查看: 1061|回复: 3
[LISP程序]:请问有没有直线加粗程序
发表于 2005-11-24 20:44:00 | 显示全部楼层 |阅读模式
不知哪位仁兄有直线加粗程序,谢谢!
发表于 2005-11-28 21:31:40 | 显示全部楼层
论坛有,自己找
发表于 2005-11-29 22:32:16 | 显示全部楼层
(DEFUN C:CW (/ W2 SS S1 ENT LT I P1 P2 R)
  (SETVAR "CMDECHO" 0)
  (SETVAR "BLIPMODE" 0)
  (VL-LOAD-COM)
  (IF (NOT W1)
    (SETQ W1 (GETVAR "PLINEWID"))
  (PRINC "\n 请选择需要修改线宽的线段:")
  (SETQ SS (SSGET '((0 . "*LINE,ARC,CIRCLE,ELLIPSE"))))
  (IF (> (SSLENGTH SS) 0)
    (PROGN
      (SETQ W2 W1)
      (PRINC
        "\n 请输入新的统一线宽<"
      (PRINC W1)
      (PRINC ">:")
      (SETQ W1 (GETREAL))
      (IF (= W1 NIL)
        (SETQ W1 W2)
      (SETQ I 0)
      (REPEAT (SSLENGTH SS)
        (SETQ S1 (SSNAME SS I))
        (SETQ ENT (ENTGET S1))
        (SETQ LT (CDR (ASSOC 0 ENT)))
        (COND
          ((OR (= LT "ELLIPSE") (= LT "SPLINE"))
           (VLA-PUT-LINEWEIGHT
             (VLAX-ENAME->VLA-OBJECT S1)
             (EVAL (READ (STRCAT "acLnWt" (GETSW W1))))
          ((= LT "CIRCLE")
           (SETQ P1 (CDR (ASSOC 10 ENT)))
           (SETQ R (CDR (ASSOC 40 ENT)))
           (SETQ P2 (POLAR P1 0.000001 R))
           (SETQ P2 (OSNAP P2 "_NEA"))
           (SETQ P1 (POLAR P1 0.0 R))
           (SETQ P1 (OSNAP P1 "_NEA"))
           (COMMAND "_BREAK" S1 P1 P2)
           (COMMAND "_PEDIT" S1 "" "W" W1 "")
          ((= LT "LWPOLYLINE")
           (COMMAND "_PEDIT" S1 "W" W1 "")
          ((COMMAND "_PEDIT" S1 "" "W" W1 "")
        (SETQ I (1+ I))
  (SETVAR "CMDECHO" 1)
  (PRINC)
(PRINC "\n 修改线宽程序已加载,运行命令:CW")
(DEFUN GETSW (W / I LST1 LST2 E1)
  (SETQ        LST1 '("000"        "005"         "009"          "013"           "015"    "018"
               "020"        "025"         "030"          "035"           "040"    "050"
               "053"        "060"         "070"          "080"           "090"    "100"
               "106"        "120"         "140"          "158"           "200"    "211"
  (SETQ        LST2 (MAPCAR '(LAMBDA (X)
                        (ABS (- (/ (ATOF X) 100.0) W))
                     LST1
  (SETQ E1 (APPLY 'MIN LST2))
  (SETQ I 0)
  (WHILE (/= E1 (NTH I LST2))
    (SETQ I (1+ I))
  (SETQ W2 (NTH I LST1))
发表于 2005-12-18 11:45:43 | 显示全部楼层
谢谢了,这个很好用的哦!
GMT+8, 2026-11-3 01:53 , Processed in 0.648238 second(s), 38 queries , Gzip On.
