查看: 1266|回复: 4
[求助] [求助]:文字之和并写出来出问题了
发表于 2006-2-14 21:14:30 | 显示全部楼层 |阅读模式
(defun c:total( / cmdmode sset ssl nsset temp ssl1 total)
(if *error* quit)
(setq cmdmode (getvar "cmdecho"))
(setvar "cmdecho" 0)
(prompt "\nSelect numbers to add: ")
(setq sset (ssget))
(if (null sset)
(princ "\nError: Nothing selected!\n")
;过滤出选中的“text”实体,并报告有多少“text”实体被选中。
(progn
(setq ssl (sslength sset))
(setq nsset (ssadd))
(while (> ssl 0)
(setq temp (ssname sset (setq ssl(1- ssl))))
(if (= (cdr (assoc 0 (entget temp))) "TEXT")
(ssadd temp nsset)
(setq ssl (sslength nsset))
(print ssl)
(princ "text entities are found.")
;选出所有可转化为数的“TEXT”,并求和。
(setq total 0)
(setq ssl1 ssl)
(while (> ssl 0)
(setq temp (ssname nsset (setq ssl (1- ssl))))
(setq number (atof(cdr(assoc 1 (entget temp)))))
(if (= 0 number)
(setq ssl1 (1- ssl1))
(setq total (+ total number))
;显示和及加数的个数,便于用户检查是否多选或漏选。
(princ "\nThe total is ")
(princ total)
(princ "of the ")
(princ ssl1)
(princ "numbers\n")
(command "units" "2" "1" "" "" "" "" "")
(COMMAND "style" "wanghai" "新宋体" "300" "1" "0" "" "")
(setq pt1(getpoint"\n\t放置点 : "))
(command "text" "j" "mc" pt1 "0" total)
(setvar "CMDECHO" cmdmode)
发表于 2006-2-14 21:49:13 | 显示全部楼层
  1. [FONT=courier new](defun c:test ()
  2.   (setvar"DIMZIN"0)
  3.   (setq        ss (ssget '((0 . "TEXT")))
  4.         i  -1
  5.         n  0
  6.   )
  7.   (while (setq s1 (ssname ss (setq i (1+ i))))
  8.     (setq n (+ n (distof (cdr (assoc 1 (entget s1)))))
  9.     )
  10.   )
  11.   (princ "\nThe total is ")
  12.   (princ n)
  13.   (princ " of the ")
  14.   (princ i)
  15.   (princ " numbers.")
  16.   (COMMAND "style" "wanghai" "新宋体" "300" "1" "0" "" "")
  17.   (if (setq pt1 (getpoint "\n放置点 : "))
  18.     (command "text" "j" "mc" pt1 "0" (rtos n))
  19.   )
  20.   (princ)
  21. )[/FONT]
 楼主| 发表于 2006-2-15 09:44:44 | 显示全部楼层
还是没有达到预期效果
xyp1964在给乘、除、减的代码吧!谢谢
发表于 2006-2-15 12:30:19 | 显示全部楼层
试试签名栏下的“数字运算”程序。
发表于 2006-2-15 12:31:05 | 显示全部楼层
你把这句(command "text" "j" "mc" pt1 "0" total)
改成  (command "text" "j" "mc" pt1 "" "" (rtos total)),最主要是把total改成(rtos total)
GMT+8, 2026-11-22 08:32 , Processed in 0.350955 second(s), 18 queries , Gzip On, File On.
