查看: 822|回复: 1
[求助] [求助]:请教怎么用command调用INSERT命令
发表于 2006-1-7 10:55:29 | 显示全部楼层 |阅读模式
我这样调用的:
(setq pt'(list 0 0 0))
(command "insert" "blkname" pt)
好象不行的,比例怎么加上去。
块作出来后能直接显示吗?/
已领礼包: 9347个
发表于 2006-1-7 11:09:02 | 显示全部楼层
Command: -insert
Enter block name or [?] <Last>: 0000   ; <====== BlockName
Specify insertion point or [Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]: 100,100
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>: 2
Enter Y scale factor <use X scale factor>: 2
Specify rotation angle <0>:
(command "insert" "blkname" pt 2 2 0)    ; <---- 2=scale
GMT+8, 2026-11-6 21:50 , Processed in 0.369283 second(s), 34 queries , Gzip On.
