查看: 4414|回复: 15
[LISP程序]:一个多重复制的程序
已领礼包: 6468个
发表于 2006-11-19 19:36:43 | 显示全部楼层 |阅读模式
;;;                CV(COPYM) 超级多重复制   CCLISP程序                ;;
;;;                By    二00五年九月                               ;;
(defun c:cv ( / ss p1 cmd snaptp ucshold )
(acet-error-init
   (list (list  "cmdecho" 0
               "snaptype" 0
               "snapmode" nil
               "gridmode" nil
               "snapunit" nil
               "gridunit" nil
         );list
         0
         '(progn
            (acet-sysvar-set (list "cmdecho" 0))
            (if ss
                (acet-ss-redraw ss 4)
            (if ucshold
                (acet-ucs-set ucshold)
            (acet-sysvar-restore)
            (princ)
          );progn
   );list
);acet-error-init
(setq ucshold (acet-ucs-get nil))
(if (setq ss (ssget))
     (progn
      (acet-ss-redraw ss 3)
      (setq p1 (getpoint "\基点: "))
      (if p1
          (acet-copym ss p1)
      );if
     );progn then
);if
(acet-error-restore)
);defun c:copym
(defun acet-copym ( ss p1 / na p2 n d lst j p3 )
(setq p2 T)
(setq n 0)
(while p2
  (setq na (entlast))
  (if (not lst)
      (setq lst (list (list ss p1)))
  );if
  (setvar "lastpoint" p1)
  (initget 128 "Repeat Divide Measure Array Undo eXit")
  (setq p2 (acet-ss-drag-move
            ss
            p1
            "\n第二点或 \n[重复(R)/定数分开(D)/定距等分(M)/阵列(A)/撤消(U)] <退出>: "
            nil
           );acet-ss-drag-move
  );setq
  (if (= p2 "eXit")
      (setq p2 nil)
  );if
  (cond
   ((= p2 "Undo")
    (if (= n 0)
        (princ "\n没有撤消。")
        (progn
         (command "_.undo" "1")
         (setq   n (- n 1)
               lst (cdr lst)
                ss (car lst)
                p1 (cadr ss)
                ss (car ss)
         );setq
        );progn else
    );if
   );cond #1
   ((= p2 "Repeat")
    (if (= n 0)
        (princ "\n没有重复。")
        (progn
         (setq p2 (cadr (car lst))
               p1 (cadr (cadr lst))
                d (list (- (car p2) (car p1))
                        (- (cadr p2) (cadr p1))
                        (- (caddr p2) (caddr p1))
                  );list
         );setq
         (command "_.copy" ss "" d "")
         (setq   n (+ n 1)
                ss (acet-ss-new na)
                p1 (list (+ (car p2) (car d))
                         (+ (cadr p2) (cadr d))
                         (+ (caddr p2) (caddr d))
                   );list
               lst (cons (list ss p1) lst)
         );setq
        );progn else
    );if
   );cond #2
   ((equal 'LIST (type p2))
    (command "_.copy" ss "" p1 p2)
    (setq   n (+ n 1)
           ss (acet-ss-new na)
           p1 p2
    );setq
   );cond #3
   ((and (= "Divide" p2)
         (setq p3 (getpoint p1 "\n选择定数分开的端点: "))
         (progn
          (initget 6)
          (setq j (getint "\n复制数: "))
         );progn
    );and
    (setq  ss (acet-copym-divide ss p1 p3 j)
           p1 p3
            n (+ n 1)
    );setq
   );cond #4
   ((and (= "Measure" p2)
         (setq p3 (getpoint p1 "\n选择定距等分的端点: "))
         (progn
          (initget 6)
          (setq d (getdist "\n复制之间的距离: "))
         );progn
    );and
    (setq  ss (acet-copym-measure ss p1 p3 d) ;returns selset and base point
           p1 (cadr ss)
           ss (car ss)
            n (+ n 1)
    );setq
   );cond #5
   ((= "Array" p2)
    (setq  ss (acet-copym-array ss p1)
           p1 (cadr ss)
           ss (car ss)
            n (+ n 1)
    );setq
   );cond #6
   (p2
    (princ "\n无效的输入。")
   );cond #7
  );cond close
);while
);defun acet-copym
(defun acet-copym-array ( ss p1 / a )
(initget "Pick Measure Divide")
(setq a (getkword "\n选取-动态(P)/定距等分(M)/定数等分(D) <选取>: "))
(cond
  ((or (not a)
       (= a "Pick")
   );or
   (setq a (acet-copym-array-dynamic ss p1))
  );cond #1
  ((= a "Measure")
   (setq a (acet-copym-array-measure ss p1))
  );cond #2
  ((= a "Divide")
   (setq a (acet-copym-array-divide ss p1))
  );cond #3
);cond close
a
);defun acet-copym-array
(defun acet-copym-array-dynamic ( ss p1 / snap grid snapu gridu p2 p3 p4 dx dy lst ss2 na a )
(acet-undo-begin)
(setq p2 (getangle p1 "\n指定角度 <0>: "))
(if p2
     (setq p2 (polar p1 p2 1.0)) ;convert angle to a point
     (setq p2 (polar p1 0.0 1.0));use default of 0 and convert to point
);if
(setq p3 (polar p1 (+ (angle p1 p2) (/ pi 2.0)) 1.0)
       p1 (trans p1 1 0)
       p2 (trans p2 1 0)
       p3 (trans p3 1 0)
);setq
(acet-ucs-cmd (list "_3p" (trans p1 0 1) (trans p2 0 1) (trans p3 0 1)))
(setq p1 (trans p1 0 1)
       p2 (trans p2 0 1)
       p3 (trans p3 0 1)
);setq
(setq  p2 (acet-copym-getcorner p1 "\n选取角点以得到列和行距离: " T)
        dx (- (car p2) (car p1))
        dy (- (cadr p2) (cadr p1))
       lst (list p1)
        p4 T
);setq
(acet-sysvar-set
  (list
    "snapunit" (list (abs dx) (abs dy))
    "gridunit" (list (abs dx) (abs dy))
    "snapmode" 1
    "gridmode" 1
);acet-sysvar-set
(while p4
  (setvar "snapmode" 1)
  (setvar "gridmode" 1)
  ;(setq p4 (getpoint p1 "\n选取阵列的元素位置或按<回车>键完成: "))
  (setq p4 (acet-ss-drag-move
             ss
             p1
             nil
            );acet-ss-drag-move
  );setq
  (cond
   ((not p4) T);cond #1
   ((member p4 lst)
    (princ "\n*invalid* 您已经选取了此点!")
   );cond #2
   (T
    (setq  na (entlast)
          lst (cons p4 lst)
    );setq
    (command "_.copy" ss "" p1 p4)
   );cond #3
  );cond close
);while
(if na
     (setq  p1 (trans (getvar "lastpoint") 1 0)
           ss2 (acet-ss-new na)
     );setq
     (setq ss2 ss);setq else
);if
(acet-ucs-cmd (list"_prev"))
(setq p1 (trans p1 0 1))
(acet-undo-end)
(list ss2 p1)
);defun acet-copym-array-dynamic
(defun acet-copym-getcorner ( p1 msg nozero / flag p2 na )
(while (not flag)
  (setq na (entlast))
  (command "_.rectang" p1)
  (while (wcmatch (getvar "cmdnames") "*RECTANG*")
   (princ msg)
   (command pause)
  );while
  (setq p2 (getvar "lastpoint"));setq
  (if (not (equal na (entlast)))
      (entdel (entlast))
  );if
  (cond
   ((not nozero)
    (setq flag T)
   );cond #1
   ((and (equal (car p1) (car p2) 0.00000001)
         (equal (cadr p1) (cadr p2) 0.00000001)
    );and
    (princ "\n*Points cannot be equal*")
   );cond #2
   ((= (car p1) (car p2))
    (princ "\n*X 座标不能相等*")
   );cond #3
   ((= (cadr p1) (cadr p2))
    (princ "\n*Y 座标不能相等*")
   );cond #4
   (T
    (setq flag T)
   );cond #5
  );cond close
);while
p2
);defun acet-copym-getcorner
(defun acet-copym-array-measure ( ss p1 / snap grid snapu gridu p2 p3 p4 dx dy
                                     ss2 na a n j k m x y
(acet-undo-begin)
(if p2
);if
       p1 (trans p1 1 0)
       p2 (trans p2 1 0)
       p3 (trans p3 1 0)
);setq
        p2 (acet-copym-getcorner p1 "\n选取角点以得到行和列距离: " T)
        p4 T
);setq
(acet-sysvar-set
  (list
    "snapmode" 1
    "gridmode" 1
);acet-sysvar-set
(setq p2 (acet-copym-getcorner p1 "\n阵列填充另一角: " T))
(if (> (car p2) (car p1))
     (setq dx (abs dx))
     (setq dx (* -1.0 (abs dx)))
);if
(if (> (cadr p2) (cadr p1))
     (setq dy (abs dy))
     (setq dy (* -1.0 (abs dy)))
);if
(setq k (/ (abs (- (car p2) (car p1)))
            (abs dx)
       m (/ (abs (- (cadr p2) (cadr p1)))
            (abs dy)
       k (+ 1 (atoi (rtos k 2 0)))
       m (+ 1 (atoi (rtos m 2 0)))
);setq
(setq n 0)
(repeat m        ;; rows
  (setq y (+ (cadr p1) (* dy n)))
  (setq j 0)
  (repeat k        ;; columns
   (setq x (+ (car p1) (* dx j)))
   (setq na (entlast))
   (if (not (and (= n 0)
                 (= j 0)
            );and
       );not
       (command "_.copy" ss "" p1 (list x y (caddr p1)))
   );if
   (setq j (+ j 1));setq
  );repeat
(setq n (+ n 1))
);repeat
(if na
     );setq
);if
(acet-ucs-cmd (list "_prev"))
(acet-undo-end)
(list ss2 p1)
);defun acet-copym-array-measure
(defun acet-copym-array-divide ( ss p1 / p2 dx dy ss2 na a n j k m x y p3 )
(acet-undo-begin)
(if p2
);if
       p1 (trans p1 1 0)
       p2 (trans p2 1 0)
       p3 (trans p3 1 0)
);setq
       p2 (acet-copym-getcorner p1 "\n阵列填充另一角: " nil)
);setq
(initget 6)
(setq k (getint "\n输入列数: "))
(initget 6)
(setq m (getint "\n输入行数: "))
(setq dx (/ (- (car p2) (car p1)) k)
       dy (/ (- (cadr p2) (cadr p1)) m)
);setq
(setq n 0)
(repeat m        ;; rows
  (setq j 0)
   (setq na (entlast))
                 (= j 0)
            );and
       );not
   );if
  );repeat
(setq n (+ n 1))
);repeat
(if na
     );setq
);if
(acet-undo-end)
(list ss2 p1)
);defun acet-copym-array-divide
;Takes a selection set, two points and the distance between
;consecutive copies.
;Returns a list containing a selection set the most
;recent copy and a base point.
(defun acet-copym-measure ( ss p1 p3 d / j n na p2 )
(acet-undo-begin)
(setq j (fix (/ (distance p1 p3) d))
       n 1
);setq
(repeat j
(setq p2 (polar p1 (angle p1 p3) (* d n))
       na (entlast)
);setq
(if (= n j)
     (setq ss (acet-ss-new na))
);if
(setq n (+ n 1))
);repeat
(acet-undo-end)
(list ss p2)
);defun acet-copym-measure
;takes a selection set, two points and the number of copies to
;make of the selection between the two points.
;returns a selection set the most recent copy
(defun acet-copym-divide ( ss p1 p3 j / d n na p2 )
(acet-undo-begin)
(setq d (/ (distance p1 p3) j)
       n 1
);setq
(repeat j
       na (entlast)
);setq
(if (= n j)
);if
(setq n (+ n 1))
);repeat
(acet-undo-end)
ss
);defun acet-copym-divide
(princ)
发表于 2006-11-23 08:46:53 | 显示全部楼层
用不起来啊!
提示:; 错误: no function definition: ACET-ERROR-INIT
发表于 2006-11-23 16:01:12 | 显示全部楼层
说一下怎么用啊。。。菜菜不会用啊。。
发表于 2006-11-27 15:21:59 | 显示全部楼层
楼主的不可用啊,怎么会事,我同样出现了上面的问题
已领礼包: 6468个
 楼主| 发表于 2006-12-4 19:08:31 | 显示全部楼层
没有啊!
我测试了没有问题才传上来的呀!
要么我再试一次吧!
发表于 2006-12-12 15:25:44 | 显示全部楼层
很想学学
发表于 2007-5-29 10:23:30 | 显示全部楼层
钱少竟下不了,可惜
已领礼包: 2个
发表于 2007-6-11 17:05:58 | 显示全部楼层
ACET-ERROR-INIT是楼主自定义的函数吧?
发表于 2007-7-1 12:48:40 | 显示全部楼层
一个废贴,如果楼主不把其于的自定义函数贴出来的话,建议大家不要在这里浪费太多时间
已领礼包: 2个
发表于 2007-7-7 20:51:11 | 显示全部楼层
<CENTER><H1>在指定的方向上定长复制.lsp</H1></CENTER>
<SCRIPT LANGUAGE="JavaScript">document.write("最后修改时间: " + document.lastModified)
</SCRIPT>
<HR SIZE=5><PRE><FONT face="Fixedsys" COLOR=#990099><SPAN STYLE="BACKGROUND-COLOR: #CCCCCC">;;关闭命令回显</SPAN></FONT>
<FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">setvar</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"CMDECHO"</FONT> <FONT face="Fixedsys" COLOR="#009900">0</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
<FONT face="Fixedsys" COLOR=#990099><SPAN STYLE="BACKGROUND-COLOR: #CCCCCC">;;;================================================</SPAN></FONT>
<FONT face="Fixedsys" COLOR=#990099><SPAN STYLE="BACKGROUND-COLOR: #CCCCCC">;;功能:在指定的方向上定长复制</SPAN></FONT>
<FONT face="Fixedsys" COLOR=#990099><SPAN STYLE="BACKGROUND-COLOR: #CCCCCC">;;日期:zml84 于 2007-07-07</SPAN></FONT>
<FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">defun</FONT> <FONT face="Fixedsys">C:tt</FONT> <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">/</FONT> <FONT face="Fixedsys">s</FONT> <FONT face="Fixedsys">p1</FONT> <FONT face="Fixedsys">p2</FONT> <FONT face="Fixedsys">ang</FONT> <FONT face="Fixedsys">dist</FONT> <FONT face="Fixedsys">xx_dis</FONT> <FONT face="Fixedsys">n</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
    <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">princ</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"\n选择要复制的物体:"</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
    <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">if</FONT>        <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">and</FONT> <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">setq</FONT> <FONT face="Fixedsys">s</FONT> <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">ssget</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
             <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">setq</FONT> <FONT face="Fixedsys">p1</FONT> <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">getpoint</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"\n1.复制的基点:"</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
             <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">setq</FONT> <FONT face="Fixedsys">p2</FONT> <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">getpoint</FONT> <FONT face="Fixedsys">p1</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"\n2.复制的目标点:"</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
             <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">progn</FONT>
                 <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">setq</FONT> <FONT face="Fixedsys">ang</FONT>  <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">angle</FONT> <FONT face="Fixedsys">p1</FONT> <FONT face="Fixedsys">p2</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
                       <FONT face="Fixedsys">dist</FONT> <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">distance</FONT> <FONT face="Fixedsys">p1</FONT> <FONT face="Fixedsys">p2</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
                 <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">princ</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"\n&gt;&gt;&gt;复制间距="</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
                 <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">princ</FONT> <FONT face="Fixedsys">dist</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
                 <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">setq</FONT> <FONT face="Fixedsys">xx_dis</FONT> <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">getdist</FONT> <FONT face="Fixedsys">p1</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"\n3.确定距离范围: "</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
            <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">setq</FONT> <FONT face="Fixedsys">n</FONT> <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">fix</FONT> <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">/</FONT> <FONT face="Fixedsys">xx_dis</FONT> <FONT face="Fixedsys">DIST</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
            <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">princ</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"\n&gt;&gt;&gt;复制范围="</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
            <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">princ</FONT> <FONT face="Fixedsys">xx_dis</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
            <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">princ</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"   复制次数="</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
            <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">princ</FONT> <FONT face="Fixedsys">n</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
            <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">repeat</FONT> <FONT face="Fixedsys">n</FONT>
                <FONT face="Fixedsys" COLOR=#990099><SPAN STYLE="BACKGROUND-COLOR: #CCCCCC">;;小提示:acad2006及其以后版本的copy命令已默认为多重模式。</SPAN></FONT>
                <FONT face="Fixedsys" COLOR=#990099><SPAN STYLE="BACKGROUND-COLOR: #CCCCCC">;;为了上下版本兼容,在下面一句中使用了"m"选项。</SPAN></FONT>
                <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">command</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"_.copy"</FONT> <FONT face="Fixedsys">s</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">""</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"m"</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"non"</FONT> <FONT face="Fixedsys">p1</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">"non"</FONT> <FONT face="Fixedsys">p2</FONT> <FONT face="Fixedsys" COLOR="#FF00FF">""</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
                <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">setq</FONT> <FONT face="Fixedsys">p2</FONT> <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">polar</FONT> <FONT face="Fixedsys">p2</FONT> <FONT face="Fixedsys">ang</FONT> <FONT face="Fixedsys">dist</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
    <FONT face="Fixedsys" COLOR="#FF0000">)</FONT> <FONT face="Fixedsys" COLOR=#990099><SPAN STYLE="BACKGROUND-COLOR: #CCCCCC">;_结束 if</SPAN></FONT>
    <FONT face="Fixedsys" COLOR="#FF0000">(</FONT><FONT face="Fixedsys" COLOR="#0000FF">princ</FONT><FONT face="Fixedsys" COLOR="#FF0000">)</FONT>
<FONT face="Fixedsys" COLOR="#FF0000">)</FONT> <FONT face="Fixedsys" COLOR=#990099><SPAN STYLE="BACKGROUND-COLOR: #CCCCCC">;_结束 defun</SPAN></FONT>
</PRE>
发表于 2008-5-4 23:14:46 | 显示全部楼层
可以的,没有问题.
发表于 2008-5-7 00:15:30 | 显示全部楼层
感觉人气不旺啊。
发表于 2008-9-28 11:30:47 | 显示全部楼层
经典,下来感觉感觉,嘿嘿
发表于 2008-10-25 13:51:21 | 显示全部楼层
完全可以用的,不过貌似不是很实用呀,
发表于 2008-10-25 17:22:13 | 显示全部楼层
我也用不起来啊!
命令: cv
; 错误: *error* 函数中出错参数类型错误: stringp nil
GMT+8, 2026-11-3 07:16 , Processed in 0.709030 second(s), 61 queries , Gzip On.
