查看: 939|回复: 2
[VBA程序]:过滤lwpoline的线宽?
发表于 2003-5-7 14:12:58 | 显示全部楼层 |阅读模式
请问可以过滤lwpoline的线宽吗?是怎么样的,?我查了帮助好像没有?
已领礼包: 181个
发表于 2003-5-7 19:47:14 | 显示全部楼层
是在DXF This Reference的帮助文件中,找到Chapter 6 -- ENTITIES Section中的 LWPOLYLINE项(这是R2000的,其它版本可能有变化)
Lwpolyline group codes
Group code        Description
100        Subclass marker (AcDbPolyline)
90        Number of vertices
70        Polyline flag (bit-coded); default is 0:
1 = Closed; 128 = Plinegen
43         Constant width (optional; default = 0). Not used if variable width (codes 40 and/or 41) is set
38         Elevation (optional; default = 0)
39         Thickness (optional; default = 0)
10        Vertex coordinates (in OCS), multiple entries; one entry for each vertex
DXF: X value; APP: 2D point
20        DXF: Y value of vertex coordinates (in OCS), multiple entries; one entry for each vertex
40         Starting width (multiple entries; one entry for each vertex) (optional; default = 0; multiple entries). Not used if constant width (code 43) is set
41         End width (multiple entries; one entry for each vertex) (optional; default = 0; multiple entries). Not used if constant width (code 43) is set
42         Bulge (multiple entries; one entry for each vertex) (optional; default = 0)
210        Extrusion direction (optional; default = 0, 0, 1)
DXF: X value; APP: 3D vector
220, 230        DXF: Y and Z values of extrusion direction (optional)
上面的43组码就是全局宽度,40是起点线段宽度,41是终点线段宽度。
 楼主| 发表于 2003-5-7 21:39:21 | 显示全部楼层
多谢!!!!!!你的帮忙
GMT+8, 2026-11-2 17:15 , Processed in 0.927307 second(s), 36 queries , Gzip On.
