查看: 802|回复: 3
[求助] [求助]:请教线开口的问题
发表于 2006-3-3 12:25:02 | 显示全部楼层 |阅读模式
;;;线开口
(defun c:test040 (/ pt1 pt2 pt3 sss nnn e leng df s1)
  (CMDLA0)
  (setvar "osmode" 0)
  (setq        pt1 (getvar "VSMIN")
        pt2 (getvar "VSMax")
        pt3 (xyp-get-MidPoint pt1 pt2)
        SSS (ssget '((0 . "CIRCLE,ELLIPSE,*LINE,ARC")))
        NO1 (UDIST 1 "" "\n\t线长" NO1 pt3)
        NO2 (UDIST 1 "" "\n\t缺口长" NO2 pt3)
        nnn -1
  (while (setq e (ssname sss (setq nnn (1+ nnn))))
    (setq leng (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e))
          df   (fix (abs (/ leng (+ NO1 no2))))
    (repeat df
      (setq pt1        (vlax-curve-getPointAtDist
                  (vlax-ename->vla-object e)
                  no1
            pt2        (vlax-curve-getPointAtDist
                  (+ no1 no2)
      (command "break" e pt1 pt2)
      (command "select" "l" "")
      (setq s1 (ssget "p")
            e  (ssname s1 0)
  (CMDLA1)
这是在“通用函数及实用程序汇总1111“ 里面摘录的,我发现了一个问题,在CAD中如果有好多图形时,选中其中一个加缺口,发现在未选中的图形也加了缺口, 估计是  “(command "select" "l" "")
            e  (ssname s1 0)
”的问题, 高手帮我呀
发表于 2006-3-3 23:40:14 | 显示全部楼层
  1. [FONT=courier new];;;线开口
  2. (defun c:test040 (/ pt1 pt2 ss i e leng df ss1)
  3.   (CMDLA0)
  4.   (setvar "osmode" 0)
  5.   (setq        NO1 (UREAL 7 "" "\n线长" no1)
  6.         NO2 (UREAL 7 "" "\n缺口长" no2)
  7.         ss  (ssget '((0 . "CIRCLE,ELLIPSE,*LINE,ARC")))
  8.         i   -1
  9.   )
  10.   (while (setq e (ssname ss (setq i (1+ i))))
  11.     (setq leng (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e))
  12.           df   (fix (abs (/ leng (+ NO1 no2))))
  13.     )
  14.     (repeat df
  15.       (setq pt1        (vlax-curve-getPointAtDist
  16.                   (vlax-ename->vla-object e)
  17.                   no1
  18.                 )
  19.             pt2        (vlax-curve-getPointAtDist
  20.                   (vlax-ename->vla-object e)
  21.                   (+ no1 no2)
  22.                 )
  23.       )
  24.       (command "break" e pt1 pt2)
  25.       (setq e (entlast))
  26.     )
  27.   )
  28.   (CMDLA1)
  29. )[/FONT]
 楼主| 发表于 2006-3-4 08:48:27 | 显示全部楼层
我试了楼主的办法,好象也不行,我现在采用的方法好象挺好的,
将(setq e (entlast))改为(SETQ E (SSNAME (SSGET “C”PT2  PT2) 0))就好了
发表于 2006-3-4 10:59:45 | 显示全部楼层
最初由 zhengguoyun 发布
[B]我试了楼主的办法,好象也不行,我现在采用的方法好象挺好的,
将(setq e (entlast))改为(SETQ E (SSNAME (SSGET “C”PT2  PT2) 0))就好了 [/B]
只要好用就行。
不过,真是这样(SETQ E (SSNAME (SSGET “C”PT2  PT2) 0))肯定不行!!
GMT+8, 2026-11-7 00:47 , Processed in 0.472225 second(s), 38 queries , Gzip On.
