查看: 873|回复: 2
[ARX函数]:为什么已经切换当前数据库,acedSSGet还是对老的数据库操作?
发表于 2006-3-1 11:16:27 | 显示全部楼层 |阅读模式
bool CBlueprintDrawing::CreateBlueprint(long lBluePrintTemplateID, int iPageNo)
        Acad::ErrorStatus es;
        AcDbDatabase *pDb;
        CString m_BlueprintFileFullName;
        CString t_BlueprintTemplateFileName;
        pDb = new AcDbDatabase;
        //获取模板文件名
        es = pDb->readDwgFile( t_BlueprintTemplateFileName);
        if( es != Acad::eOk )
                acutPrintf("\n没有发现 %c 文件!\n", t_BlueprintTemplateFileName);
                delete pDb;
                return false;
        AcDbDatabase *pOldDb = acdbHostApplicationServices()->workingDatabase();
        acdbHostApplicationServices()->setWorkingDatabase(pDb);
        AcDbBlockTable *pBlockTable;
    pDb->getSymbolTable(pBlockTable, AcDb::kForRead);
        //acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlockTable, AcDb::kForRead);
    AcDbBlockTableRecord *pBlockTableRecord;
    pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite);
        pBlockTable->close();
        //---- 绘制图形
        CBlueprintDrawing::CreateTableGroup( pBlockTableRecord );
        //---- 绘制图纸框架
//?????????????? 选择集出现问题
//如果pOldDb中在选择区域中有实体,就可以;反之不行。
//希望pDb中在选择区域中有实体,就可以;反之不行。
//pDb已经是当前数据库为什么还关联pOldDb[/COLOR]
        CBlueprintDrawing::CreateFrameLine( pBlockTableRecord );
        //---- 关闭块表
        pBlockTableRecord->close();
        //切换回原工作表
        acdbHostApplicationServices()->setWorkingDatabase(pOldDb);
        //保存图纸
        pDb->saveAs(m_BlueprintFileFullName);
        delete pDb;
bool CBlueprintDrawing::CreateFrameLine(AcDbBlockTableRecord *pBlockTableRecord)
        int stat;
        long Number;
        ads_name SSName;
        ads_point t_ptW0, t_ptW1;
        AcGePoint3d ptW0(0, 0, 0), ptW1(0, 297, 0);
        Number = 0;
        t_ptW0[X] = 210.0;
        t_ptW0[Y] = 0.0;
        t_ptW0[Z] = 0.0;
        t_ptW1[X] = 420.0;
        t_ptW1[Y] = 297.0;
        t_ptW1[Z] = 0.0;
        //建一个交叉窗口选择集
        stat = acedSSGet("C", t_ptW0, t_ptW1, NULL, SSName);
        if ( stat != RTNORM )
                acedAlert("创建交叉选择集不成功!");
        else
                acedSSLength(SSName, &Number);
                acedAlert("创建交叉选择集成功!");
                while ( Number != 0 )
                        ptW0.x = t_ptW0[X];
                        ptW1.x = t_ptW1[X];
                        t_ptW0[X] +=  210.0;
                        t_ptW1[X] +=  210.0;
                        Number = 0;
                        acedSSFree(SSName);
        //--    绘制外框线
        AcGePoint3d pt0(0, 0, 0), pt1(0, 297, 0), pt2(0, 0, 0), pt3(0, 0, 0);
        pt2.x = ptW1.x;
        pt2.y = ptW1.y;
        pt3.x = ptW1.x;
        pt3.y = ptW0.y;
        CreateLine(pBlockTableRecord, pt0, pt1);
        CreateLine(pBlockTableRecord, pt1, pt2);
        CreateLine(pBlockTableRecord, pt2, pt3);
        CreateLine(pBlockTableRecord, pt3, pt0);
        return true;
发表于 2006-3-1 20:18:52 | 显示全部楼层
试试 activateDocument 后在有ssget
顺便说一句,代码问题比较多,自己查看一下把
最好把工程上传,这样我可以帮你调调
 楼主| 发表于 2006-3-2 10:48:55 | 显示全部楼层
谢谢。这是我减切下来的,应该没有太多问题,程序跑的挺好的,就是acedSSGet不听话。
GMT+8, 2026-11-5 10:59 , Processed in 0.421279 second(s), 36 queries , Gzip On.
