查看: 1324|回复: 4
[求助] [求助]:请大家帮助看看哪错了?
发表于 2005-12-26 09:19:48 | 显示全部楼层 |阅读模式
;比例放大
(defun c:sf ()
      (setq bl(getdist "\n放大比例:") )
      (prompt "\n选择放大对象<退出>:" )
      (while (setq dm (ssget ))
              (setq  cr(getpoint "\n基点:") ent (ssname dm 0)dd1 (entget ent))
          (command "scale"  dd1 cr BL )
(princ)
已领礼包: 12494个
发表于 2005-12-26 09:32:59 | 显示全部楼层
[php]
;比例放大
(defun c:sf ()
(setq bl (getdist "\n放大比例:"))
(prompt "\n选择放大对象<退出>:")
(setq cr(getpoint "\n基点:"))
(command "scale" dm cr BL)
(princ)
[/php]
 楼主| 发表于 2005-12-26 13:34:42 | 显示全部楼层
还是不对,如下:
sf
放大比例:2
选择放大对象<退出>:
Select objects: Specify opposite corner: 1 found
Select objects:
基点:
*Invalid selection*
Expects a point or
Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P
revious/Undo/AUto/SIngle
发表于 2005-12-26 16:31:46 | 显示全部楼层
(command "scale" dm “” cr BL)
发表于 2005-12-26 18:03:49 | 显示全部楼层
  1. (defun c:sf ()
  2.   (setq bl (getdist "\n放大比例:"))
  3.   (prompt "\n选择放大对象<退出>:")
  4.   (while (setq dm (ssget))
  5.     (setq cr  (getpoint "\n基点:")
  6.     )
  7.     (command "scale" dm "" cr BL "")
  8.   )
  9.   (princ)
  10. )
GMT+8, 2026-11-6 20:48 , Processed in 0.407904 second(s), 40 queries , Gzip On.
