )
  32.   )
  33.   (reverse IDs)
  34. )
发表于 2005-11-29 10:57:20 | 显示全部楼层
樓主這個程序是取cpu的內ID ? 測試了, 有點慢吞吞.
GMT+8, 2026-11-22 10:39 , Processed in 0.458001 second(s), 12 queries , Gzip On, File On.
