查看: 1026|回复: 2
[求助] [求助]:netbee 版主请你帮帮我都搞好几天了!!
发表于 2006-1-21 22:03:07 | 显示全部楼层 |阅读模式
netbee 版主您好!!我下载你的轴网和轴网标注软件真是太棒了。
但有个问题想请你帮助解决,
我在CAD2006里加载你的程序一切正常,但我加载另外两个程序(画外墙和画内墙程序)轴网标注就不好用了。不知那里有冲突请您帮我看看如何,我很需要这两个程序(已经用很长时间用习惯),我在此跪谢了!!
画外墙代码如下:
  1. (defun *error*(st)
  2.   (if (and (/= st "Function cancelled")
  3.            (/= st "quit / exit abort")
  4.       )
  5.       (princ (strcat "错误: " st))
  6.   )
  7.   (setq *error* old_err)
  8.   (princ)
  9. )
  10. (defun dxf (code en)
  11.   (cdr (assoc code en))
  12. )
  13. (defun tan (ang)
  14.   (/ (sin ang) (cos ang))
  15. )
  16. ;;;==============================================
  17. ;;;               main   programm
  18. ;;;==============================================
  19. (defun C:wwall(/ th ss bp sp ep pt1 pt2 pt3 pt4 n tmp bbp ssp)
  20.   (setq old_err *error*)
  21.   (setvar "CMDECHO" 0)
  22.   (setvar "BLIPMODE" 0)
  23.   (command "layer" "m" "wall" "c" "w" "wall" "")
  24.   (setvar "osmode" 32)
  25.   (if (= thw nil) (setq thw 360.0))
  26.   (setq th (getreal (strcat "\n外墙厚<" (rtos thw 2 0) ">:")))
  27.     (if (= th nil) (setq th thw))
  28.     (setq thw th)
  29.   (if (= thlsw nil) (setq thlsw 240.0))
  30.   (setq thls (getreal (strcat "\n轴线外的墙厚<" (rtos thlsw 2 0) ">:")))
  31.     (if (= thls nil) (setq thls thlsw))           ;thls轴线外墙厚
  32.     (setq thlsw thls)
  33.   (setq thrx (- th thls))                         ;thrx轴线内墙厚
  34.   (setq bp (getpoint "\n第一点: "))
  35.   (setq bbp bp)                                   ;bbp记录下第一点
  36.   (if (= nil bp) (quit))
  37.   (setq sp (getpoint bp "\n下一点(注意:按顺时针): "))
  38.   (setq ssp sp)                                   ;ssp记录下第二点
  39.   (setvar "osmode" 0)
  40.   (if (= nil sp) (quit))
  41.   (setq n 0 tmp 0)         ;n=0为第一条线  ;tmp=0
  42.   (while T
  43.     (setq ang1 (angle bp sp))
  44.     (setq dis1 (distance bp sp))
  45.     (setq pt1 (polar bp (+ ang1 (* pi 0.5)) thls))
  46.     (setq pt2 (polar pt1 ang1 dis1))
  47.     (if (= 0 n)
  48.       (command "line" pt1 pt2 "")
  49.       (command "line" pt11 pt2 "")
  50.     )
  51.     (setq ss (ssadd))
  52.     (setq ss (ssget "L"))
  53.     (setq pt3 (polar bp (- ang1 (* pi 0.5)) thrx))
  54.     (setq pt4 (polar pt3 ang1 dis1))
  55.     (if (= 0 n)
  56.       (command "line" pt3 pt4 "")
  57.       (command "line" pt33 pt4 "")
  58.     )
  59.     (setq ss (ssadd (entlast) ss))
  60.     (if (= 1 tmp) (command "erase" ss ""))
  61.     (if (= nil ep)
  62.       (progn
  63.         (if (= 1 tmp)
  64.           (progn
  65.             (redraw)
  66.             (quit)
  67.           )
  68.           (progn
  69.             (setvar "osmode" 32)
  70.             (initget "C")
  71.             (setq ep (getpoint sp "\nC闭合/下一点: "))
  72.             (setvar "osmode" 0)
  73.           )
  74.         )
  75.         (if (= nil ep) (quit))
  76.         (if (eq ep "C") (setq ep bbp))
  77.         (setq ang2 (angle sp ep))
  78.         (setq ang3 (- pi ang1))
  79.         (setq ang4 (- (* pi 2) ang2))
  80.         (setq ang3 (- (/ pi 2) (/ (- ang3 ang4) 2)))
  81.         (setq dis2 (distance sp ep))
  82.         (setq dis3 (* thls (tan ang3)))
  83.         (setq dis4 (* thrx (tan ang3)))
  84.         (setq pt1 (polar bp (+ ang1 (* pi 0.5)) thls))
  85.         (setq pt2 (polar pt1 ang1 (+ dis1 dis3)))
  86.         (command "erase" ss "")
  87.         (if (= 0 n)
  88.           (progn
  89.             (command "line" pt1 pt2 "")
  90.             (setq sss (ssadd))
  91.             (setq sss (ssget "L"))
  92.           )
  93.           (command "line" pt11 pt2 "")
  94.         )
  95.         (setq pt3 (polar bp (- ang1 (* pi 0.5)) thrx))
  96.         (setq pt4 (polar pt3 ang1 (- dis1 dis4)))
  97.         (if (= 0 n)
  98.           (progn
  99.             (command "line" pt3 pt4 "")
  100.             (setq sss (ssadd (entlast) sss))
  101.           )
  102.           (command "line" pt33 pt4 "")
  103.         )
  104.       )
  105.       (progn
  106.         (command "erase" sss "")
  107.         (setq ang2 (angle sp ep))
  108.         (setq ang3 (- pi ang1))
  109.         (setq ang4 (- (* pi 2) ang2))
  110.         (setq ang3 (- (/ pi 2) (/ (- ang3 ang4) 2)))
  111.         (setq dis2 (distance sp ep))
  112.         (setq dis3 (* thls (tan ang3)))
  113.         (setq dis4 (* thrx (tan ang3)))
  114.         (setq pt1 (polar bp (+ ang1 (* pi 0.5)) thls))
  115.         (setq pt2 (polar pt1 ang1 (+ dis1 dis3)))
  116.         (command "erase" ss "")
  117.         (command "line" pt11 pt2 "")
  118.         (setq ss (ssadd))
  119.         (setq ss (ssget "L"))
  120.         (setq pt3 (polar bp (- ang1 (* pi 0.5)) thrx))
  121.         (setq pt4 (polar pt3 ang1 (- dis1 dis4)))
  122.         (command "line" pt33 pt4 "")
  123.         (setq ss (ssadd (entlast) ss))
  124.         (command "line" pt2 pte1 "")
  125.         (command "line" pt4 pte2 "")
  126.         (setq tmp 1)
  127.       )
  128.     )
  129.     (if (= 0 n)
  130.       (setq pte1 pt2 pte2 pt4)
  131.     )
  132.     (setq pt11 pt2 pt33 pt4)
  133.     (setq bp sp sp ep n 1)
  134.     (if (equal bbp ep)
  135.       (setq ep ssp)
  136.       (setq ep nil)
  137.     )
  138.   )
  139.   (princ)
  140. )
这是画内墙的:
  4.       )
  6.   )
  8.   (princ)
  9. )
  10. (defun sort (l tst1 tst2 / lt ltem vmax vmin l1 l2 l3
  11.              lt0 ltem0 ltem1 l30 vmax0 vmin0 l10 l20)
  12.   (setq ltem (mapcar 'car l)                    ;ltem :  取出l的第一项形成的表
  13.         vmin (1- (apply 'min ltem))             ;vmin :  是一个比ltem中最小的数还小的数
  14.   )
  15.   (while (< vmin (setq vmax (apply 'max ltem)))        ;从ltem中取出最大值
  16.     (setq l1 l l3 nil ltem (subst vmin vmax ltem))     ;去掉最大值
  17.     (while (setq l2 (assoc vmax l1))                   ;取出最大值所对应的项
  18.       (setq l1 (cdr (member l2 l1)))                   ;处理相同的值
  19.       (setq l3 (cons l2 l3))
  20.     )
  21.     (progn                                         ;如果X相等, 对Y排序
  22.       (setq ltem0 (mapcar 'cadr l3)
  23.             ltem1 (mapcar 'car l3)
  24.             l30   (mapcar 'cdr l3)
  25.             vmin0 (1- (apply 'min ltem0))
  26.       )
  27.       (while (< vmin0 (setq vmax0 (apply 'max ltem0)))
  28.         (setq l10 l30 ltem0 (subst vmin0 vmax0 ltem0))
  29.         (while (setq l20 (assoc vmax0 l10))
  30.           (setq l10 (cdr (member l20 l10)))
  31.           (setq lt0 (cons l20 lt0))
  32.         )
  33.       )
  34.       (setq l3 (mapcar 'cons ltem1 lt0))
  35.       (if tst1 (setq l3 (reverse l3)))                 ;tst1,tst2控制排序顺序
  36.     )
  37.     (setq lt (append l3 lt))
  38.   )
  39.   (if tst2 (setq lt (reverse lt)) (setq lt lt))
  40. )
  41. (defun dxf (code en)
  42.   (cdr (assoc code en))
  43. )
  44. (defun dxf1 (code en)
  45.   (cdr (assoc code (entget en)))
  46. )
  47. (defun tan (ang)
  48.   (/ (sin ang) (cos ang))
  49. )
  50. (defun pross (bp sp bp0 sp0 bpm spm ne tst / tem ss ss0 n el ip lpt lpt0
  51.               a en en0 pt pt0 ne ne0 i j tst1 tst2 t1 t2 t10 t20)
  52.   (setq ne0 ne)
  53.   (if (or (> (car bp) (car sp))
  54.           (and (= (car bp) (car sp)) (> (cadr bp) (cadr sp)))
  55.       )
  56.     (setq t1 nil t2 t tem T)
  57.     (setq t1 nil t2 nil tem T)
  58.   )
  59.   (if (or (> (car bp0) (car sp0))
  60.           (and (= (car bp0) (car sp0)) (> (cadr bp0) (cadr sp0)))
  61.       )
  62.     (setq t10 nil t20 t)
  63.     (setq t10 nil t20 nil)
  64.   )
  65.   (setq ss nil)
  66.   (if (setq ss (ssget "c" bp sp))
  67.     (progn
  68.       (setq n 0)
  69.       (repeat (sslength ss)
  70.         (setq el (entget (setq en (ssname ss n))))
  71.         (if (and (= (dxf 0 el) "LINE")
  72.                  (= (dxf 8 el) "WALL")
  73.                  (setq ip (inters bp sp (dxf 10 el) (dxf 11 el)))
  74.             )                    ; ip 交点
  75.             (if (> (distance ip bp) 0.01) (setq lpt (cons ip lpt)))
  76.         )
  77.         (setq n (1+ n))
  78.       )         ; repeat 找出所有的交点并形成表lpt
  79.       (if (/= nil lpt) (setq lpt (sort lpt t1 t2)))
  80.     )
  81.   )
  82.   (setq ss0 nil)
  83.   (if (setq ss0 (ssget "c" bp0 sp0))
  84.     (progn
  85.       (setq n 0)
  86.       (repeat (sslength ss0)
  87.         (setq el (entget (setq en (ssname ss0 n))))
  88.         (if (and (= (dxf 0 el) "LINE")
  89.                  (= (dxf 8 el) "WALL")
  90.                  (setq ip (inters bp0 sp0 (dxf 10 el) (dxf 11 el)))
  91.             )                    ; ip 交点
  92.             (if (> (distance ip bp0) 0.01) (setq lpt0 (cons ip lpt0)))
  93.         )
  94.         (setq n (1+ n))
  95.       )         ; repeat 找出所有的交点并形成表lpt
  96.       (if (/= nil lpt0) (setq lpt0 (sort lpt0 t10 t20)))
  97.     )
  98.   )
  99.   (setq i 1)
  100.   (if (/= nil lpt)
  101.     (foreach pt lpt
  102.       (setq ss nil)
  103.       (setq ss (ssget "c" (polar pt (* pi 1.25) 1) (polar pt (* pi 0.25) 1)))
  104.       (setq en (ssname ss 0))
  105.       (setq j 1)
  106.       (foreach pt0 lpt0
  107.         (setq ss0 nil)
  108.         (setq ss0 (ssget pt0))
  109.         (setq en0 (ssname ss0 0))
  110.         (if (= i j)
  111.           (progn
  112.             (if (equal en en0)
  113.               (command "break" en pt pt0)
  114.               (progn
  115.                 (setq ip (inters (dxf1 10 en) (dxf1 11 en) (dxf1 10 en0) (dxf1 11 en0)))
  116.                 (if (= ip nil)
  117.                   (progn
  118.                     (if (< (distance (dxf1 10 en) pt) (distance (dxf1 11 en) pt))
  119.                       (command "break" en pt (dxf1 10 en))
  120.                       (command "break" en pt (dxf1 11 en))
  121.                     )
  122.                     (if (< (distance (dxf1 10 en0) pt0) (distance (dxf1 11 en0) pt0))
  123.                       (command "break" en0 pt0 (dxf1 10 en0))
  124.                       (command "break" en0 pt0 (dxf1 11 en0))
  125.                     )
  126.                   )
  127.                   (progn
  128.                     (if (< (distance (dxf1 10 en) ip) 0.001) (setq ip (dxf1 10 en)))
  129.                     (if (< (distance (dxf1 11 en) ip) 0.001) (setq ip (dxf1 11 en)))
  130.                     (command "break" en pt ip)
  131.                     (if (< (distance (dxf1 10 en0) ip) 0.001) (setq ip (dxf1 10 en0)))
  132.                     (if (< (distance (dxf1 11 en0) ip) 0.001) (setq ip (dxf1 11 en0)))
  133.                     (command "break" en0 pt0 ip)
  134.                   )
  135.                 )
  136.               )
  137.             )
  138.           )
  139.         )
  140.         (setq j (1+ j))
  141.       )
  142.       (setq i (1+ i))
  143.     )
  144.   )
  145.       (setq tst1 tst)
  146.       (if (/= nil lpt)
  147.         (progn
  148.           (foreach pt lpt
  149.             (if (= tst1 T)
  150.               (if (> (distance bp pt) 500) (setq ne 0 tst1 nil))
  151.             )
  152.             (if (= 0 ne)
  153.               (progn
  154.                 (command "line" bp pt "")
  155.                 (setq ne 1)
  156.               )
  157.               (setq ne 0)
  158.             )
  159.             (setq bp pt)
  160.           )
  161.         )
  162.       )
  163.       (if (= 0 ne) (command "line" bp sp ""))
  164.       (setq tst2 tst)
  165.       (if (/= nil lpt0)
  166.         (progn
  167.           (foreach pt0 lpt0
  168.             (if (= tst2 T)
  169.               (if (> (distance bp0 pt0) 500) (setq ne0 0 tst2 nil))
  170.             )
  171.             (if (= 0 ne0)
  172.               (progn
  173.                 (command "line" bp0 pt0 "")
  174.                 (setq ne0 1)
  175.               )
  176.               (setq ne0 0)
  177.             )
  178.             (setq bp0 pt0)
  179.           )
  180.         )
  181.       )
  182.       (if (= 0 ne0) (command "line" bp0 sp0 ""))
  183. )
  184. ;;;==============================================
  185. ;;;               main   programm
  186. ;;;==============================================
  187. (defun C:nwall(/ th bp sp n ang1 dis1 ss ang2 ang3 ang4 dis2 dis3 dis4
  188.              ep pt1 pt2 pt3 pt4 pt11 pt33 ne tst ts loop)
  189.   (setq old_err *error*)
  190.   (setvar "CMDECHO" 0)
  191.   (setvar "BLIPMODE" 0)
  192.   (command "layer" "m" "wall" "c" "w" "wall" "")
  193.   (princ "\n说明: 缺省为INT捕捉方式, 如不是请自己敲入 !")
  194.   (if (= th0 nil) (setq th0 240.0))
  195.   (setq th (getreal (strcat "\n内墙厚<" (rtos th0 2 0) ">:")))
  196.     (if (= th nil) (setq th th0))
  197.     (setq th0 th)
  198.   (setq loop T)
  199.   (setvar "osmode" 32)
  200.   (while loop
  201.     (initget 1 "R")
  202.     (setq bp (getpoint "\nR参照点/<第一点>: "))
  203.     (cond
  204.       ((eq bp "R") (progn
  205.                      (setq bp (getpoint "\n参照点: "))
  206.                      (setq bp (getpoint bp "\n@X,Y 或 @长度<角度: "))
  207.                      (setq loop nil)
  208.                     ))
  209.       (t (setq loop nil))
  210.     )
  211.   )
  212.   (setvar "osmode" 0)
  213.   (if (= nil bp) (quit))
  214.   (setvar "osmode" 32)
  215.   (setq sp (getpoint bp "\n下一点: "))
  216.   (if (= nil sp) (quit))
  217.   (setvar "osmode" 0)
  218.   (setq n 0 tst T)
  219.   (while tst
  220.     (setq ang1 (angle bp sp))
  221.     (setq dis1 (distance bp sp))
  222.     (setq pt1 (polar bp (+ ang1 (* pi 0.5)) (/ th 2.0)))
  223.     (setq pt2 (polar pt1 ang1 dis1))
  224.     (setq pt3 (polar bp (- ang1 (* pi 0.5)) (/ th 2.0)))
  225.     (setq pt4 (polar pt3 ang1 dis1))
  226.
  227.     (if (= 0 n)
  228.       (command "line" pt1 pt2 "")
  229.       (command "line" pt11 pt2 "")
  230.     )
  231.     (setq ss (ssadd))
  232.     (setq ss (ssget "L"))
  233.     (if (= 0 n)
  234.       (command "line" pt3 pt4 "")
  235.       (command "line" pt33 pt4 "")
  236.     )
  237.     (setq ss (ssadd (entlast) ss))
  238.     (setvar "osmode" 32)
  239.     (setq ep (getpoint sp "\n下一点: "))
  240.     (setvar "osmode" 0)
  241.     (if (= nil ep)
  242.       (progn
  243.         (setq ep sp)
  244.         (setq tst nil)
  245.       )
  246.     )
  247.     (setq ang2 (angle sp ep))
  248.     (setq ang3 (- pi ang1))
  249.     (setq ang4 (- (* pi 2) ang2))
  250.     (setq ang3 (- (/ pi 2) (/ (- ang3 ang4) 2)))
  251.     (setq dis2 (distance sp ep))
  252.     (setq dis3 (* (/ th 2) (tan ang3)))
  253.     (setq dis4 (* (/ th 2) (tan ang3)))
  254.     (if (= sp ep) (setq dis3 0 dis4 0))
  255.     (setq pt1 (polar bp (+ ang1 (* pi 0.5)) (/ th 2.0)))
  256.     (setq pt2 (polar pt1 ang1 (+ dis1 dis3)))
  257.     (setq pt3 (polar bp (- ang1 (* pi 0.5)) (/ th 2.0)))
  258.     (setq pt4 (polar pt3 ang1 (- dis1 dis4)))
  259.     (command "erase" ss "")
  260.     (if (= 0 n)
  261.       (progn
  262.         (setq ne 1 ts T)
  263.         (pross pt1 pt2 pt3 pt4 bp sp ne ts)
  264.       )
  265.       (progn
  266.         (setq ne 0 ts nil)
  267.         (pross pt11 pt2 pt33 pt4 bp sp ne ts)
  268.       )
  269.     )
  270.     (setq pt11 pt2 pt33 pt4)
  271.     (setq bp sp sp ep n 1 ts nil)
  272.   )
  273.   (princ)
  274. )
发表于 2006-1-23 13:21:42 | 显示全部楼层
这段时间没怎么上网了,今天才看见帖子。见谅。。。。
经测试这段程序与轴线绘制冲突在函数定义:。
  1. (DEFUN dxf (st ss) (CDR (ASSOC st (ENTGET ss))))
你将上面的函数定义放在我的轴线标注程序段的前面即可。
外墙程序运行通过。
内墙程序会删除第一段墙,这是程序内判断第一段墙的地方绘制有问题,与轴线绘制程序无关。
由于没有时间详读你的程序,只是大体判断了一下,你再仔细查查。
 楼主| 发表于 2006-1-23 16:38:09 | 显示全部楼层
谢谢netbee  版主的回复!!
轴线好了但内墙不好用。
不过我又找到一个更好的绘墙程序,不知是那位大师编的。
和您的轴线、轴标配和使用很方便有自动剪切功能。
我在这里传上来和大家分享一下,可惜没有源码。程序捕捉点清零这一点用起来不太方便,如果那位有源码希望能共享一下。
绘墙程序CAD2006下通过
在次感谢netbee  版主 谢谢!!
GMT+8, 2026-11-6 23:39 , Processed in 0.542293 second(s), 36 queries , Gzip On.
