查看: 2125|回复: 6
[求助] [求助]:用lisp如何获的CAD窗口的背景颜色
已领礼包: 2个
发表于 2005-12-8 15:22:51 | 显示全部楼层 |阅读模式
vla-get-graphicswinmodelbackgrndcolor
发表于 2005-12-8 17:43:14 | 显示全部楼层
VLA-GET和VLA-PUT
这些函数是activex类的,必须查ACTIVEX和VBA
GraphicsWinModelBackgrndColor Property
Specifies the background color for the model space window.
See Also | Example
Signature
object.GraphicsWinModelBackgrndColor
object
PreferencesDisplay
The object or objects this property applies to.
OLE_COLOR (Visual Basic constant); read-write
vbBlack
vbRed
vbYellow
vbGreen
vbCyan
vbBlue
vbMagenta
vbWhite
Remarks
The default color for this property is vbBlack.
发表于 2005-12-9 11:09:19 | 显示全部楼层
感谢一楼的楼主,也感谢三楼的楼主,请问三楼的楼主能否再说的详细一点呢!
我想那样会更好!
已领礼包: 593个
发表于 2005-12-9 19:20:50 | 显示全部楼层
http://www.xdcad.net/forum/showt ... d=385302#post385302
Command: (getenv "Background")
"0"
  1. (variant-value
  2.   (vlax-variant-change-type
  3.     (vla-get-GraphicsWinModelBackgrndColor
  4.       (vla-get-display
  5.         (vla-get-preferences (vlax-get-acad-object))
  6.       )
  7.     )
  8.     vlax-vbstring
  9.   )
  10. )
复制代码
已领礼包: 2个
 楼主| 发表于 2005-12-9 20:12:04 | 显示全部楼层
背景在黑与白之间转换
摘自明经通道
[PHP](defun c:ax (/ prefdisplay)
  (vl-load-com)
  (setq prefdisplay (vla-get-display (vla-get-preferences
        color (vlax-variant-value (vlax-variant-change-type
                                                            (vla-get-graphicswinmodelbackgrndcolor prefdisplay)
                                                            vlax-vblong
  (vla-put-graphicswinmodelbackgrndcolor prefdisplay
                                         (vlax-make-variant (if (= color 0)
                                                              16777215
                                                              0
                                                            ) vlax-vblong
  (princ)
)[/PHP]
发表于 2005-12-9 22:01:21 | 显示全部楼层
修改背景:
(COMMAND "vbastmt" "ThisDrawing.Application.preferences.Display.GraphicsWinModelBackgrndColor = 56")
(VLA-EVAL (vlax-get-acad-object)"ThisDrawing.Application.preferences.Display.GraphicsWinModelBackgrndColor = 56")
发表于 2005-12-11 10:42:54 | 显示全部楼层
我也有这个问题。我感觉通用函数很复杂,每次都不会用。哪里可以查到所有的通用函数呢?
GMT+8, 2026-11-6 22:38 , Processed in 0.534588 second(s), 44 queries , Gzip On.
