查看: 761|回复: 1
[LISP程序]:如何改才能在win2000上用
发表于 2006-2-20 20:21:44 | 显示全部楼层 |阅读模式
这段程序在xp上用无问题,可在win2000就不行.若能改,我付费.E: MAwuz@126.com
(defun c:phy()
  (vl-load-com)
  (setq serx '())
  (if (SETQ OBJW (Vlax-Create-Object "wbemScripting.SwbemLocator"))
    (progn
      (SETQ lccon (VLAX-Invoke
    OBJW       'ConnectServer      "."
    "\\root\\cimv2"   ""      ""
    ""        ""   128      nil
      (setq lox (vlax-invoke
  lccon
  'ExecQuery
  "Select SerialNumber,Tag from Win32_PhysicalMedia"
      (vlax-for item lox
(setq serx (cons (list (vlax-get item 'Tag)
       (vlax-get
item
'SerialNumber
serx
      (vlax-release-object lox)
      (vlax-release-object lccon)
      (vlax-release-object objW)
  (setq q serx)))
  (print q)
已领礼包: 593个
发表于 2006-2-21 00:58:32 | 显示全部楼层
到函数库论坛查看源帖中的解决方法
GMT+8, 2026-11-5 15:33 , Processed in 0.411318 second(s), 33 queries , Gzip On.
