查看: 1784|回复: 2
Restores expected behavior of STRETCH command in ACAD 2006
发表于 2005-12-13 02:04:21 | 显示全部楼层 |阅读模式
  1. ;;;----------------StretchRight.lsp-----------------------------------------
  2. ;;; Purpose: Restores expected behavior of STRETCH command in ACAD 2006
  3. ;;; Author : Herman Mayfarth
  4. ;;; Date   : 4/23/2005
  5. ;;; Version: 1.1
  6. ;;; Permission granted to freely use and redistribute without fee.
  7. ;;; Supplied "as is," and without warranty, express or implied.
  8. ;;; Acknowledgements: Many thanks to Joe Burke & John Uhden for discovering
  9. ;;; STRETCH command behaves as if PICKAUTO=0 when called from a LISP routine,
  10. ;;; unless the value of QAFLAGS is >0, and to Trey Mansour for testing this.
  11. ;;;-------------------------------------------------------------------------
  12. (vl-cmdf "undefine" "_stretch")
  13. (defun C:Stretch (/ *error* oldpik oldqaf olcmd)
  14.   (defun *error* (msg /)
  15.     (setvar "pickstyle" oldpik)
  16.     (setvar "qaflags" oldqaf)
  17.   )
  18.   (setq        oldpik (getvar "pickstyle")
  19.         oldqaf (getvar "qaflags")
  20.         oldcmd (getvar "cmdecho") ;_ add
  21.   )
  22.   (setvar "cmdecho" 1)
  23.   (setvar "qaflags" 1)
  24.   (cond        ((member oldpik '(1 3)) ;_group selection enabled
  25.          (setvar "pickstyle" (1- oldpik)) ;_disable object grouping
  26.          (vl-cmdf "_.stretch") ;_invoke native stretch command
  27.          (while        (= (logand (getvar "CMDACTIVE") 1) 1)
  28.            (command pause)
  29.          ) ;_pause until completion
  30.         )
  31.         (1 ;_group selection disabled
  32.          (vl-cmdf "_.stretch") ;_invoke native stretch command
  33.          (while        (= (logand (getvar "CMDACTIVE") 1) 1)
  34.            (command pause)
  35.          ) ;_pause until completion
  36.         )
  37.   ) ;_cond
  38.   (setvar "cmdecho" oldcmd)
  39.   (*error* nil) ;_restore sysvars
  40.   (princ)
  41. ) ;_C:Stretch
  42. (princ "\n StretchRight Loaded.")
  43. (princ)
发表于 2013-6-26 23:28:40 | 显示全部楼层
替换CAD的查找,先试下:)
发表于 2013-6-27 07:47:00 | 显示全部楼层
是拉伸用的一个插件
GMT+8, 2026-11-22 08:06 , Processed in 0.373822 second(s), 14 queries , Gzip On, File On.
