查看: 847|回复: 0
[LISP程序]:哪们高手能帮我提取这个非常好的程序?
发表于 2005-7-28 11:15:08 | 显示全部楼层 |阅读模式
(defun c:CV ( / ss p1 cmd snaptp ucshold )
(acet-error-init
   (list (list  "cmdecho" 0
               "snaptype" 0
               "snapmode" nil
               "gridmode" nil
               "snapunit" nil
               "gridunit" nil
         );list
         0
         '(progn
            (acet-sysvar-set (list "cmdecho" 0))
            (if ss
                (acet-ss-redraw ss 4)
            (if ucshold
                (acet-ucs-set ucshold)
            (acet-sysvar-restore)
            (princ)
          );progn
   );list
);acet-error-init
(setq ucshold (acet-ucs-get nil))
(if (setq ss (ssget))
     (progn
      (acet-ss-redraw ss 3)
      (setq p1 (getpoint "\nBase point: "))
      (if p1
          (acet-copym ss p1)
      );if
     );progn then
);if
(acet-error-restore)
);defun c:copym
(defun acet-copym ( ss p1 / na p2 n d lst j p3 )
(setq p2 T)
(setq n 0)
(while p2
  (setq na (entlast))
  (if (not lst)
      (setq lst (list (list ss p1)))
  );if
  (setvar "lastpoint" p1)
  (initget 128 "Repeat Divide Measure Array Undo eXit")
  (setq p2 (acet-ss-drag-move
            ss
            p1
            "\nSecond point or \n[Repeat (last)/Divide/Measure/Array (dynamic)/Undo] <exit>: "
            nil
           );acet-ss-drag-move
  );setq
  (if (= p2 "eXit")
      (setq p2 nil)
  );if
  (cond
   ((= p2 "Undo")
    (if (= n 0)
        (princ "\nNothing to undo.")
        (progn
         (command "_.undo" "1")
         (setq   n (- n 1)
               lst (cdr lst)
                ss (car lst)
                p1 (cadr ss)
                ss (car ss)
         );setq
        );progn else
    );if
   );cond #1
   ((= p2 "Repeat")
    (if (= n 0)
        (princ "\nNothing to repeat.")
        (progn
         (setq p2 (cadr (car lst))
               p1 (cadr (cadr lst))
                d (list (- (car p2) (car p1))
                        (- (cadr p2) (cadr p1))
                        (- (caddr p2) (caddr p1))
                  );list
         );setq
         (command "_.copy" ss "" d "")
         (setq   n (+ n 1)
                ss (acet-ss-new na)
                p1 (list (+ (car p2) (car d))
                         (+ (cadr p2) (cadr d))
                         (+ (caddr p2) (caddr d))
                   );list
               lst (cons (list ss p1) lst)
         );setq
        );progn else
    );if
   );cond #2
   ((equal 'LIST (type p2))
    (command "_.copy" ss "" p1 p2)
    (setq   n (+ n 1)
           ss (acet-ss-new na)
           p1 p2
    );setq
   );cond #3
   ((and (= "Divide" p2)
   );cond #4
   ((and (= "Measure" p2)
         (setq p3 (getpoint p1 "\nSelect measure ending point: "))
         (progn
          (initget 6)
          (setq d (getdist "\nDistance between copies: "))
         );progn
    );and
    (setq  ss (acet-copym-measure ss p1 p3 d) ;returns selset and base point
           p1 (cadr ss)
           ss (car ss)
            n (+ n 1)
    );setq
   );cond #5
   ((= "Array" p2)
    (setq  ss (acet-copym-array ss p1)
           p1 (cadr ss)
           ss (car ss)
            n (+ n 1)
    );setq
   );cond #6
   (p2
    (princ "\nInvalid input.")
   );cond #7
  );cond close
);while
);defun acet-copym
(defun acet-copym-array ( ss p1 / a )
(initget "Pick Measure Divide")
(setq a (getkword "\nPick (dynamic)/Measure/Divide <Pick>: "))
(cond
  ((or (not a)
       (= a "Pick")
   );or
   (setq a (acet-copym-array-dynamic ss p1))
  );cond #1
  ((= a "Measure")
   (setq a (acet-copym-array-measure ss p1))
  );cond #2
  ((= a "Divide")
   (setq a (acet-copym-array-divide ss p1))
  );cond #3
);cond close
a
);defun acet-copym-array
(defun acet-copym-array-dynamic ( ss p1 / snap grid snapu gridu p2 p3 p4 dx dy lst ss2 na a )
(acet-undo-begin)
(setq p2 (getangle p1 "\nSpecify angle <0>: "))
(if p2
     (setq p2 (polar p1 p2 1.0)) ;convert angle to a point
     (setq p2 (polar p1 0.0 1.0));use default of 0 and convert to point
);if
(setq p3 (polar p1 (+ (angle p1 p2) (/ pi 2.0)) 1.0)
       p1 (trans p1 1 0)
       p2 (trans p2 1 0)
       p3 (trans p3 1 0)
);setq
(acet-ucs-cmd (list "_3p" (trans p1 0 1) (trans p2 0 1) (trans p3 0 1)))
(setq p1 (trans p1 0 1)
       p2 (trans p2 0 1)
       p3 (trans p3 0 1)
);setq
(setq  p2 (acet-copym-getcorner p1 "\nPick a corner point to establish COLUMN and ROW distances: " T)
        dx (- (car p2) (car p1))
        dy (- (cadr p2) (cadr p1))
       lst (list p1)
        p4 T
);setq
(acet-sysvar-set
  (list
    "snapunit" (list (abs dx) (abs dy))
    "gridunit" (list (abs dx) (abs dy))
    "snapmode" 1
    "gridmode" 1
);acet-sysvar-set
(while p4
  (setvar "snapmode" 1)
  (setvar "gridmode" 1)
  ;(setq p4 (getpoint p1 "\nPick location for array element or <enter> when done: "))
  (setq p4 (acet-ss-drag-move
             ss
             p1
             nil
            );acet-ss-drag-move
  );setq
  (cond
   ((not p4) T);cond #1
   ((member p4 lst)
    (princ "\n*invalid* You already picked that point!")
   );cond #2
   (T
    (setq  na (entlast)
          lst (cons p4 lst)
    );setq
    (command "_.copy" ss "" p1 p4)
   );cond #3
  );cond close
);while
(if na
     (setq  p1 (trans (getvar "lastpoint") 1 0)
           ss2 (acet-ss-new na)
     );setq
     (setq ss2 ss);setq else
);if
(acet-ucs-cmd (list"_prev"))
(setq p1 (trans p1 0 1))
(acet-undo-end)
(list ss2 p1)
);defun acet-copym-array-dynamic
(defun acet-copym-getcorner ( p1 msg nozero / flag p2 na )
(while (not flag)
  (setq na (entlast))
  (command "_.rectang" p1)
  (while (wcmatch (getvar "cmdnames") "*RECTANG*")
   (princ msg)
   (command pause)
  );while
  (setq p2 (getvar "lastpoint"));setq
  (if (not (equal na (entlast)))
      (entdel (entlast))
  );if
  (cond
   ((not nozero)
    (setq flag T)
   );cond #1
   ((and (equal (car p1) (car p2) 0.00000001)
         (equal (cadr p1) (cadr p2) 0.00000001)
    );and
    (princ "\n*Points cannot be equal*")
   );cond #2
   ((= (car p1) (car p2))
    (princ "\n*X coords cannot be equal*")
   );cond #3
   ((= (cadr p1) (cadr p2))
    (princ "\n*Y coords cannot be equal*")
   );cond #4
   (T
    (setq flag T)
   );cond #5
  );cond close
);while
p2
);defun acet-copym-getcorner
(defun acet-copym-array-measure ( ss p1 / snap grid snapu gridu p2 p3 p4 dx dy
                                     ss2 na a n j k m x y
(acet-undo-begin)
(if p2
);if
       p1 (trans p1 1 0)
       p2 (trans p2 1 0)
       p3 (trans p3 1 0)
);setq
        p2 (acet-copym-getcorner p1 "\nPick a corner point to establish ROW and COLUMN distances: " T)
        p4 T
);setq
(acet-sysvar-set
  (list
    "snapmode" 1
    "gridmode" 1
);acet-sysvar-set
(setq p2 (acet-copym-getcorner p1 "\nOther corner for array fill: " T))
(if (> (car p2) (car p1))
     (setq dx (abs dx))
     (setq dx (* -1.0 (abs dx)))
);if
(if (> (cadr p2) (cadr p1))
     (setq dy (abs dy))
     (setq dy (* -1.0 (abs dy)))
);if
(setq k (/ (abs (- (car p2) (car p1)))
            (abs dx)
       m (/ (abs (- (cadr p2) (cadr p1)))
            (abs dy)
       k (+ 1 (atoi (rtos k 2 0)))
       m (+ 1 (atoi (rtos m 2 0)))
);setq
(setq n 0)
(repeat m        ;; rows
  (setq y (+ (cadr p1) (* dy n)))
  (setq j 0)
  (repeat k        ;; columns
   (setq x (+ (car p1) (* dx j)))
   (setq na (entlast))
   (if (not (and (= n 0)
                 (= j 0)
            );and
       );not
       (command "_.copy" ss "" p1 (list x y (caddr p1)))
   );if
   (setq j (+ j 1));setq
  );repeat
(setq n (+ n 1))
);repeat
(if na
     );setq
);if
(acet-ucs-cmd (list "_prev"))
(acet-undo-end)
(list ss2 p1)
);defun acet-copym-array-measure
(defun acet-copym-array-divide ( ss p1 / p2 dx dy ss2 na a n j k m x y p3 )
(acet-undo-begin)
(if p2
);if
       p1 (trans p1 1 0)
       p2 (trans p2 1 0)
       p3 (trans p3 1 0)
);setq
       p2 (acet-copym-getcorner p1 "\nOther corner for array fill: " nil)
);setq
(initget 6)
(setq k (getint "\nEnter number of columns: "))
(initget 6)
(setq m (getint "\nEnter number of rows: "))
(setq dx (/ (- (car p2) (car p1)) k)
       dy (/ (- (cadr p2) (cadr p1)) m)
);setq
(setq n 0)
(repeat m        ;; rows
  (setq j 0)
   (setq na (entlast))
                 (= j 0)
            );and
       );not
   );if
  );repeat
(setq n (+ n 1))
);repeat
(if na
     );setq
);if
(acet-undo-end)
(list ss2 p1)
);defun acet-copym-array-divide
(defun acet-copym-measure ( ss p1 p3 d / j n na p2 )
(acet-undo-begin)
(setq j (fix (/ (distance p1 p3) d))
       n 1
);setq
(repeat j
(setq p2 (polar p1 (angle p1 p3) (* d n))
       na (entlast)
);setq
(if (= n j)
     (setq ss (acet-ss-new na))
);if
(setq n (+ n 1))
);repeat
(acet-undo-end)
(list ss p2)
);defun acet-copym-measure
;takes a selection set, two points and the number of copies to
;make of the selection between the two points.
;returns a selection set the most recent copy
(defun acet-copym-divide ( ss p1 p3 j / d n na p2 )
(acet-undo-begin)
(setq d (/ (distance p1 p3) j)
       n 1
);setq
(repeat j
       na (entlast)
);setq
(if (= n j)
);if
(setq n (+ n 1))
);repeat
(acet-undo-end)
ss
);defun acet-copym-divide
(princ)
我想提取其中的“Divide”命令,哪们高手能帮个忙?
GMT+8, 2026-11-3 16:02 , Processed in 0.523448 second(s), 31 queries , Gzip On.
