查看: 1581|回复: 10
[求助]:请CAD高手把自己的左手键盘自定义命令公布下
发表于 2005-12-27 23:03:09 | 显示全部楼层 |阅读模式
如题,常见到CAD高手..右手鼠标左手键盘..画图飞快,偶弱弱地想问一下..你们都是怎么设置的呀?比如LINE不是在L键吗?怎么让它在左边区域呀?
发表于 2005-12-27 23:12:35 | 显示全部楼层
好好看一下论坛吧,里面有详尽的设置说明
发表于 2005-12-27 23:13:59 | 显示全部楼层
设置ACAD.PGP
发表于 2005-12-28 00:08:51 | 显示全部楼层
楼主还是按默认的好,不然你这样用习惯了,换一台机就不适应了。
发表于 2005-12-28 15:52:03 | 显示全部楼层
我认识的很多人都是一换机子第一件事情就是重新设置左手键命令
好像很好用
自己也一直想学 但是不知道好不好
大家都来谈谈意见啊
发表于 2005-12-28 21:06:59 | 显示全部楼层
px ; This PGP file was created with the AutoCAD Alias Editor.
; Last modified 2004-11-23   9:38:32
; Use the Alias Editor (EDITALIAS command) to edit this file.
; [Operating System Commands]
2,        Start calc,     0,,
4,        ,               0,*Shell to dos command :,
Del,      Del,            0,*请输入将被删除的文件:,
Dir,      Dir,            0,*请输入待列表的文件:,
Edit,     Start edit,     0,*请输入待编辑的文件:,
Explorer, Start explorer, 0,,
Fcopy,    Copy,           0,*请输入拷贝源文件及目标文件(中间隔以空格):,
Lj,       Cleanmgr,       0,,
Lu,       Layoff,         0,,
Notepad,  Start notepad,  0,*请输入待编辑的文件:,
Osk,      Osk,            0,,
Pbrush,   Start pbrush,   0,,
Ren,      Ren,            0,*请输入改名源文件名及目标文件名(中间隔以空格):,
Sh,       ,               0,*Dos command:,
Start,    Start,          0,*Application to start:,
Type,     Type,           0,*请输入须显示内容的文件名:,
; [AutoCAD Command Aliases]
3A,        *3Darray
3F,        *3Dface
3P,        *3Dpoly
Ad,        *Id
Ae,        *Area
Al,        *Align
Ap,        *Appload
Atp,       *Attdisp
Att,       *Ddattdef
-Att,      *Attdef
Av,        *Dsviewer
jt,        *Arrow
Bd,        *Ptbreak
Bf,        *Dimyi2
Bh,        *Bhatch
Bj,        *Dimyi0
Bl,        *Bmake
-Bl,       *Block
Bo,        *Boundary
-Bo,       *-Boundary
Bq,        *Dimw
By,        *Dimyi1
Cg,        *Chg_lyr
Ch,        *Ddchprop
-Ch,       *Change
Co,        *Ddcolor
Ddv,       *Ddvpoint
Df,        *Dmdiv
Dg,        *Chval
Dgf,       *Recov
Di,        *Dist
Div,       *Divide
Dst,       *Dimstyle
Dt,        *Dtext
Dv,        *Dview
Dx,        *Ddim
Dxi,       *Dxfin
Dxo,       *Dxfout
Dz,        *Dmver
Dzb,       *Maxcha
ee,        *Dimaligned
El,        *Elev
Ell,       *Ellipse
En,        *End
Ew,        *Dimlwf
F,         *Fillet
Fd,        *Enlgvp
Fw,        *Wdrevy
Fz,        *Wdrevx
Gr,        *Ddgrips
-Gr,       *Grid
He,        *Hatchedit
Hl,        *Highlight
Ht,        *Hatch
Hy,        *Mk3vp
Len,       *Lengthen
2P,        *Layfreeze
Ls,        *Ltscale
LSt,        *Linetype
-Lt,       *-Linetype
Lts,       *Ltscale
Me,        *Measure
Mi,        *Mirror
YM,        *Rmarea
Ml,        *Mline
Mmm,       *Wdname
Mn,        *Menu
Mo,        *Ddmodify
Ms,        *Mspace
Mt,        *Mtext
-Mt,       *-Mtext
Mv,        *Mview
N,         *New
Os,        *Ddosnap
-Os,       *-Osnap
Pa,        *Pastespec
Pb,        *Pickbox
Pe,        *Pedit
gg,        *Polygon
Pgp,       *Reinit
Pl,        *Pline
Pn,        *Plan
Po,        *Point
Pol,       *Polygon
Pr,        *Preferences
Pv,       *Preview
Print,     *Plot
Ps,        *Pspace
Pt,        *Plot
Pu,        *Purge
Qc,        *Latopli
Qd,        *Wlmove
Qx,        *Pltola
R,         *Redraw
Ra,        *Redrawall
Rd,        *Redo
Re,        *Rename
-Re,       *Rename
Reg,       *Region
Rev,       *Revolve
Rg,        *Regen
Rga,       *Regenall
Rm,        *Ddrmodes
Rpr,       *Rpref
Scr,       *Script
6,        *Ddselect
-Se,       *Select
Set,       *Setvar
Sl,        *Slice
Sn,        *Snap
So,        *Solid
Sp,        *Splframe
Spe,       *Splinedit
Spl,       *Spline
Ssa,       *Saveas
St,        *Style
Stt,       *Shade
Su,        *Subtract
Ta,        *Tablet
Tb,        *Tbword
Th,        *Thickness
Ti,        *Tilemode
Tol,       *Tolerance
Tor,       *Torus
Tr,        *Trace
Uc,        *Dducs
Ucp,       *Dducsp
Ui,        *Ucsicon
Un,        *Ddunits
-Un,       *Units
Uni,       *Union
V,         *Ddvpoint
-V,        *Vpoint
Vi,        *Ddview
-Vi,       *View
Vs,        *Dmhor1
Vv,        *Vslide
W,         *Wblock
We,        *Wedge
Www,       *Fill
Xa,        *Xattach
Xb,        *Xbind
-Xb,       *-Xbind
Xc,        *Xclip
Xl,        *Xline
Xr,        *Xref
-Xr,       *-Xref
Z,         *Zoom
Z,         *Zoom
Z,         *Zoom
Z,         *Zoom
Z,         *Zoom
Zd,        *Wdbrk
Zg,        *Hword1
zz,        *eledim1
`,         *dimlwf
ttt,       *asctext1
xt,       *Wrinput
A,          *dimmp
dw,        *Dwall
bz,        *Eledim1
66,         *cirwall
c,            *towidth
Ww,        *Chamfer
1,         *Osnap
3,         *Preferences
11,        *layiso
4,         *Laylck
44,        *Layulk
AR,         *Array
As,        *Pan
-As,       *-Pan
Li,        *List
E,         *Erase
Er,        *Extend
La,        *Layer
-La,       *-Layer
Lo,        *Layon
-Lo,       *-Layon
aaa,        *Laycur
Cy,        *Off_lyr
h,        *Layoff
22,         *Quit
dddd,       *Rectangle
Rr,        *Extrim
Rt,        *Rotate
S,         *Stretch
Sc,        *Scale
Ss,        *Qsave
T,         *Trim
To,        *Toolbar
At,        *Ddatte
-At,       *Attedit
dt,         *dmdiv
cj,         *dmcut
Do,        *Donut
tt,            *Copy
pp,         *dsect2
ds,          *dmhor1
sx,          *eleud
hz,            *elelr
XK,        *ddinsert
Aa,        *Ai_propchk
Cc,        *Bhatch
B,          *Break
x,          *Explode
dz,           *edtzb
Y,           *offset
Dd,        *Line
DI,       *Dimmp
I,         *Ddinsert
-I,        *Insert
Im,        *Image
-Im,       *-Image
Ji,         *Join
Hi,         *Hide
Bz,        *Ddedit1
Vd,        *Move
Qq,        *Matchprop
Qw,        *Open
Do,        *Donut
Ff,        *Dist
Fi,        *Filter
Le,        *Leader
ty,           * hword1
eee,     *dimmp
qqq,        *Set_lyr
tf,          *txtrev
dz,        *edtzb
r,           *dimradius
`,          *dimangular
nn,         *wdname
xs,         *chdash
t1,         *dmmge
zzz,         *dmdiv
bg,          *big5_gb
sb,           *wdtodn
ty,      *hword1
t2,      *1to2
fz,   *eleud
zy,   *elelr
d,    *sqrhole
vz,   *dmhor
ax,   *TRectAxis
yz,    *dimyi0
yy,     *indexnum1
fx,     *c_l2pl
wc,     *wdcopy
xw,     *wdin
zc,    *wdinc
mc,    *mocoro
gu,    *GROUP
fd,    *find
;;  TSSD 缩写命令
TS,      *TSSDSET
HTK,     *HZHTK
;;外部接口
TBSA,    *TBSAJK
TCH,     *TZHJK
GS,      *GSHJK
PM,      *PMJK
PMS,     *PMSHD
PZX,     *PMZHX
PZZ,     *PMZHZ
PZL,     *PMZHL
PCL,     *PMCL
PJQ,     *PMJLQ
PZQ,     *PMZHQ
PGJ,     *PMGJ
PCC,     *PMCHC
PWZ,     *PMWZ
PBH,     *PMBH
;;轴网
JZ,      *JXZHW
HZ,      *YHZHW
TZ,      *TJZHX
SZ,      *SHCHZHX
ZJ,      *ZHXJC
XZ,      *XCHZHX
BZ,      *ZHWBZH
DB,      *DZHBH
ZBJ,     *ZHHBJ
YX,      *ZHHYX
DH,      *DHKG
ZBL,     *ZHWXBXSH
;;柱子
CFZ,     *CHFZH
CYZ,     *CHYZH
ZCC,     *ZHCHCBZH
ZYW,     *ZHYWBZH
ZJZ,     *ZHJZHBZH
DZB,     *DZHBZH
ZTS,     *ZHTSH
ZKX,     *ZHKX
JX,      *JXCHL
ZXS,     *ZHXSHBH
ZXB,     *ZHXBXSH
;;梁
ZXL,     *ZHXBL
ZL,      *HZHXL
HL,      *HHXL
LYW,     *LYWBZH
LZ,     *LJZHBZH
LBL,     *LXBL
CL,      *CSHXL
GLK,     *GBLK
LPY,     *LXPY
XLX,     *JXCHL
LLJ,     *LJLX
QCL,     *XCHLX
LXS,     *LXSHBH
LXB,     *LXBXSH
;;剪力墙
ZXQ,     *ZHXBQ
xQ,      *HZHXQ
HQ,      *HHXQ
QJC,     *QXJC
QHF,     *JCHF
GQK,     *GBQK
QPY,     *QXPY
QTC,     *QXTCH
EQ,      *CSHXQ
QBZ,     *QXPMBZH
QKD,     *QSHKD
QFK,     *QDFK
;;板
BSZ,     *BBSHZH
BYZ,     *BYZHB
BKD,     *LBKD
;;基础
ZXX,     *ZHXXBJ
BJC,     *BDLJCH
JJC,     *JCHJC
;;构件计算
LXL,     *LXLJS
JZL,     *JZLJS
JXB,     *JXBJS
JC,      *JCHJS
CT,      *CHTJS
LT,     *LTJS
yMJ,      *MJJS
LLM,     *LLMT
LJM,     *LJM
jm,      *FZHJM
YZ,      *YZHJM
QZ,      *QZHJM
LTP,     *QZHJM
LTT,     *LTXT
LTB,     *LTB
CTT,     *ZHJCHT
ZJP,     *ZHXZHJP
ZJS,     *ZHXZHJS
JJP,     *JTZHJP
JJS,     *JTZHJS
BKP,     *BKZHJP
BKS,     *BKZHJS
TJL,     *WDLTJ
JL2,     *YDLTJ
GJC,     *GXJCHS
DSJ,     *DLSHJ
ZSJ,     *ZHXSHJ
;;钢筋
SG,      *REINSET
GJH,     *GJBH
SBJ,     *SFGJBH
BJH,     *GJHBJ
ZHJ,     *ZDZHJ
jj,      *RYZHJ
FJ,      *ZDFJ
fj,      *RYFJ
DF,      *DKFJ
j,      *TSHHRYJ
DJ,      *HDGJ
DDJ,     *DDGJ
GJ,      *GJ
YXG,     *YXGJ
SJ,      *SXGJ
FDJ,     *FJDJ
FQJ,     *FJGJ
LJ,      *LJ
;;钢筋工具
JYG,     *GJJYG
JXG,     *GJJXG
JZG,     *GJJZHG
eg,     *SHWG
BDJ,     *GBGJDJ
dt,      *YGDD
XG,      *XGDD
PYJ,     *PYGJ
DPY,     *DDPY
JJJ,     *LJGJ
JLT,     *GJLT
SZJ,     *ZHJSHS
SGJ,     *GJSHS
GJB,     *GJCHXB
;;尺寸
ee,     *XXBZH
DQB,     *DQBZH
PYB,     *PXBZH
BKH,     *LKQH
BLZ,     *LQZHB
ZDB,     *ZHDBZH
BJD,     *JDBZH
BHC,     *HCHBZH
BBJ,     *BJBZH
BDK,     *BZHDK
BHB,     *BZHHB
FCD,     *CHDCHL
KDQ,     *KDQQ
XCQ,     *XCHQQ
GCC,     *GCHCZH
BWZ,     *CHCBWZ
ZFZ,     *WZFZH
zS,     *WZYS
;;文字
SZX,     *TEXTSET
DSR,     *DHSHR
DBJ,     *DHBJ
XFZ,     *XFZH
SWZ,     *WZSHR
BJ,      *TYBJ
ZPX,     *WZPX
CK,      *CK
TWZ,     *CHZHTH
TGJ,     *THGJZHJ
CCD,     *CHZCHD
SCD,     *SHCHJCHK
ZWZ,     *WZZHK
FWZ,     *ZHKHF
;;文字工具
HTH,     *FHTH
ZCZ,     *LJCHZ
LWZ,     *LJWZ
WZ2,     *QPWZ
WZ1,     *SHPWZ
CWZ,     *CHFZCH
DWZ,     *WZDD
SFZ,     *WZSF
XWZ,     *WZQX
WZZ,     *WZXZH
GSB,     *GGSHB
GXB,     *GGXB
SHF,     *SHBHF
XHF,     *XBHF
TYZ,     *TYZG
;;表格
ZHB,     *ZHZBG
BJB,     *BJBG
JBJ,     *JBBJBG
GN,      *GNWZ
XXH,     *XXH
JQZ,     *WZJQZH
JHZ,     *WZJHZH
HZB,     *SHCHZHB
QLB,     *SHCHQLB
QSB,     *SHCHQSHB
QZB,     *SHCHQZHB
;;钢结构详图
HXG,     *XGHZH
HLS,     *LSHHZH
BHF,     *HFBZH
;;实体工具
BBL,     *BBL
GXK,     *GBXK
LXD,     *LJXD
LC,      *LXFZH
JD,      *JXDH
XCX,     *XCHCHX
XST,     *XCHSHT
DJD,     *JDDD
CJD,     *JDJC
CTX,     *TXJC
BXS,     *XSHBH
XBL,     *XBXSH
;;其它工具
SXT,     *SYSET
STC,     *LAYERSET
CX,      *XCXSH
CG,      *XCGB
TDS,     *QTDS
GTC,     *TCHGS
ZKG,     *ZKG
TYH,     *TXYH
TK,      *HZHTK
;;常用符号
LD1,     *LDMH1
LD2,     *LDMH2
LD3,     *LDMH3
LD4,     *LDMH4
PF,      *PFBZH
YC,      *YCHBZH
SY,      *SYFH
HMJ,     *MJHZH
LF,      *LJFH
PD,      *PDX
PP,      *PMPQ
JP,      *JMPQ
BGg,      *BGHZH
BBG,     *BGBJ
DC,      *DCHFH
TM,      *TXMCH
ZBZ,     *ZHBZH
ZB,      *BZBD
;;墙柱截面qz
QZ1,     *QZHJM1
QZ2,     *QZHJM2
QZ3,     *QZHJM3
QZ4,     *QZHJM4
QZ5,     *QZHJM5
QZ6,     *QZHJM6
QZ7,     *QZHJM7
QZ8,     *QZHJM8
QZ9,     *QZHJM9
QZ0,     *QZHJM10
;;里正
; The following are alternative aliases and aliases as supplied in AutoCAD Release 13.
AV,        *DSVIEWER
CP,        *COPY
DIMALI,    *DIMALIGNED
DIMANG,    *DIMANGULAR
DIMBASE,   *DIMBASELINE
DIMCONT,   *DIMCONTINUE
DIMDIA,    *DIMDIAMETER
DIMED,     *DIMEDIT
DIMTED,    *DIMTEDIT
DIMLIN,    *DIMLINEAR
DIMORD,    *DIMORDINATE
DIMRAD,    *DIMRADIUS
DIMSTY,    *DIMSTYLE
DIMOVER,   *DIMOVERRIDE
LEAD,      *LEADER
TM,        *TILEMODE
LL,        *LDLIN
;The following are added by Leading software Inc.
;LZ_DRAWTOOLS_COMMAND_BEGIN (DO NOT CHANGE THIS LINE)
LL,        *LDLIN
LXK,        *LESLN
LAL,        *LZAEL
LDL,        *LZDEL
LAP,        *LZAPT
LDP,        *LZDPT
LBK,        *LZBKL
LMV,        *LZMVL
LZH,        *LZXLA
GG,        *LDSTL
GBZ,        *LZSTN
GXK,        *LESTLP
GAG,        *LZAHK
GDG,        *LZDHK
GHG,        *LZXHK
GBX,        *LZEHK
GXM,        *LZMVS
GAL,        *LZAES
GDL,        *LZDES
GBH,        *LEMSTB
GLT,        *LESTLTHR
WT,        *LDTXT
WLX,        *LDTCD
WED,        *LETML
WLXE,        *LETCE
WTP,        *LETMD
WTUP,        *LETUP
WFH,        *LETOM
WTH,        *LETTT
WJH,        *LETCP
WHJ,        *LETRS
WFJ,        *LETHE
WZH,        *LETSL
WF,        *LETWF
WS,        *LZNPT
CC,        *LDDIM
CXX,        *LDLNR
CDQ,        *LDALI
CZJ,        *LDDIA
CTD,        *LEDIMSCL
BJD,        *LDSHT
BML,        *LDTAB2
BCG,        *LDFLY
BGJ,        *LDTAB1
BPF,        *LDTAB3
ZXt,        *LDAXE
ZW,        *LDNET
ZXG,        *LECAT
ZXA,        *LEAXA
ZCC,        *LEADM
ZTH,        *LEANO
JH,        *LDGEO
JHR,        *LDFP
JHG,        *LECEO
JHRG,        *LECFP
FBG,        *LDLM
FBZ,        *LDLDR
FGZ,        *LDLDS
FGJ,        *LDLDB
FDU,        *LDLDM
FSY,        *LDDEX
FDC,        *LDSYM
FPQ,        *LDSEC
FLJ,        *LDJNT
FBH,        *LDNUM
FTM,        *LDTAG
FPD,        *LDGRD
FLJG,        *LECJN
FBHG,        *LECNO
FTMG,        *LECTG
FPDG,        *LECGR
SXG,        *LDSTE
SHFB,        *LDHF
SLSB,        *LDLS
SHF,        *LDHGD
SLS,        *LDLGD
SXGG,        *LECST
SHFBG,        *LECHF
SLSBG,        *LECLS
SHFG,        *LECHGD
SLSG,        *LECLGD
CL,        *LZDISL
SD,        *LZLBSD
DIS,        *LZDIS
GJSC,        *LZMGJA
;LZ_DRAWTOOLS_COMMAND_END (DO NOT CHANGE THIS LINE)
发表于 2005-12-28 21:16:15 | 显示全部楼层
左手间只有好处,关键在设置,日久生情。
发表于 2005-12-28 21:16:23 | 显示全部楼层
刚开始学就是要怎么快怎么来
有了动力才能学下去
个人观点
发表于 2005-12-28 22:40:40 | 显示全部楼层
就是设置ACAD.PGP,所有的左手键都有设置,没有改变原来的键盘设置,两个都是可以用的!
把这个文件复制到:
C:\Documents and Settings\用户名\Application Data\Autodesk\AutoCAD 2004\R16.0\chs\Support
覆盖原文件就可以了!
发表于 2005-12-28 22:44:51 | 显示全部楼层
同时配上相关的左手CAD快捷键的对应表!
发表于 2005-12-28 22:49:23 | 显示全部楼层
我一直用的是默认的设置,只有用得顺手,都差不多的,看个人习惯,
GMT+8, 2026-11-7 10:29 , Processed in 0.465022 second(s), 53 queries , Gzip On.
