查看: 1363|回复: 3
[求助]:块属性问题求教
发表于 2005-11-25 09:28:36 | 显示全部楼层 |阅读模式
怎么读取图档同块的属性,并修改该块的属性
发表于 2005-11-25 13:22:18 | 显示全部楼层
GetAttributes 方法
 楼主| 发表于 2005-11-25 14:30:29 | 显示全部楼层
GetAttributes 方法 是读取属性值,我想读取属性并修改该属性值,改这么办? 请斑主指教,谢谢
另外请问 怎样移动选择集?
发表于 2005-12-2 19:24:57 | 显示全部楼层
简单
AutoCAD自带的VBA帮助里关于“快属性编辑”一句经典的话:
[' Note: There is no SetAttributes. Once you have the variant array, you have the objects.
(翻译:'注意:没有SetAttributae这个方法; 你一旦拥有了属性Variant数组,你有拥有了这个对象。)] 意思很简单:当你通过GetAttribute获取了块的属性(比如赋给Dim varAttributes As Variant它了,
),那么,varAttributes这个变量就能代表“块属性”这个对象,你可以对它进行操作,就能编辑块的属性值。这个做法在VBA的对象里很少见。
现在借花献佛,把Autocad自带的例子给你看看。
Sub Example_GetAttributes()
    ' This example creates a block. It then adds attributes to that
    ' block. The block is then inserted into the drawing to create
    ' a block reference.
    ' Create the block
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "TESTBLOCK")
    ' Define the attribute definition
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim insertionPoint(0 To 2) As Double
    Dim tag As String
    Dim value As String
    height = 1#
    mode = acAttributeModeVerify
    prompt = "Attribute Prompt"
    insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
    tag = "Attribute Tag"
    value = "Attribute Value"
    ' Create the attribute definition object in model space
    Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
    ' Insert the block
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "TESTBLOCK", 1#, 1#, 1#, 0)
    ZoomAll
    ' Get the attributes for the block reference
    varAttributes = blockRefObj.GetAttributes
    ' Move the attribute tags and values into a string to be displayed in a Msgbox
    Dim strAttributes As String
    Dim I As Integer
    For I = LBound(varAttributes) To UBound(varAttributes)
        strAttributes = strAttributes & "  Tag: " & varAttributes(I).TagString & _
                        "   Value: " & varAttributes(I).textString & "    "
    Next
    MsgBox "The attributes for blockReference " & blockRefObj.name & " are: " & strAttributes, , "GetAttributes Example"
    ' Change the value of the attribute
    ' Note: There is no SetAttributes. Once you have the variant array, you have the objects.[/COLOR]
    ' Changing them changes the objects in the drawing.
    varAttributes(0).textString = "NEW VALUE!"
    Dim newvarAttributes As Variant
    newvarAttributes = blockRefObj.GetAttributes
    ' Again, display the tags and values
    strAttributes = ""
    Next      '''////这个循环就在修改属性值!你要的在这儿。。。。
[/COLOR]
End Sub
师父就在身边:AutoCAD帮助-开发人员文档,是个好东东。
GMT+8, 2026-11-3 18:01 , Processed in 0.654571 second(s), 38 queries , Gzip On.
