查看: 1295|回复: 1
[LISP函数]:获取当前屏幕分辨率
发表于 2005-11-25 21:02:15 | 显示全部楼层 |阅读模式
  1. ;;Test OK with XP
  2. ;;Use WMI to Get Display Mode
  3. ;;Author :  eachy
  4. ;;Web    :  [url]http://www.xdcad.net[/url]
  5. ;;2005.11.24
  6. (defun xdl-GetDisplayPixels (/ IDs WMIobj serv lox sn)
  7.   (vl-load-com)
  8.   (setq IDs '())
  9.   (if (SETQ WMIobj (VLAX-CREATE-OBJECT "wbemScripting.SwbemLocator"))
  10.     (progn
  11.       (SETQ serv (VLAX-INVOKE
  12.                    WMIobj     'ConnectServer            "."
  13.                    "\\root\\cimv2"         ""            ""
  14.                    ""              ""         128            nil
  15.                   )
  16.       )
  17.       (setq lox        (vlax-invoke
  18.                   serv
  19.                   'ExecQuery
  20.                   "Select * from Win32_DisplayControllerConfiguration"
  21.                 )
  22.       )
  23.       (vlax-for        item lox
  24.         (if (not
  25.               (member (setq sn (list
  26.                                  (vlax-get item 'HorizontalResolution)
  27.                                  (vlax-get item 'VerticalResolution)
  28.                                )
  29.                       )
  30.                       IDs
  31.               )
  32.             )
  33.           (setq IDs (cons sn IDs))
  34.         )
  35.       )
  36.       (mapcar 'vlax-release-object (list lox serv WMIobj))
  37.     )
  38.   )
  39.   (car (reverse IDs))
  40. )
发表于 2005-12-14 12:36:33 | 显示全部楼层
我的屏幕分辨率是1024X768,你的呢?
GMT+8, 2026-11-22 10:34 , Processed in 0.136803 second(s), 10 queries , Gzip On, File On.
