查看: 1572|回复: 6
[求助] [求助]:那位大侠帮忙看看这小段程序
发表于 2005-12-21 22:17:10 | 显示全部楼层 |阅读模式
(SetVar "cmdecho" 0)
                    ( Command "circle" p "d" (* m z)
                                "chprop" "l" "" "lt" "dhx" ""
                                "circle" p "d" (* m (- z 2))
                                "chprop" "l" "" "lt" "xx" ""
                                "circle" p "d" (* m (+ z 2))
                    (SetVar "cmdecho" 1)
已领礼包: 12482个
发表于 2005-12-21 23:10:24 | 显示全部楼层
有什么问题?请直接提问。
 楼主| 发表于 2005-12-22 14:44:38 | 显示全部楼层
就是看不懂此程序
发表于 2005-12-22 14:51:52 | 显示全部楼层
是想编一个能自动画圆的程序吗?
你这个根本不对,提出要求大家才能给你解答呀!
 楼主| 发表于 2005-12-22 15:02:52 | 显示全部楼层
以下是整个程序,加载后,出现到修改属性之后不知道该如何操作?
;当前齿数和模数控件的初值
  (SetQ *m* "3" *z* "20")
  ;数据类型检查函数
  (Defun ChkZ (cz)
         (If (And (= 'INT (Type (Read cz))) (> (Read *z*) 17))
              T
              (Progn (Alert "无效的齿数,请重新输入...")
                      (Mode_Tile "z" 2)
                      nil
  (Defun C:T8-1 ()
      ;设置模数基础参数表
         (SetQ ml '(1.0 2.0 2.5 3.0 4.0 5.0 6.0 8.0))
      ;打开并激活对话框
         (New_Dialog "Gear" (Load_Dialog "8-1.dcl"))
      ;按 ml 表填充拉下列表盒的内容
         (Start_List "m")
         (ForEach m ml (Add_List (RToS m 2 1)))
         (End_List)
      ;设各控件的初值
         (Set_Tile "m" *m*) (Set_Tile "z" *z*)
            ;设各控件的动作~给当前的模数和齿数变量赋值
         (Action_Tile "m" "(SetQ *m* $Value)")
         (Action_Tile "z" "(SetQ *z* $Value)")
      ;修改OK按钮的动作~如果 *z*类型正确,再结束对话框
         (Action_Tile "accept" "(If (ChkZ *z*) (Done_Dialog 1))")
      ;对结束码的识别和正常结束后的画图处理
         (If (= 1 (Start_Dialog))
             (Progn (SetQ p (GetPoint "齿轮中心点: ")
                            m (Nth (Read *m*) ml)
                            z (Read *z*)
                     (Command "circle" p "d" (* m z)
        (PrinC)
dcl程序
Gear : dialog
       { label = "Test 8-1";
         : boxed_row
           { label = "Gear";
             : popup_list { label = "m: "; key = "m"; }
             : edit_box   { label = "Z: "; key = "z"; edit_limit = 3; }
         ok_cancel;
已领礼包: 12482个
发表于 2005-12-22 22:41:47 | 显示全部楼层
将"chprop" "l" "" "lt" "dhx" ""中的lt改为la;
将"chprop" "l" "" "lt" "xx" ""中的lt改为la。
而且在程序运行前要先设定好dhx和xx图层。
 楼主| 发表于 2005-12-23 19:19:49 | 显示全部楼层
此程序应该是画出来三个圆的,可是画出来一个后就没有了,只提示让修改属性但是如何才能画出另外的两个圆?
谢谢
GMT+8, 2026-11-2 17:14 , Processed in 0.533677 second(s), 44 queries , Gzip On.
