查看: 862|回复: 8
[求助]:cad2006,命令
发表于 2005-12-29 16:04:32 | 显示全部楼层 |阅读模式
我刚用cad2006没有多久,想知道,怎么修改命令的快捷键,好想和cad以前的版本不太一样,比如在pgp文件中把L,×line,改成Li,×line,好像不能用呀?
有人可以指导一下怎么修改快捷键吗?*-*5
发表于 2005-12-29 16:13:12 | 显示全部楼层
菜单:工具--自定义--编辑程序参数(acad.pgp)
 楼主| 发表于 2005-12-29 16:22:28 | 显示全部楼层
可以了!!!谢谢!!!
发表于 2005-12-30 14:59:54 | 显示全部楼层
现在想问句,就是下边的命令的快捷键,可以改成自己熟悉的命令么(怎么改,能说下么),呵呵,现在我不敢改,请高手指点!!谢谢!!!
3A,        *3DARRAY
3DO,       *3DORBIT
3F,        *3DFACE
3P,        *3DPOLY
A,         *ARC
AC,        *BACTION
ADC,       *ADCENTER
AA,        *AREA
AL,        *ALIGN
AP,        *APPLOAD
AR,        *ARRAY
-AR,       *-ARRAY
ATT,       *ATTDEF
-ATT,      *-ATTDEF
ATE,       *ATTEDIT
-ATE,      *-ATTEDIT
ATTE,      *-ATTEDIT
B,         *BLOCK
-B,        *-BLOCK
BC,        *BCLOSE
BE,        *BEDIT
BH,        *HATCH
BO,        *BOUNDARY
-BO,       *-BOUNDARY
BR,        *BREAK
BS,        *BSAVE
C,         *CIRCLE
CH,        *PROPERTIES
-CH,       *CHANGE
CHA,       *CHAMFER
CHK,       *CHECKSTANDARDS
CLI,       *COMMANDLINE
COL,       *COLOR
COLOUR,    *COLOR
CO,        *COPY
CP,        *COPY
CT,        *CTABLESTYLE
D,         *DIMSTYLE
DAL,       *DIMALIGNED
DAN,       *DIMANGULAR
DAR,       *DIMARC
JOG,       *DIMJOGGED
DBA,       *DIMBASELINE
DBC,       *DBCONNECT
DC,        *ADCENTER
DCE,       *DIMCENTER
DCENTER,   *ADCENTER
DCO,       *DIMCONTINUE
DDA,       *DIMDISASSOCIATE
DDI,       *DIMDIAMETER
DED,       *DIMEDIT
DI,        *DIST
DIV,       *DIVIDE
DJO,       *DIMJOGGED
DLI,       *DIMLINEAR
DO,        *DONUT
DOR,       *DIMORDINATE
DOV,       *DIMOVERRIDE
DR,        *DRAWORDER
DRA,       *DIMRADIUS
DRE,       *DIMREASSOCIATE
DRM,       *DRAWINGRECOVERY
DS,        *DSETTINGS
DST,       *DIMSTYLE
DT,        *TEXT
DV,        *DVIEW
E,         *ERASE
ED,        *DDEDIT
EL,        *ELLIPSE
EX,        *EXTEND
EXIT,      *QUIT
EXP,       *EXPORT
EXT,       *EXTRUDE
F,         *FILLET
FI,        *FILTER
G,         *GROUP
-G,        *-GROUP
GD,        *GRADIENT
GR,        *DDGRIPS
H,         *HATCH
-H,        *-HATCH
HE,        *HATCHEDIT
HI,        *HIDE
I,         *INSERT
-I,        *-INSERT
IAD,       *IMAGEADJUST
IAT,       *IMAGEATTACH
ICL,       *IMAGECLIP
IM,        *IMAGE
-IM,       *-IMAGE
IMP,       *IMPORT
IN,        *INTERSECT
INF,       *INTERFERE
IO,        *INSERTOBJ
J,         *JOIN
L,         *LINE
LA,        *LAYER
-LA,       *-LAYER
LE,        *QLEADER
LEN,       *LENGTHEN
LI,        *LIST
LINEWEIGHT, *LWEIGHT
LO,        *-LAYOUT
LS,        *LIST
LT,        *LINETYPE
-LT,       *-LINETYPE
LTYPE,     *LINETYPE
-LTYPE,    *-LINETYPE
LTS,       *LTSCALE
LW,        *LWEIGHT
M,         *MOVE
MA,        *MATCHPROP
ME,        *MEASURE
MI,        *MIRROR
ML,        *MLINE
MO,        *PROPERTIES
MS,        *MSPACE
MSM,       *MARKUP
MT,        *MTEXT
MV,        *MVIEW
O,         *OFFSET
OP,        *OPTIONS
ORBIT,     *3DORBIT
OS,        *OSNAP
-OS,       *-OSNAP
P,         *PAN
-P,        *-PAN
PA,        *PASTESPEC
PARAM,     *BPARAMETER
PARTIALOPEN, *-PARTIALOPEN
PE,        *PEDIT
PL,        *PLINE
PO,        *POINT
POL,       *POLYGON
PR,        *PROPERTIES
PRCLOSE,   *PROPERTIESCLOSE
PROPS,     *PROPERTIES
PRE,       *PREVIEW
PRINT,     *PLOT
PS,        *PSPACE
PTW,       *PUBLISHTOWEB
PU,        *PURGE
-PU,       *-PURGE
QC,        *QUICKCALC
R,         *REDRAW
RA,        *REDRAWALL
RE,        *REGEN
REA,       *REGENALL
REC,       *RECTANG
REG,       *REGION
REN,       *RENAME
-REN,      *-RENAME
REV,       *REVOLVE
RO,        *ROTATE
RPR,       *RPREF
RR,        *RENDER
S,         *STRETCH
SC,        *SCALE
SCR,       *SCRIPT
SE,        *DSETTINGS
SEC,       *SECTION
SET,       *SETVAR
SHA,       *SHADEMODE
SL,        *SLICE
SN,        *SNAP
SO,        *SOLID
SP,        *SPELL
SPL,       *SPLINE
SPE,       *SPLINEDIT
SSM,       *SHEETSET
ST,        *STYLE
STA,       *STANDARDS
SU,        *SUBTRACT
T,         *MTEXT
-T,        *-MTEXT
TA,        *TABLET
TB,        *TABLE
TH,        *THICKNESS
TI,        *TILEMODE
TO,        *TOOLBAR
TOL,       *TOLERANCE
TOR,       *TORUS
TP,        *TOOLPALETTES
TR,        *TRIM
TS,        *TABLESTYLE
UC,        *UCSMAN
UN,        *UNITS
-UN,       *-UNITS
UNI,       *UNION
V,         *VIEW
-V,        *-VIEW
VP,        *DDVPOINT
-VP,       *VPOINT
VS,        *BVSTATE
W,         *WBLOCK
-W,        *-WBLOCK
WE,        *WEDGE
X,         *EXPLODE
XA,        *XATTACH
XB,        *XBIND
-XB,       *-XBIND
XC,        *XCLIP
XL,        *XLINE
XR,        *XREF
-XR,       *-XREF
Z,         *ZOOM
发表于 2005-12-30 19:15:46 | 显示全部楼层
我的改了之后怎么不管用呀,(我改了一个保存了,不行,还是原来的命令/我把E改成1!
),有什么错误的地方吗,请高手指教!
发表于 2005-12-31 09:39:51 | 显示全部楼层 |阅读模式
你可能改错地方了,只是把前面的缩写改成你习惯用的就可以了,一般这个.pgp文件存在C盘C:\Documents and Settings\用户名\Application Data\Autodesk\AutoCAD 2006\R16.2\enu\Support里,改一下保存,然后重新启动CAD,就可以了
发表于 2005-12-31 10:36:26 | 显示全部楼层
好像我的autocad2006没有C:\Documents and Settings\用户名\Application Data\Autodesk\AutoCAD 2006\R16.2\enu\Support这个目录哦。
发表于 2005-12-31 10:47:16 | 显示全部楼层
进sys文件夹,用计事本打开acad.pgp文件,直接改成想用的快捷键,保存就可以了~
发表于 2005-12-31 10:50:54 | 显示全部楼层
最初由 caowang23 发布
[B]你可能改错地方了,只是把前面的缩写改成你习惯用的就可以了,一般这个.pgp文件存在C盘C:\Documents and Settings\用户名\Application Data\Autodesk\AutoCAD 2006\R16.2\enu\Support里,改一下保存,然后重新启动CAD,就... [/B]
不要到深闺里去找她。
1楼主改好并存盘后,reinit 命令使之立即生效即可,不要重启。
GMT+8, 2026-8-30 11:55 , Processed in 0.416398 second(s), 49 queries , Gzip On.
