查看: 801|回复: 0
[原创]:块内特定层文字更新程序,请指点。
发表于 2006-2-16 11:10:44 | 显示全部楼层 |阅读模式
主要思想是查找图中所有块,对块内entity判断是否为特定层文字,如果是
将块内特定层文字修改为当前时间和文件路径。
可是运行时有问题,请高手指点!问题出在哪?谢!
代码如下:
[PHP]
(defun c:nn (/ blkhead ename etest edata test_etype cdate DWGNAME DWGPREFIX)
  (setq cdate (MENUCMD
     "M=$(edtime,$(getvar,date) ,DD.MO.YYYY   HH:MM:SS)")
  (setq DNAME (getvar "DWGNAME")
      DPATH (getvar "DWGPREFIX")
  (setq cdate (strcat "Last Plot Date: " cdate "   " DPATH DNAME))
     ; get the first block
  (setq blkhead (tblnext "BLOCK" 1))
(while blkhead
    (setq ename (cdr (assoc -2 blkhead)))
    (setq etest 1)
     ; scan through the block an check every entity, whether it is of type text
(while etest ;while1
(setq edata (entget ename))
(if edata
(progn
   (setq test_etype (cdr (assoc 0 edata)))
   (setq txtlayer (cdr (assoc 8 edata)))
   (if (equal "TEXT" test_etype) ;if1
       (progn
          (if (equal "zdylastpd" txtlayer) ;if2
              (progn
              (setq etest 0)
              (command "change" ename "" "" "" "" "" "" cdate)
              (progn
                  (setq ename (entnext ename))
                  (setq etest ename)
          ); endif2
    )    ; end if1
) ;end progn
) ;end if
)     ; end while1
    (setq blkhead (tblnext "BLOCK"))
  )     ; end while blkhead
); end defun
[/PHP]
GMT+8, 2026-11-4 17:41 , Processed in 0.506590 second(s), 32 queries , Gzip On.
