查看: 1082|回复: 6
[求助] [求助]:关于测量两直线夹角的程序总有问题
发表于 2006-3-3 08:23:48 | 显示全部楼层 |阅读模式
各位高手,我编写的测量两直线夹角的程序得到的结果总是不对,不知是那里的问题,还请大家帮我改改!谢了!程序如下:
;;函数功能:测量两直线夹角
(defun chaxun_jiajiao(/ en1 en2 pt1 pt2 pt3 pt4 pt ang1 ang2 ang)
  (setvar "cmdecho" 0)
  (while (not(setq en1 (entsel"\n选取第一条线:"))))
  (while (not(setq en2 (entsel"\n选取第二条线:"))))
  (setq pt1 (cdr (assoc 10 (entget (car en1)))))
  (setq pt2 (cdr (assoc 11 (entget (car en1)))))
  (setq pt3 (cdr (assoc 10 (entget (car en2)))))
  (setq pt4 (cdr (assoc 11 (entget (car en2)))))
  (setq pt (inters pt1 pt2 pt3 pt4 nil))
  (setq ang1 (/ (*(angle pt (cadr en1)) 180)pi))
  (setq ang2 (/ (*(angle pt (cadr en2)) 180)pi))
  (setq ang (abs(- ang2 ang1)))
  (alert (strcat "角度= " (rtos ang 2 2)))
  (princ)
已领礼包: 2个
发表于 2006-3-3 08:36:33 | 显示全部楼层
Re: [求助]:关于测量两直线夹角的程序总有问题
[QUOTE]最初由 wangwangnn 发布
[B]各位高手,我编写的测量两直线夹角的程序得到的结果总是不对,不知是那里的问题,还请大家帮我改改!谢了!程序如下:
;;函数功能:测量两直线夹角
先看看WHILE怎麽用吧。
已领礼包: 111个
发表于 2006-3-3 09:16:46 | 显示全部楼层
先用角度标注两直线的夹角,再提取标注值显示即可
[php]
(defun lzxjj(/ en1 en2 pt1 pt2 pt3 pt4 pt ang1 ang2 ang)
   (while (setq en1 (entsel"\n选取第一条线:"))
      (if (= (cdr (assoc 0 (entget (car en1)))) "LINE")
          (progn
             (redraw (car en1) 3)
             (while (progn (setq en2 (entsel"\n选取第二条线:"))
                           (not (= (cdr (assoc 0 (entget (car en2)))) "LINE"))
                (alert "所选择的第二条线不是LINE!")
             (redraw (car en2) 3)
             (princ "\n请指定标注点:")
             (command "_dimangular" en1 en2 pause)
             (setq ang (angtos (cdr (assoc 42 (entget (entlast)))) 1 6))
             (entdel (entlast))
             (redraw (car en1) 4)(redraw (car en2) 4)
             (alert ang)
          (alert "所选择的第一条线不是LINE!")
[/php]
发表于 2006-3-3 11:06:51 | 显示全部楼层
  1. ;;;=========================================================================
  2. ;;;
  3. ;;;    Program name: qjcpj_lxjj.lsp
  4. ;;;
  5. ;;;    Description:
  6. ;;;     在AutoCAD屏幕上测量任意两条直线夹角
  7. ;;;
  8. ;;;=========================================================================
  9. (Defun *error* (msg)
  10.         (princ "错误:")
  11.         (princ msg)
  12.         (terpri)
  13. )
  14. (Defun C:JD        (/                                 cmde                         ent_1                 ent_2                 ent_1_name
  15.                                                  ent_2_name                                         ang_1                 ang_2                 ang
  16.                                                  ang_yj                 ang_min         ang_max
  17.                                                 )
  18.         (Defun TQ_ENT_NAME (ent)
  19.                 (eval '(cdr (assoc '0 (entget (car ent)))))
  20.         )
  21.         (Defun TQ_ANG        (ent)
  22.                 (setq        ang        (angle (cdr (assoc 10 (entget (car ent))))
  23.        (cdr (assoc 11 (entget (car ent))))
  24.                                                         )
  25.                 )
  26.         )
  27.         (setq cmde (getvar "cmdecho"))
  28.         (setvar "cmdecho" 0)
  29.         (setq ent_1 (entsel "\n测量两线夹角,选第一条直线:"))
  30.         (if        ent_1
  31.                 (progn
  32.                         (princ "OK!")
  33.                         (setq ent_1_name (TQ_ENT_NAME ent_1))
  34.                         (if        (= ent_1_name "LINE")
  35.                                 (progn
  36.                                         (setq ang_1 (TQ_ANG ent_1))
  37.                                         (redraw (car ent_1) 3)
  38.                                 )
  39.                         )
  40.                         (if        ang_1
  41.                                 (progn
  42.                                         (setq ent_2 (entsel "\n选第二条直线:"))
  43.                                         (if        ent_2
  44.                                                 (progn
  45.                                                         (princ "OK!")
  46.                                                         (princ)
  47.                                                         (setq ent_2_name (TQ_ENT_NAME ent_2))
  48.                                                         (if        (= ent_2_name "LINE")
  49.        (progn
  50.        (setq ang_2 (TQ_ANG ent_2))
  51.        (redraw (car ent_2) 3)
  52.        (princ)
  53.        )
  54.                                                         )
  55.                                                         (if        (and ang_1 ang_2)
  56.        (progn
  57.        (setq ang (abs (- ang_1 ang_2)))
  58.        (if        (> ang pi)
  59.        (setq ang (- ang pi))
  60.        )
  61.        (setq        ang                        (* ang (/ 180 pi))
  62.        ang_yj        (- 180 ang)
  63.        ang_min        (min ang ang_yj)
  64.        ang_max        (max ang ang_yj)
  65.        )
  66.        (setq        ang_min        (rtos ang_min 2 4)
  67.        ang_max        (rtos ang_max 2 4)
  68.        )
  69.        (alert
  70.        (strcat        "\n 夹   角α = "                ang_min
  71.        "° \n\n 180°- α = "
  72.        ang_max                                                        "°"
  73.        )
  74.        )
  75.        (princ "\n所求夹角=")
  76.        (princ ang_min)
  77.        (princ "\°  180°- 夹角=")
  78.        (princ ang_max)
  79.        (princ "°")
  80.        (redraw (car ent_1) 4)
  81.        (redraw (car ent_2) 4)
  82.        )
  83.                                                         )
  84.                                                 )
  85.                                                 (progn
  86.                                                         (princ "\n未选中第二条直线!")
  87.                                                         (redraw (car ent_1) 4)
  88.                                                 )
  89.                                         )
  90.                                 )
  91.                         )
  92.                 )
  93.                 (princ "\n未选中第一条直线!")
  94.         )
  95.         (setvar "cmdecho" cmde)
  96.         (princ)
  97. )
 楼主| 发表于 2006-3-3 13:40:58 | 显示全部楼层
谢谢各位。
yshf高手的程序角度值为何显示91d45'36.83,这好像不是一个角度值。
发表于 2006-3-3 13:58:52 | 显示全部楼层
其实就是91°45 ′36.83″
发表于 2006-3-3 23:50:45 | 显示全部楼层
  1. [FONT=courier new](defun c:test (/ en1 en2 pt1 pt2 pt3 pt4 ang)
  2.   (setvar "cmdecho" 0)
  3.   (while (not (setq en1 (car (entsel "\n选取第一条线:")))))
  4.   (while (not (setq en2 (car (entsel "\n选取第二条线:")))))
  5.   (setq        pt1 (cdr (assoc 10 (entget en1)))
  6.         pt2 (cdr (assoc 11 (entget en1)))
  7.         pt3 (cdr (assoc 10 (entget en2)))
  8.         pt4 (cdr (assoc 11 (entget en2)))
  9.         ang (abs (* (/ (- (angle pt1 pt2) (angle pt3 pt4)) pi) 180.0))
  10.   )
  11.   (alert (strcat "角度= " (rtos ang 2 2)))
  12.   (princ)
  13. )[/FONT]
GMT+8, 2026-11-7 00:47 , Processed in 0.536761 second(s), 44 queries , Gzip On.
