查看: 1128|回复: 5
[求助] [求助]:为什么只能点选而不能框选?
已领礼包: 9个
发表于 2005-11-24 02:01:06 | 显示全部楼层 |阅读模式
运行下面的程序中
  (progn
         (initdia)
         (IF T (command ".bhatch"))
         (while (eq 1 (logand 1 (getvar "CMDACTIVE")))
                (command pause)
         (command "Chprop" (entlast) "" "LA" "hatch" "")
进入对话框填充时“选择对象”只能够用点选不能用框选了?
为什么?
昨天都是正常的呢。
发表于 2005-11-24 14:09:53 | 显示全部楼层
怪事,运行了你上面的LISP后,CAD自动关了
已领礼包: 9个
 楼主| 发表于 2005-11-24 14:14:17 | 显示全部楼层
不会啊,那你运行整个程序看看呢。
(defun c:bh ( / ccolor clayer hatch hatchx num)
  (setq CLayer (getvar "clayer")
        CColor (getvar "cecolor")
  (if (= (tblsearch "layer" "Hatch") nil)
    (progn
      (princ "\n Hatch 图层不存在,正在创建...")
      (command "-layer" "n" "Hatch" "c" 252 "Hatch" "")
  (command ".layer" "on" "hatch" "")
  (initget "1 2 3 4 5")
  (if (not (setq num (getkword "\n请选择填充图案:[1-填实]/[2-钢筋混凝土]/[3-素混凝土]/[4-砖]/[5-钢材]/[回车进入对话框]:  ")))
     (if (setq p0 (getpoint "\n左键进行填实,右键进入对话框:"))
        (progn
          (princ "\n 请选择内部点: ")
          (setvar "clayer" "Hatch")
          (if (> (atof (getvar "acadver")) 16.0)
                  (command "-bhatch" "p" "solid" "dr" "b" pause)
                  (command "-bhatch" "p" "solid" pause)
                (command pause)
       (progn
         (initdia)
                (command pause)
    (progn
      (if (= "1" num)
        (progn
          (while (= (getvar "cmdnames") "-BHATCH")
            (command pause)
        (progn
          (cond
            ((= "2" num)
              (setq hatch "an31c"
                    hatchx 1000.
            ((= "3" num)
              (setq hatch "an33c"
                    hatchx 1000.
            ((= "4" num)
              (setq hatch "ansi31"
                    hatchx 1200.
            ((= "5" num)
              (setq hatch "ansi32"
                    hatchx 1000.
                (command "-bhatch" "p" hatch hatchx 0. "dr" "b" pause)
                  (command "-bhatch" "p" hatch hatchx 0. pause)
            (command pause)
      (xdrx_draworder->back (entlast))
;;;      (command ".regen")
  (setvar "clayer" CLayer)
  (setvar "cecolor" CColor)
  (princ)
发表于 2005-12-6 22:43:17 | 显示全部楼层
我用了一下,对话框就没跳出来,直接命令行显示要点选。
另外,你的填充图形的比例能不根椐填充对象的大小来调整比例。
发表于 2005-12-6 23:41:01 | 显示全部楼层
请问:
做一个选择集的时候,就能框选了,怎么做一个只能点选的选择集,请高手们把代码贴出,谢谢!
发表于 2005-12-6 23:50:41 | 显示全部楼层
  1. [FONT=courier new](defun c:test (/ s1)
  2.   (setq ss (ssadd))
  3.   (while (setq s1 (car (entsel "\n选择实体 : ")))
  4.     (setq ss (ssadd s1 ss))
  5.   )
  6.   ss
  7. )[/FONT]
GMT+8, 2026-11-6 20:46 , Processed in 0.404747 second(s), 42 queries , Gzip On.
