查看: 1124|回复: 4
[求助] [求助]:怎样把-.600变成-0.600来显示
发表于 2005-12-21 07:49:42 | 显示全部楼层 |阅读模式
请教各位大侠,我用lisp程序计算得到一个负数(比如说是-0.600),我想要它在cad内的现状文字对象内正确显示,但是有时候显示的是-.600,少了个零,请教这是怎么回事阿,是不是哪个参数没有设置好,急切的得到各
位的回答阿。
已领礼包: 9347个
发表于 2005-12-21 08:18:59 | 显示全部楼层
DIMZIN
DIMZIN System Variable
Type: Integer
Saved in: Drawing
Initial value: 0
Controls the suppression of zeros in the primary unit value. DIMZIN stores this value when you enter it on the command line or set it under Primary Units in the Annotation dialog box. DIMZIN values 0–3 affect feet-and-inch dimensions only.
0 Suppresses zero feet and precisely zero inches
1 Includes zero feet and precisely zero inches
2 Includes zero feet and suppresses zero inches
3 Includes zero inches and suppresses zero feet
4 Suppresses leading zeros in decimal dimensions (for example, 0.5000 becomes .5000)
8 Suppresses trailing zeros in decimal dimensions (for example, 12.5000 becomes 12.5)
12 Suppresses both leading and trailing zeros (for example, 0.5000 becomes .5)
DIMZIN also affects real-to-string conversions performed by the AutoLISP rtos and angtos functions.
发表于 2005-12-21 11:16:43 | 显示全部楼层
(rtos (atof "-.6") 2 3)
 楼主| 发表于 2005-12-21 20:32:03 | 显示全部楼层
谢谢各位,问题解决了,非常感谢。
发表于 2005-12-22 23:11:38 | 显示全部楼层
高手云集啊
GMT+8, 2026-11-6 19:48 , Processed in 0.428331 second(s), 40 queries , Gzip On.
