查看: 3461|回复: 12
[分享]:兩表的並集、交集和差集等表处理函数
已领礼包: 2个
发表于 2005-12-3 22:08:10 | 显示全部楼层 |阅读模式
1.兩表的並集:LI-UNION
[PHP]
;; ! LI_Union
;; ! Function : Performs a union of two lists
;; ! Arguments:
;; !            'Lst1' - First List
;; !            'Lst2' - Second List
;; ! Action   : Returns a list which contains all of Lst1 plus any elements in
;; !            not contained in Lst1
;; !            Duplicate elements will be added as many times as they occur in
;; !            second list
;; ! Updated  : December 23, 1998
;; ! e-mail   : rakesh.rao@4d-technologies.com
;; ! Web      : www.4d-technologies.com
(defun LI-Union( Lst1 Lst2 / Lst tmp )
(setq Lst '())
(foreach tmp Lst2
        (if (not (member tmp Lst1))
                (setq Lst (cons tmp Lst))
(setq
        Lst (reverse Lst)
        Lst (append Lst1 Lst)
Lst
[/PHP]
還差以下兩個,有興趣的,跟!
2.兩表的差集:LI-DIFF
3.兩表的交集:LI-INTER
发表于 2005-12-3 23:30:55 | 显示全部楼层
  1. [FONT=courier new]
  2. ;;;两表的并集
  3. (defun LSTUNION        (Lst1 Lst2 / Lst tmp)
  4.   (append Lst1 lst2)
  5. )
  6. ;;;两表的交集
  7. (defun LSTINTER        (Lst1 Lst2 / Lst tmp lst11 lst22)
  8.   (foreach tmp Lst2
  9.     (if        (member tmp Lst1)
  10.       (setq Lst22 (cons tmp Lst22))
  11.     )
  12.   )
  13.   (foreach tmp Lst1
  14.     (if        (member tmp Lst2)
  15.       (setq Lst11 (cons tmp Lst11))
  16.     )
  17.   )
  18.   (setq        Lst (append (reverse Lst11) (reverse Lst22))
  19.         lst (LstDelSame lst)
  20.   )
  21.   Lst
  22. )
  23. ;;;两表的差集
  24. (defun LSTDIFF (Lst1 Lst2 / Lst tmp lst11 lst22)
  25.   (foreach tmp Lst2
  26.     (if        (not (member tmp Lst1))
  27.       (setq Lst22 (cons tmp Lst22))
  28.     )
  29.   )
  30.   (foreach tmp Lst1
  31.     (if        (not (member tmp Lst2))
  32.       (setq Lst11 (cons tmp Lst11))
  33.     )
  34.   )
  35.   (setq        Lst (append (reverse Lst11) (reverse Lst22))
  36.         lst (LstDelSame lst)
  37.   )
  38.   Lst
  39. )
  40. ;;;删除列表中的相同元素(保留一个)并返回新表
  41. (defun LstDelSame (lst / x nl)
  42.   (foreach x lst
  43.     (if        (not (member x nl))
  44.       (setq nl (cons x nl))
  45.     )
  46.   )
  47.   (reverse nl)
  48. )
  49. [/FONT]
测试:
[php]
;;(LSTUNION '(f a b gg b c c d f) '(a e f gg c h d))→(F A B GG B C C D F A E F GG C H D)
;;(LSTINTER '(f a b gg b c c d f) '(a e f gg c h d))→(F A GG C D)
;;(LSTDIFF '(f a b gg b c c d f) '(a e f gg c h d))→(B E H)
[/php]
已领礼包: 2个
 楼主| 发表于 2005-12-4 07:06:22 | 显示全部楼层
版主真是牛b,五體投地!請大家收集所有的表處理函數,看看有多少好東西.
http://www.xdcad.net/forum/showthread.php?s=&threadid=452095
以上鏈接內容:
1.去除表的最後一個元素.
2.將表的第N項移去.
3.在表的第n項位置增加一元素.
4.从列表中移去指定的元素.(摘自明經)
[PHP](defun i:listremoveatom (delatom lstin)
  (apply
    'append
    (subst
      nil
      (list delatom)
      (mapcar
        'list
        lstin
[/PHP]
另一種:
[PHP](defun LI_RemLst( itm lst / nlst elem len )
(setq nlst '())
(foreach elem lst
        (if (not (equal elem itm))
                (setq nlst (append nlst (list elem)))
nlst
)[/PHP]
測試:
(setq q (list 1 1 1 2 3 4 5 6 7 8 9 9 9 9))
(i:listremoveatom 1 q)
(2 3 4 5 6 7 8 9 9 9 9)
(i:listremoveatom 9 q)
(1 1 1 2 3 4 5 6 7 8)
(i:listremoveatom 8 q)
(1 1 1 2 3 4 5 6 7 9 9 9 9)
(LI_REMLST 3 (list 1 2 3 4 5 6 7 8 9 9 8 7 6 5 4 3 2 1))
(1 2 4 5 6 7 8 9 9 8 7 6 5 4 2 1)
5.结合两个列表以创建一个点对列表 (摘自明經)
[PHP](defun listunion (lst1 lst2)
  (mapcar 'cons lst1 lst2)
)[/PHP]
測試:
(listunion '("One" "Two" "Three") '(1 2 3))
(("One" . 1) ("Two" . 2) ("Three" . 3))
(listunion '("One" "Two" "Three") '(1 2 ))
(("One" . 1) ("Two" . 2))
(listunion '("One" "Two")'(1 2 3))
6.删除列表中的相同元素(保留一个)并返回新表
[PHP](defun LstDelSame( Lst / Lst1 tmp )
(setq Lst1 '())
(foreach tmp Lst
                (setq Lst1 (cons tmp Lst1))
(reverse Lst1)
)[/PHP]
[PHP](defun LstDelSame (lst / x nl)
  (mapcar
    '(lambda (x)
    lst
  (reverse nl)
)[/PHP]
7.替換指定位置的元素.
[PHP];; ! ***************************************************************************
;; ! LI_RepList
;; ! Function : Replaces a member of the list at the specified position
;; ! Argument : 'Lst'    - The list to operate on.
;; !            'Pos'    - Postion in list after which the new element is to be
;; !                       replaced (starts with 1).
;; !            'Val'    - The new value of the list member
;; ! Returns  : The updated list, if 'pos' is greater than the length of the
;; !            list, the function returns nil
;; ! Update   : October 13, 1998
(defun LI_RepList (Lst Pos Val / Lst1 Lst2 cnt len )
(setq
        cnt 0
        len (length Lst)
        Lst1 '()
(if (and (> Pos 0) (<= Pos len))
(progn
        (repeat (1- Pos)
                (setq
                        Lst1 (cons (nth cnt Lst) Lst1)
                        cnt (1+ cnt)
        (setq
                Lst1 (cons Val Lst1)
                Lst1 (reverse Lst1)
                cnt Pos
        (if (> len cnt)
        (progn
                (setq Lst2 '())
                (repeat (- len cnt)
                        (setq
                                Lst2 (cons (nth cnt Lst) Lst2)
                                cnt (1+ cnt)
                (setq
                        Lst2 (reverse Lst2)
                        Lst1 (append Lst1 Lst2)
Lst1
[/PHP]
8.N位開始,M 長度的子表.
[PHP](defun LI_SubList ( Lst Start len / _len n m _Lst)
(if (minusp len)
        (setq len (1+(length lst)))
(setq
        _len (length Lst)
        n (min (- Start 1) _len)        ; Starting Index
        m (min (+ n len) _len)                ; Ending Index
        _Lst '()
(while (< n m)
        (setq
                _Lst (cons (nth n Lst) _Lst)
                n (1+ n)
(reverse _Lst)
[/PHP]
測試:
命令: !q
(1 2 3 4 5 6 7 8 9 9 8 7 6 5 4 3 2 1)
命令: (LI_SUBLIST q 1 8)
(1 2 3 4 5 6 7 8)
命令: (LI_SUBLIST q 1 -1)
命令: (LI_SUBLIST q 1 0)
nil
9.差集(覺得XYP版主的不對)
[PHP](defun LI_Subtract( Lst1 Lst2 / Lst )
(setq Lst '())
(if Lst1
(progn
        (foreach tmp Lst1
(setq Lst (reverse Lst))
Lst
[/PHP]
測試:
命令: !q (1 2 3 4 5 6 7 8 9 9 8 7 6 5 4 3 2 1)
命令: !w(5 6 9 8 7 10 45)
命令: (LI_SUBTRACT w q)
(10 45)
命令: (LI_SUBTRACT q w)
(1 2 3 4 4 3 2 1)
命令: (lstdiff q w)
(1 2 3 4 10 45)
命令: (lstdiff w q)
(10 45 1 2 3 4)
10.交集的另一種(覺得XYP版主的更合理).
[PHP](defun LI_Intersect( Lst1 Lst2 / Lst tmp )
(setq Lst '())
(if (or Lst1 Lst2)
(progn
        (foreach tmp Lst1
Lst
[/PHP]
測試:
命令: (LI_INTERSECT q w)
(5 6 7 8 9 9 8 7 6 5)
命令: (LI_INTERSECT w q)
(5 6 9 8 7)
命令: (lstinter q w)
(5 6 7 8 9)
命令: (lstinter w q)
(5 6 9 8 7)
发表于 2005-12-4 08:08:16 | 显示全部楼层
移除列表的第N项
[PHP]
(defun hy_remove_nth(lst n / i )
(setq j -1)
(vl-remove-if '(lambda(x)(= n(setq j(1+ j)))) lst)
[/PHP]
清除列表相同的项目
[PHP]
(defun hy_erasedouble(nlist preci / needlist);;;preci 带精度控制
  (setq needlist nlist)
  (foreach item nlist (setq needlist (append (list item)
                                             (vl-remove-if '(lambda(x) (equal item x preci)
                                               needlist)))
  (reverse needlist))
[/PHP]
发表于 2005-12-4 09:56:35 | 显示全部楼层
我感觉stdlib里面的表函数就挺齐全的,反正现在一般临时想到的都能在里面找到相应函数
已领礼包: 2个
 楼主| 发表于 2005-12-4 13:32:16 | 显示全部楼层
最初由 snoopychen 发布
[B]我感觉stdlib里面的表函数就挺齐全的,反正现在一般临时想到的都能在里面找到相应函数 [/B]
沒發現STDLIB裏有多少表處理函數啊?列幾個出來看看?
查了一下,確實挺全的.參考以下鏈接:
http://www.xdcad.net/forum/showt ... 2337952#post2337952
http://www.xdcad.net/forum/showt ... 2418851#post2418851
发表于 2005-12-5 12:45:08 | 显示全部楼层
各位高手可以说明一下
表的运用吗?
thank!
已领礼包: 2个
 楼主| 发表于 2005-12-6 20:42:32 | 显示全部楼层
1.判断点表是否共线.
链接:   http://www.xdcad.net/forum/showthread.php?s=&threadid=471571
2.1,点集中XminYmin(X优先于Y)
2.2,点集中XmaxYmax(X优先于Y)
2.3,点集中YminXmin(Y优先于X)
2.4,点集中YmaxXmax(Y优先于X)
链接:  http://www.xdcad.net/forum/showthread.php?s=&threadid=463109
发表于 2005-12-6 21:29:45 | 显示全部楼层
最初由 taner 发布
[B]1.判断点表是否共线.
2.4,点?.. [/B]
不错的文章
但可以来各范例介绍一下运用吗
谢谢
已领礼包: 2个
 楼主| 发表于 2005-12-6 21:35:54 | 显示全部楼层
最初由 xyz518mm 发布
[B][QUOTE]最初由 taner 发布
[B]1.判断点表是否共线.
2... [/B]
1.部份函数有测试的范例,看看测试结果应该知道用法.
2.请自行测试,自己亲自测试比别人介绍更有效.
已领礼包: 488个
发表于 2005-12-6 22:13:55 | 显示全部楼层
  1. ;;;两表的差集
  2. (defun LST-LST(lst1 lst2)
  3.   (vl-remove-if '(lambda(x)(member x lst2)) lst1)
  4. )
  5. ;;;交集
  6. (defun LSTxLST(lst1 lst2)
  7.   (vl-remove-if-not '(lambda(x)(member x lst2)) lst1)
  8. )
  9. ;;;并集
  10. (defun LST+LST(lst1 lst2)
  11. (append lst1 (LST-LST lst2 lst1))
  12. )
其实没必要写函数
发表于 2007-1-24 00:49:10 | 显示全部楼层
楼上的代码都很精彩,多谢了
已领礼包: 1491个
发表于 2008-7-24 15:15:40 | 显示全部楼层
好东西!但('1 2 3 4 5  '1 2 4 6 7 ' 1 3 4 5 6 )和( '1 2  3 4 5  '1 2 4 6 7) 不可以剩下('1 3 4 5 6)!要是可以实现这个功能就好了!
GMT+8, 2026-11-7 08:11 , Processed in 0.618794 second(s), 56 queries , Gzip On.
