查看: 1059|回复: 0
[LISP程序]:[LISP程序]:实际距离偏移
发表于 2006-1-22 12:34:00 | 显示全部楼层 |阅读模式
  1. 在用不同比例绘图时可以使用
复制代码
[php](Defun c:OO (/ Factor Offset_Dis)
  (Setvar "Cmdecho" 0)
  (Setq Factor (Getvar "Dimlfac"))
  (Princ
    (Strcat "\n**提示:当前绘图比例为 " (Rtos Factor 2 0) " **")
  (If (Null *Offset_Dis*)
    (Setq *Offset_Dis* 3000)
  (If (Setq
        Offset_Dis
         (Getdist
           (Strcat "\n偏移的实际距离:<" (Rtos *Offset_Dis* 2 2) ">")
    (Setq *Offset_Dis* Offset_Dis)
    (Setq Offset_Dis *Offset_Dis*)
  (Command "Offset" (/ Offset_Dis Factor))
  (Setvar "Cmdecho" 1)
  (Princ)
)[/php]
GMT+8, 2026-11-3 00:38 , Processed in 0.540035 second(s), 32 queries , Gzip On.
