查看: 1382|回复: 5
[求助] [求助]:在哪可以找到這些E/T函數的說明?
已领礼包: 2个
发表于 2006-3-2 13:31:38 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. ACET-ACAD-REFRESH             (SUBR)
  3. ACET-ACADREACTOR-ID-ADD       (SUBR)
  4. ACET-ACADREACTOR-ID-REMOVE    (SUBR)
  5. ACET-ACADREACTOR-ID-REMOVE-ALL(SUBR)
  6. ACET-ACADREACTOR-ID-SWAP      (SUBR)
  7. ACET-ACADREACTOR-IDS-GET      (SUBR)
  8. ACET-ADDGBINEXPRESS           (SUBR)
  9. ACET-ALERT                    (SUBR)
  10. ACET-ALT-VIEWPORT             (SUBR)
  11. ACET-ANGLE-EQUAL              (SUBR)
  12. ACET-ANGLE-FORMAT             (SUBR)
  13. ACET-APPID-DELETE             (SUBR)
  14. ACET-ARX-RE-LOAD              (SUBR)
  15. ACET-ARXLOAD-OR-BUST          (SUBR)
  16. ACET-AUTOLOAD                 (SUBR)
  17. ACET-AUTOLOAD-APPLY           (SUBR)
  18. ACET-AUTOLOAD-EXEC            (SUBR)
  19. ACET-AUTOLOAD2                (SUBR)
  20. ACET-BLINK-AND-SHOW-OBJECT    (SUBR)
  21. ACET-BLOCK-MAKE-ANON          (SUBR)
  22. ACET-BLOCK-PURGE              (SUBR)
  23. ACET-BS-STRIP                 (SUBR)
  24. ACET-CALC-BITLIST             (SUBR)
  25. ACET-CALC-ROUND               (SUBR)
  26. ACET-CALC-TAN                 (SUBR)
  27. ACET-CMD-CHECK                (SUBR)
  28. ACET-CMD-EXIT                 (SUBR)
  29. ACET-CURRENTVIEWPORT-ENAME    (SUBR)
  30. ACET-DCL-LIST-MAKE            (SUBR)
  31. ACET-DICT-ENAME               (SUBR)
  32. ACET-DICT-FILTER-MATCH        (SUBR)
  33. ACET-DICT-MAKE                (SUBR)
  34. ACET-DICT-NAME-LIST           (SUBR)
  35. ACET-DISABLED-COMMAND         (SUBR)
  36. ACET-DTOR                     (SUBR)
  37. ACET-DXF                      (SUBR)
  38. ACET-EDITOR-REACTOR-ADD       (SUBR)
  39. ACET-ELIST-ADD-DEFAULTS       (SUBR)
  40. ACET-ELIST-FILTER--4-MATCH    (SUBR)
  41. ACET-ELIST-FILTER-AND-MATCH   (SUBR)
  42. ACET-ELIST-FILTER-GC-MATCH    (SUBR)
  43. ACET-ELIST-FILTER-MATCH       (SUBR)
  44. ACET-ELIST-FILTER-NOT-MATCH   (SUBR)
  45. ACET-ELIST-FILTER-OR-MATCH    (SUBR)
  46. ACET-ENT-CURVEPOINTS          (EXRXSUBR)
  47. ACET-ENT-GEOMEXTENTS          (EXRXSUBR)
  48. ACET-ERROR                    (LIST)
  49. ACET-ERROR-INIT               (SUBR)
  50. ACET-ERROR-RESTORE            (SUBR)
  51. ACET-EXPLODE                  (SUBR)
  52. ACET-FILE-ATTR                (EXRXSUBR)
  53. ACET-FILE-BACKUP              (SUBR)
  54. ACET-FILE-BACKUP-DELETE       (SUBR)
  55. ACET-FILE-BACKUP-RESTORE      (SUBR)
  56. ACET-FILE-CHDIR               (EXRXSUBR)
  57. ACET-FILE-COPY                (EXRXSUBR)
  58. ACET-FILE-CWD                 (EXRXSUBR)
  59. ACET-FILE-DIR                 (EXRXSUBR)
  60. ACET-FILE-FIND                (SUBR)
  61. ACET-FILE-FIND-FONT           (SUBR)
  62. ACET-FILE-FIND-IMAGE          (SUBR)
  63. ACET-FILE-FIND-ON-PATH        (SUBR)
  64. ACET-FILE-MKDIR               (EXRXSUBR)
  65. ACET-FILE-MOVE                (EXRXSUBR)
  66. ACET-FILE-OPEN                (SUBR)
  67. ACET-FILE-READDIALOG          (EXRXSUBR)
  68. ACET-FILE-REMOVE              (EXRXSUBR)
  69. ACET-FILE-RMDIR               (EXRXSUBR)
  70. ACET-FILE-SYSTIME-COMPARE     (SUBR)
  71. ACET-FILE-WRITEDIALOG         (EXRXSUBR)
  72. ACET-FILENAME-ACAD-ROOT       (SUBR)
  73. ACET-FILENAME-ASSOCIATED-APP  (SUBR)
  74. ACET-FILENAME-DIR-ON-PATH     (SUBR)
  75. ACET-FILENAME-DIRECTORY       (SUBR)
  76. ACET-FILENAME-EXT-REMOVE      (SUBR)
  77. ACET-FILENAME-EXTENSION       (SUBR)
  78. ACET-FILENAME-PATH-REMOVE     (SUBR)
  79. ACET-FILENAME-SUPPORTPATH-REMOVE(SUBR)
  80. ACET-FILENAME-VALID           (SUBR)
  81. ACET-FSCREEN-OFF              (EXRXSUBR)
  82. ACET-FSCREEN-ON               (EXRXSUBR)
  83. ACET-FSCREEN-OPTIONS          (EXRXSUBR)
  84. ACET-FSCREEN-STATUS           (EXRXSUBR)
  85. ACET-FSCREEN-TOGGLE           (EXRXSUBR)
  86. ACET-FULL-DWGNAME             (SUBR)
  87. ACET-GENERAL-PROPS-GET        (SUBR)
  88. ACET-GENERAL-PROPS-GET-PAIRS  (SUBR)
  89. ACET-GENERAL-PROPS-SET        (SUBR)
  90. ACET-GENERAL-PROPS-SET-PAIRS  (SUBR)
  91. ACET-GEOM-ANGLE-TO-ELLIPSEANGLE(SUBR)
  92. ACET-GEOM-ANGLE-TRANS         (SUBR)
  93. ACET-GEOM-ARBITRARY-X         (SUBR)
  94. ACET-GEOM-ARC-3P-D-ANGLE      (SUBR)
  95. ACET-GEOM-ARC-BULGE           (SUBR)
  96. ACET-GEOM-ARC-CENTER          (SUBR)
  97. ACET-GEOM-ARC-D-ANGLE         (SUBR)
  98. ACET-GEOM-ARC-DELTA-ANGLE     (SUBR)
  99. ACET-GEOM-ARC-POINT-LIST      (SUBR)
  100. ACET-GEOM-CALC-ARC-ERROR      (SUBR)
  101. ACET-GEOM-CROSS-PRODUCT       (SUBR)
  102. ACET-GEOM-DELTA-VECTOR        (SUBR)
  103. ACET-GEOM-ELLIPSE-ARC-LIST    (SUBR)
  104. ACET-GEOM-ELLIPSE-POINT-AT-ANGLE(SUBR)
  105. ACET-GEOM-ELLIPSE-POINT-AT-E-ANGLE(SUBR)
  106. ACET-GEOM-ELLIPSE-POINT-LIST  (SUBR)
  107. ACET-GEOM-ELLIPSE-TO-PLINE    (SUBR)
  108. ACET-GEOM-ELLIPSEANGLE-TO-ANGLE(SUBR)
  109. ACET-GEOM-EXTENTS             (SUBR)
  110. ACET-GEOM-IMAGE-BOUNDS        (SUBR)
  111. ACET-GEOM-IMAGE-CLIP-LIST     (SUBR)
  112. ACET-GEOM-INSERT-CLIP-LIST    (SUBR)
  113. ACET-GEOM-INSERT-POINT-LIST   (SUBR)
  114. ACET-GEOM-INTERSECTWITH       (SUBR)
  115. ACET-GEOM-IS-ARC              (SUBR)
  116. ACET-GEOM-LIST-EXTENTS        (SUBR)
  117. ACET-GEOM-LIST-FUZ            (SUBR)
  118. ACET-GEOM-M-TRANS             (SUBR)
  119. ACET-GEOM-MATRIX-TRANS        (SUBR)
  120. ACET-GEOM-MIDPOINT            (SUBR)
  121. ACET-GEOM-MTXTBOX             (SUBR)
  122. ACET-GEOM-OBJECT-END-POINTS   (SUBR)
  123. ACET-GEOM-OBJECT-FUZ          (SUBR)
  124. ACET-GEOM-OBJECT-NORMAL-VECTOR(SUBR)
  125. ACET-GEOM-OBJECT-POINT-LIST   (SUBR)
  126. ACET-GEOM-OBJECT-Z-AXIS       (SUBR)
  127. ACET-GEOM-PIXEL-UNIT          (SUBR)
  128. ACET-GEOM-PLINE-ARC-INFO      (SUBR)
  129. ACET-GEOM-PLINE-POINT-LIST    (SUBR)
  130. ACET-GEOM-POINT-FUZ           (SUBR)
  131. ACET-GEOM-POINT-INSIDE        (SUBR)
  132. ACET-GEOM-POINT-ROTATE        (SUBR)
  133. ACET-GEOM-POINT-SCALE         (SUBR)
  134. ACET-GEOM-RECT-POINTS         (SUBR)
  135. ACET-GEOM-SELF-INTERSECT      (SUBR)
  136. ACET-GEOM-SPLINE-POINT-LIST   (SUBR)
  137. ACET-GEOM-SS-EXTENTS          (SUBR)
  138. ACET-GEOM-SS-EXTENTS-ACCURATE (SUBR)
  139. ACET-GEOM-SS-EXTENTS-FAST     (SUBR)
  140. ACET-GEOM-TEXTBOX             (SUBR)
  141. ACET-GEOM-TRANS-IMAGE-TO-UCS  (SUBR)
  142. ACET-GEOM-TRANS-UCS-TO-IMAGE  (SUBR)
  143. ACET-GEOM-TXTBOX              (SUBR)
  144. ACET-GEOM-UNIT-VECTOR         (SUBR)
  145. ACET-GEOM-VECTOR-ADD          (SUBR)
  146. ACET-GEOM-VECTOR-D-ANGLE      (SUBR)
  147. ACET-GEOM-VECTOR-PARALLEL     (SUBR)
  148. ACET-GEOM-VECTOR-SCALE        (SUBR)
  149. ACET-GEOM-VECTOR-SIDE         (SUBR)
  150. ACET-GEOM-VERTEX-LIST         (SUBR)
  151. ACET-GEOM-VIEW-POINTS         (SUBR)
  152. ACET-GEOM-Z-AXIS              (SUBR)
  153. ACET-GEOM-ZOOM-FOR-SELECT     (SUBR)
  154. ACET-GETVAR                   (SUBR)
  155. ACET-GETVAR-CPROFILE          (SUBR)
  156. ACET-GETVAR-DWG               (SUBR)
  157. ACET-GETVAR-FIXED-PROFILE     (SUBR)
  158. ACET-GO-TO-EXPRESS-PAGE       (SUBR)
  159. ACET-GROUP-MAKE-ANON          (SUBR)
  160. ACET-HATCH-LOOP-MAKE          (SUBR)
  161. ACET-HATCH-LOOP-MAKE-DATA-GET (SUBR)
  162. ACET-HATCH-LOOPEDGE-MAKE      (SUBR)
  163. ACET-HELP                     (EXRXSUBR)
  164. ACET-HELP-TRAP                (EXRXSUBR)
  165. ACET-HOW-TO-GET-EXPRESS       (SUBR)
  166. ACET-INI-GET                  (EXRXSUBR)
  167. ACET-INI-SET                  (EXRXSUBR)
  168. ACET-INIT                     (SUBR)
  169. ACET-INIT-ACETUTIL-ARX        (SUBR)
  170. ACET-INIT-ADD-LIB-DIR         (SUBR)
  171. ACET-INIT-EXCLUDE-LIST        (SUBR)
  172. ACET-INIT-EXPRESS-INSTALLED   (SUBR)
  173. ACET-INIT-EXPRESS-NOT-INSTALLED-MSG(SUBR)
  174. ACET-INIT-FAS-LIB             (SUBR)
  175. ACET-INIT-FORCE-LOAD-ARX-LIB  (SUBR)
  176. ACET-INIT-GET-LIB-DIR         (SUBR)
  177. ACET-INIT-PLACEMENU           (SUBR)
  178. ACET-INIT-PRODKEY             (SUBR)
  179. ACET-INSERT-ATTRIB-GET        (SUBR)
  180. ACET-INSERT-ATTRIB-MOD        (SUBR)
  181. ACET-INSERT-ATTRIB-SET        (SUBR)
  182. ACET-INSERT-SPACIAL-FILTER    (SUBR)
  183. ACET-IS-SYMBOL-TABLE          (SUBR)
  184. ACET-LAYER-LOCKED             (SUBR)
  185. ACET-LAYER-LOCKED-LIST        (SUBR)
  186. ACET-LAYER-UNLOCK-ALL         (SUBR)
  187. ACET-LAYERP-MARK              (EXRXSUBR)
  188. ACET-LAYERP-MODE              (EXRXSUBR)
  189. ACET-LIST-ASSOC-APPEND        (SUBR)
  190. ACET-LIST-ASSOC-PUT           (SUBR)
  191. ACET-LIST-ASSOC-REMOVE        (SUBR)
  192. ACET-LIST-GROUP-BY-ASSOC      (SUBR)
  193. ACET-LIST-INSERT-NTH          (SUBR)
  194. ACET-LIST-IS-DOTTED-PAIR      (SUBR)
  195. ACET-LIST-ISORT               (SUBR)
  196. ACET-LIST-M-ASSOC             (SUBR)
  197. ACET-LIST-PUT-NTH             (SUBR)
  198. ACET-LIST-REMOVE-ADJACENT-DUPS(SUBR)
  199. ACET-LIST-REMOVE-DUPLICATES   (SUBR)
  200. ACET-LIST-REMOVE-NTH          (SUBR)
  201. ACET-LIST-SPLIT               (SUBR)
  202. ACET-LIST-TO-SS               (SUBR)
  203. ACET-LSP-IS-COMMAND           (SUBR)
  204. ACET-LSP-IS-FUNCTION          (SUBR)
  205. ACET-LSP-LOAD                 (SUBR)
  206. ACET-LSP-PRINC                (SUBR)
  207. ACET-LWPLINE-MAKE             (SUBR)
  208. ACET-MENU-LOAD                (SUBR)
  209. ACET-MENU-LOAD2               (SUBR)
  210. ACET-MS-TO-PS                 (EXRXSUBR)
  211. ACET-PARTIAL-MENU-STATUS-GET  (SUBR)
  212. ACET-PARTIAL-MENU-STATUS-SET  (SUBR)
  213. ACET-PATH-TO-LIST             (SUBR)
  214. ACET-PLINE-IS-2D              (SUBR)
  215. ACET-PLINE-MAKE               (SUBR)
  216. ACET-PLINE-SEGMENT-LIST       (SUBR)
  217. ACET-PLINE-SEGMENT-LIST-APPLY (SUBR)
  218. ACET-PLINES-EXPLODE           (SUBR)
  219. ACET-PLINES-EXPLODE-WIDTH-DATA-GET(SUBR)
  220. ACET-PLINES-REBUILD           (SUBR)
  221. ACET-PLINES-REBUILD-APPLY-WIDTHS(SUBR)
  222. ACET-PLINES-REBUILD-SET-ELEVATION(SUBR)
  223. ACET-POINT-FLAT               (SUBR)
  224. ACET-PREF-SUPPORTPATH-LIST    (SUBR)
  225. ACET-PS-TO-MS                 (EXRXSUBR)
  226. ACET-PSPACE-VIEWPORT-ENAME    (SUBR)
  227. ACET-R12-DXF-CONVERT          (SUBR)
  228. ACET-RE-MAKE                  (SUBR)
  229. ACET-REACTOR-EXISTS           (SUBR)
  230. ACET-REACTOR-REMOVE           (SUBR)
  231. ACET-REG-DEL                  (EXRXSUBR)
  232. ACET-REG-GET                  (EXRXSUBR)
  233. ACET-REG-PRODKEY              (EXRXSUBR)
  234. ACET-REG-PUT                  (EXRXSUBR)
  235. ACET-REG-SETACTIVEX           (SUBR)
  236. ACET-REG-TREE-GET             (SUBR)
  237. ACET-REG-TREE-SET             (SUBR)
  238. ACET-RTOD                     (SUBR)
  239. ACET-SAFE-COMMAND             (SUBR)
  240. ACET-SET-CMDECHO              (SUBR)
  241. ACET-SETVAR                   (SUBR)
  242. ACET-SETVAR-CPROFILE          (SUBR)
  243. ACET-SETVAR-DWG               (SUBR)
  244. ACET-SETVAR-FIXED-PROFILE     (SUBR)
  245. ACET-SPINNER                  (SUBR)
  246. ACET-SS-ANNOTATION-FILTER     (SUBR)
  247. ACET-SS-CLEAR-PREV            (SUBR)
  248. ACET-SS-CONVERT-ELLIPSES-TO-PLINES(SUBR)
  249. ACET-SS-DRAG-MOVE             (EXRXSUBR)
  250. ACET-SS-DRAG-ROTATE           (EXRXSUBR)
  251. ACET-SS-DRAG-SCALE            (EXRXSUBR)
  252. ACET-SS-ENTDEL                (SUBR)
  253. ACET-SS-FILTER                (SUBR)
  254. ACET-SS-FILTER-CURRENT-UCS    (SUBR)
  255. ACET-SS-FILTER-ITEM           (SUBR)
  256. ACET-SS-FILTER-VALIDATE       (SUBR)
  257. ACET-SS-FLT-CSPACE            (SUBR)
  258. ACET-SS-INTERSECTION          (SUBR)
  259. ACET-SS-NEW                   (SUBR)
  260. ACET-SS-REDRAW                (SUBR)
  261. ACET-SS-REMOVE                (SUBR)
  262. ACET-SS-REMOVE-DUPS           (SUBR)
  263. ACET-SS-REMOVE-DUPS-EXTENTS-LIST(SUBR)
  264. ACET-SS-REMOVE-DUPS-GENERALIZE-ENT(SUBR)
  265. ACET-SS-REMOVE-DUPS-REVERSE   (SUBR)
  266. ACET-SS-SCALE-TO-FIT          (SUBR)
  267. ACET-SS-SCALE-TO-FIT-BASE     (SUBR)
  268. ACET-SS-SORT                  (SUBR)
  269. ACET-SS-SSGET-FILTER          (SUBR)
  270. ACET-SS-TO-LIST               (SUBR)
  271. ACET-SS-UNION                 (SUBR)
  272. ACET-SS-VISIBLE               (SUBR)
  273. ACET-SS-ZOOM-EXTENTS          (SUBR)
  274. ACET-STR-COLLATE              (EXRXSUBR)
  275. ACET-STR-ENV-EXPAND           (SUBR)
  276. ACET-STR-EQUAL                (EXRXSUBR)
  277. ACET-STR-ESC-WILDCARDS        (SUBR)
  278. ACET-STR-FIND                 (EXRXSUBR)
  279. ACET-STR-FORMAT               (EXRXSUBR)
  280. ACET-STR-IS-PRINTABLE         (SUBR)
  281. ACET-STR-LIST-SELECT          (SUBR)
  282. ACET-STR-LR-TRIM              (SUBR)
  283. ACET-STR-M-FIND               (SUBR)
  284. ACET-STR-REPLACE              (EXRXSUBR)
  285. ACET-STR-SPACE-TRIM           (SUBR)
  286. ACET-STR-TO-LIST              (SUBR)
  287. ACET-STR-WCMATCH              (EXRXSUBR)
  288. ACET-SYS-BEEP                 (EXRXSUBR)
  289. ACET-SYS-COMMAND              (EXRXSUBR)
  290. ACET-SYS-CONTROL-DOWN         (SUBR)
  291. ACET-SYS-FOREGROUND           (EXRXSUBR)
  292. ACET-SYS-KEYSTATE             (EXRXSUBR)
  293. ACET-SYS-LASTERR              (EXRXSUBR)
  294. ACET-SYS-LMOUSE-DOWN          (SUBR)
  295. ACET-SYS-PROCID               (EXRXSUBR)
  296. ACET-SYS-SHIFT-DOWN           (SUBR)
  297. ACET-SYS-SLEEP                (EXRXSUBR)
  298. ACET-SYS-SPAWN                (EXRXSUBR)
  299. ACET-SYS-TERM                 (EXRXSUBR)
  300. ACET-SYS-WAIT                 (EXRXSUBR)
  301. ACET-SYSVAR-RESTORE           (SUBR)
  302. ACET-SYSVAR-SET               (SUBR)
  303. ACET-TABLE-NAME-LIST          (SUBR)
  304. ACET-TABLE-PURGE              (SUBR)
  305. ACET-TEMP-SEGMENT             (SUBR)
  306. ACET-TJUST                    (SUBR)
  307. ACET-TJUST-GROUP-CODES        (SUBR)
  308. ACET-TJUST-KEYWORD            (SUBR)
  309. ACET-UCS-CAPTURE-VIEWPORTS    (SUBR)
  310. ACET-UCS-CMD                  (SUBR)
  311. ACET-UCS-GET                  (SUBR)
  312. ACET-UCS-RESTORE-VIEWPORTS    (SUBR)
  313. ACET-UCS-SET                  (SUBR)
  314. ACET-UCS-SET-Z                (SUBR)
  315. ACET-UCS-TO-OBJECT            (SUBR)
  316. ACET-UI-DRAG                  (SUBR)
  317. ACET-UI-ENTSEL                (SUBR)
  318. ACET-UI-FENCE-SELECT          (SUBR)
  319. ACET-UI-GET-LONG-NAME         (SUBR)
  320. ACET-UI-GETCORNER             (SUBR)
  321. ACET-UI-GETFILE               (SUBR)
  322. ACET-UI-M-GET-NAMES           (SUBR)
  323. ACET-UI-MESSAGE               (EXRXSUBR)
  324. ACET-UI-PICKDIR               (EXRXSUBR)
  325. ACET-UI-POLYGON-SELECT        (SUBR)
  326. ACET-UI-PROGRESS              (EXRXSUBR)
  327. ACET-UI-PROGRESS-DONE         (SUBR)
  328. ACET-UI-PROGRESS-INIT         (SUBR)
  329. ACET-UI-PROGRESS-SAFE         (SUBR)
  330. ACET-UI-SINGLE-SELECT         (SUBR)
  331. ACET-UI-STATUS                (EXRXSUBR)
  332. ACET-UI-TABLE-NAME-CHECK-FLAGS(SUBR)
  333. ACET-UI-TABLE-NAME-FORMAT     (SUBR)
  334. ACET-UI-TABLE-NAME-GET        (SUBR)
  335. ACET-UI-TABLE-NAME-GET-CMD    (SUBR)
  336. ACET-UI-TABLE-NAME-GET-CMD-LIST(SUBR)
  337. ACET-UI-TABLE-NAME-GET-DLG    (SUBR)
  338. ACET-UI-TABLE-NAME-GET-ENAME  (SUBR)
  339. ACET-UI-TABLE-NAME-GET-IS-VALID(SUBR)
  340. ACET-UI-TABLE-NAME-GET-ITEM-LIST(SUBR)
  341. ACET-UI-TABLE-NAME-GET-PICKIT (SUBR)
  342. ACET-UI-TABLE-NAME-OBJECT-DATA(SUBR)
  343. ACET-UI-TXTED                 (EXRXSUBR)
  344. ACET-UNDO-BEGIN               (SUBR)
  345. ACET-UNDO-END                 (SUBR)
  346. ACET-UNDO-INIT                (SUBR)
  347. ACET-UNDO-RESTORE             (SUBR)
  348. ACET-UTIL-VER                 (EXRXSUBR)
  349. ACET-VAR-GETVAR               (EXRXSUBR)
  350. ACET-VAR-SETVAR               (EXRXSUBR)
  351. ACET-VBALOAD                  (SUBR)
  352. ACET-VIEWPORT-FROZEN-LAYER-LIST(SUBR)
  353. ACET-VIEWPORT-FROZEN-LAYER-LIST-SET(SUBR)
  354. ACET-VIEWPORT-LOCK-SET        (SUBR)
  355. ACET-VIEWPORT-NEXT-PICKABLE   (SUBR)
  356. ACET-VIEWPORT-VPFREEZE        (SUBR)
  357. ACET-WMFIN                    (SUBR)
  358. ACET-XDATA-GET                (SUBR)
  359. ACET-XDATA-SET                (SUBR)
  360. ACET-XREF-CPROJECT-PATH       (SUBR)
  361. ACET:OLD-ERROR                (SUBR)
  362. ACETAI_FFILE                  (SUBR)
  363. ACETAI_NOFILE                 (SUBR)
  364. ACETAUTOARXACEDLOAD           (SUBR)
  365. ACETAUTOARXLOAD               (SUBR)
  366. ACETAUTOLOAD                  (SUBR)
  367. ACETAUTONATIVELOAD            (SUBR)
  368.   [/FONT]
复制代码
已领礼包: 25个
发表于 2006-3-3 22:31:12 | 显示全部楼层
这是什么函数?哪里发现的,有些啥大概的作用?
已领礼包: 9337个
发表于 2006-3-4 09:48:32 | 显示全部楼层
AutoCad ExpressTools utility 函数
http://www.jtbworld.com/download/acetutil.zip
(只含部份函数说明)
Ref info:
If you have version 1.36 or later of the Express Tools module 'acetutil.arx',
you can use:
  (acet-file-dir "*" Acet:Directory "c:\\cad")
Version 1.37 of this module is included in the Express Tools packages available
for free download in the Productivity Center of Autodesk Point A
(http://pointa.autodesk.com).
Documentation of the functions provided by this module is not included (yet),
but I can forward the 22KB 'acetutil.chm' file to anyone who asks.
Frank Whaley
Autodesk, Inc.
few@autodesk.com
http://www.autodesk.com/expresstools
Express Tools - Your wish is our (command ...)
发表于 2006-3-4 16:48:21 | 显示全部楼层
在For CAD2006的ET工具安装目录中就有了.
已领礼包: 2个
 楼主| 发表于 2006-3-5 00:38:35 | 显示全部楼层
最初由 netbee 发布
[B]在For CAD2006的ET工具安装目录中就有了. [/B]
老大,我要的是用法說明.我不知道語法是怎樣的啊!
已领礼包: 444个
发表于 2006-3-6 10:34:50 | 显示全部楼层
最初由 taner 发布
[B]
老大,我要的是用法說明.我不知道語法是怎樣的啊! [/B]
ET扩展工具里面都有源文件的,可以参考里面的用法。
GMT+8, 2026-11-3 15:16 , Processed in 0.508440 second(s), 43 queries , Gzip On.
