查看: 1116|回复: 0
[ARX函数]:选择指定图层的pline线进行填充(源码-交流)
发表于 2006-3-14 16:08:05 | 显示全部楼层 |阅读模式
程序编译通过,可CAD执行时出现错误,
请朋友门一起来看看,帮助一下
void Myfl()
        ads_name ents;
        long entNums;
        struct resbuf *rb1;
        rb1 = acutBuildList(RTDXF0,"pline",8,"0",6,"continuous",RTNONE);
        acedSSGet("X",NULL,NULL,rb1,ents);
        acutRelRb(rb1); //don't forget
        acedSSLength(ents,&entNums);
        AcDbObjectIdArray dbObjIds;
        if (entNums != 0)
                        for (long a = 0; a < entNums ; a ++)
                                AcDbObjectId  objId;
                                ads_name      ent;
                                AcDbHatch* pHatch=new AcDbHatch();
                                acedSSName(ents,a,ent);
                                acdbGetObjectId(objId, ent);
                                dbObjIds.append(objId);
                acedSSFree(ents);
                acutRelRb(rb1);
        AcDbHatch* pHatch = new AcDbHatch();
        AcDbObjectId hatchId;
    // Set hatch plane
    AcGeVector3d normal(0.0, 0.0, 1.0);
    pHatch->setNormal(normal);
    pHatch->setElevation(0.0);
    // Set hatch pattern to ANSI31 predefined type
    pHatch->setPattern(AcDbHatch::kPreDefined, "ANSI31");
    // Set Associativity
    pHatch->setAssociative(Adesk::kTrue);
    // Append an external rectangular loop to hatch boundary
    pHatch->appendLoop(AcDbHatch::kExternal, dbObjIds);
    // Append an internal loop (circle) to hatch boundary
    pHatch->appendLoop(AcDbHatch::kDefault, dbObjIds);
    // Elaborate hatch lines
    pHatch->evaluateHatch();
    // Get all associative source boundary object Ids for later use.
    dbObjIds.setLogicalLength(0);
    pHatch->getAssocObjIds(dbObjIds);
    // Post hatch entity to database
    //pHatch->postToDb(pHatch, hatchId);
        long i=0;
        AcDbBlockTable * pDbBT;
        AcDbBlockTableRecord * pDbBTR;
        AcDbDatabase * pDbDatab = acdbHostApplicationServices()->workingDatabase();
        pDbDatab->getSymbolTable(pDbBT, AcDb::kForRead);
        pDbBT->getAt(ACDB_MODEL_SPACE, pDbBTR, AcDb::kForWrite);
    // Attach hatchId to all source boundary objects for notification.
        AcDbEntity *pEnt;
    int numObjs = dbObjIds.length();
        Acad::ErrorStatus es;
    for (i = 0; i < numObjs; i++) {
        es = acdbOpenAcDbEntity(pEnt, dbObjIds, AcDb::kForWrite);
                if (es == Acad::eOk){
                        pDbBTR->appendAcDbEntity(dbObjIds, pHatch);
        pDbBT->close();
        pDbBTR->close();
        pHatch->close();
GMT+8, 2026-11-22 10:04 , Processed in 0.265622 second(s), 10 queries , Gzip On, File On.
